Capacitor Replacement: Advice Needed
  • Uy181
    • Jul 2020
    So I have a couple motherboards I am recapping that I do not have capacitor replacements already in my used inventory. I am wondering which capacitors that are currently in production for 2022 that I can use to replace the following capacitors:
    "SAM YOUNG" NXC series 6.3v 3300uf
    "Nichicon" HM series 6.3v 1000uf
    "Nichicon" HM series 6.3v 3300uf
    "United Chemi-Con" KZG series 6.3v 820uf
    "TK" ATWY series 6.3v 820uf
    Thanks!
    • 31168
    Re: Capacitor Replacement: Advice Needed
    you probably need to use polymer caps for that
    • Uy181
      • Jul 2020
      For the 6.3v 3300uf HM series, I spotted a 6.3v 3300uf UHW series that matches the ohms and ripple current rating "close enough" but the 6.3v 1000uf UHW doesn't quite match the HM spec close enough. Are there any guides out there for replacing electrolytics with polymers? The values and specs to look out for. These 6.3v 1000uf caps aren't VRM caps. They're the ones I suspect that are on the 5v rail as there's 10+ of them on each board. The polymer caps I am looking at I'm not sure if they'd work as the spec on the datasheet says they are 6 mOhms at 6.3v 1000uf as opposed to the 28-30 mOhms on the HM series and have a very high ripple current and I don't know if a higher ripple current rating will affect anything. What values should I be looking for?
        • 31168
        higher ripple is better - it's the ripple it can handle.
        so higher ripple = better
        higher voltage = o.k. but not really needed
        higher capacitance is o.k. but not needed
        higher resistance = BAD, lower is better
