UN65NU6900F - Backlight No Picture
  • TVAddict
    • Jan 2022
    • 69
    • Caribbean
    Set turns on normally, backlight stays on, after about 20secs or so thin vertical colored lines appear on the left side of screen.
    First i tried disconnecting the lvds ribbon cables one side at a time to see if i would at least have half a picture, i got nothing.
    Hooked both back up and started probing voltages on both ribbon cables, got nothing, disconnected one and got all the main voltages/signals on both ( supply - 3.2v, 26.2v and 1.8v for signals).
    So started checking for shorts on this side - right driver board, mainly caps, nothing found, so decided to hook it back up and try the reverse with the left driver board and to my surprise the voltages all came up nice and steady, so hooked both back up, voltages all gone.
    So went checking further into both driver boards and found these packs (see pics below) all reading short across their pins on both boards, my question is are these the famous diode packs or resistor packs, if they are diode packs, how should these normally read/test.
    only d17 on right side board and d47 on left side board shorts on half of the pins, all the other packs on both sides read dead short/continuity across all pins, there are 4 driver boards, the two boards with the packs are the ones on the outer ends, i disconnected the other inner boards and still had the shorted readings, any ideas or help is appreciated as always.
    Also if i disconnect the outer driver boards one at a time i get a white segment, one side is all white,no lines (right side) and the left side is same white segment but with thin colored lines see last pic.
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: UN65NU6900F - Backlight No Picture
    Remove all those diodes. As far as I remember those are for protection purposes. You can either replace them or leave the board without diodes.
    • TVAddict
      • Jan 2022
      • 69
      • Caribbean
      So they are diode packs i take it, my screen must be really screwed for all those to be shorting like that, i will try your suggestion and get give an update later, Thanks so much for your HELP.
      • TVAddict
        • Jan 2022
        • 69
        • Caribbean
        Removed all packs on both sides, still shorting across on all points as seen in my previous pics above, packs give no reading by themselves, so i'm guessing they are open?
        checked remaining diodes in the area where packs were removed, they don't give me any readings, it's difficult to get my needle meter leads on the contact points but as far as i can tell i am making good contact on the pins while checking, as i said i don't get any readings, so there's not much else left in the surrounding area's, do you guys think i may have a totally shorted out panel,maybe the COF's?, as far as i can tell i don't see any signs of burning as they are under some sort of glue.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Something will be causing a short, any Mlccs near by showing up shorted ?
          • ducky29
            • Dec 2015
            • 370
            • Europe
            Try a small voltage injection and see what gets hot. It might be a component or the screen itself.
            • TVAddict
              • Jan 2022
              • 69
              • Caribbean
              Yeah, looking more and more like the screen itself.
              May i ask what's Mlccs??
              Thanks for your reply.
              • TVAddict
                • Jan 2022
                • 69
                • Caribbean
                Yep, nothing to lose at this point, i might try it but i think the screen is toast.
                  • 12144
                  • U.S.
                  mlcc's are the little ceramic capacitors.
                  • TVAddict
                    • Jan 2022
                    • 69
                    • Caribbean
                    OK, Thanks, yeah i've been over those no shorts detected, a few read around a couple hundred ohms, they were next to resistors.
                    Maybe i'll start cutting a couple of those vgh vgl ckv tracks etc..that lead to the screen and see what happens, when i get some spare time though.
                      • 12144
                      • U.S.
                      maybe try the tape cut-off method, might work, sometimes you need to play with how many signals are blocked by the tape, one of many videos there: https://www.youtube.com/watch?v=XCJAx92JwPs
                      • TVAddict
                        • Jan 2022
                        • 69
                        • Caribbean
                        Yeah, i did try it from the mainboard side, didn't think to try it on the driver boards side of things, but you see the short is still there even with both ends driver boards disconnected, i was expecting to have picture in the middle at least, oh well, Thank you guys for all your HELP and suggestions.
                        • Unspun01
                          • Jun 2011
                          • 339
                          I have the same TV as you - UN65NU6900F.
                          Upon plug in, the TV will turn on by itself, displaying a black screen with backlights on. No sound. Doesn't really do anything.
                          I spent countless hours looking and testing for shorts and poking and prodding. Nothing would make this TV work. Turns out it was a bad panel. TV gets sound when the ribbon cables to the panel are disconnected from the mainboard (there is no TCON in the TV in any one is wondering).
                          After removing the metal covers that protect the scalar boards, I found one of the ribbon cables from the scalar board to the panel must have shorted out and caused the problem. Under a magnifying lens, there was evidence of heating and damage caused by the heating.
                          See my post in another thread here:
                          https://www.badcaps.net/forum/showpo...6&postcount=28
                          Interestingly, I wonder if this TV has been refurbished since of the 4 scalar boards along the bottom of the panel (call them 1, 2, 3, 4), the left one (1) is blue color PCB, and boards 2, 3, 4 are green like all the other boards in this TV. Perhaps this blue board and the associated COF (chip on flex) cables were replaced before I ever bought the TV.
                          Anyways, this TV is a piece of crap. 2nd UN65NU6900F I've seen fail locally in the same way. And yours. And probably countless other people out there. the NU series is not a very good TV.
                          I hate these new 4K TVs that seem built to fail.
                          • TVAddict
                            • Jan 2022
                            • 69
                            • Caribbean
                            Thanks for your reply and info Unspun01, totally agree with what you said, TV's in general have become so disposable.
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • sigmeyer
                              43UM7100PLB, no picture but have half picture when i disconnect 1 side of panel
                              by sigmeyer
                              Like the title says , this is a very interesting problem , never experienced this before so i thought i'd share and maybe get some help on this. So the problem is as such: TV comes on , some gibberish flashes on screen and the screen remains black , the owner of tv said he heard sound. Now i checked some things cleaned all connections first of all so i dont run in a circle. Then i disconnected one of the cables for the panel , and viola, the left side of screen comes on, then i tried to switch it , with left side disconnected and right connected. Same problem persists. I checked some voltages...
                              09-09-2021, 10:30 AM
                            • Davidhames
                              KDL-70R550A Peeled off LCD Tabs on left side and perfect picture for 5 minutes
                              by Davidhames
                              Hi Guys,
                              Thought I might try and seek advice on an issue I am having, I got this SONY tv for free that was having some dark greenish colouring, I replaced the T-CON and too my suprise the TV would not boot - I would get 5 blinking red LED lights. I dug deeper into this forum and someone mentioned the fact that it might be the tabs that connect to the LDC panel, and peeling them off should bring back a clear image. I tried this on the side of the T-con that was causing the tv to not boot when plugged in (left) and wow a perfect picture and was booting up fine! All was well and good...
                              02-23-2022, 08:21 PM
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
