43UM7100PLB, no picture but have half picture when i disconnect 1 side of panel
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Like the title says , this is a very interesting problem , never experienced this before so i thought i'd share and maybe get some help on this. So the problem is as such: TV comes on , some gibberish flashes on screen and the screen remains black , the owner of tv said he heard sound. Now i checked some things cleaned all connections first of all so i dont run in a circle. Then i disconnected one of the cables for the panel , and viola, the left side of screen comes on, then i tried to switch it , with left side disconnected and right connected. Same problem persists. I checked some voltages on the motherboard , and sure enough , when i connect the right flat cable my 30v , and 17v dissapear on the motherboard. I assume they go to the screen.
    Now my question is , is this a motherboard problem , or is it a screen issue?
    This is one of the newer type tvs where tcon board is soldered to the panel , wondering if i could maybe cut some traces on the right ribbon and maybe get some kind of full picture? hmm , any thoughts?
    Also when i connect the right ribbon , the voltages on the tcon board dissapear , the ribbon cable is not shorted
    The TV is LG 43UM7100PLB , no service manual or any info online
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: 43UM7100PLB, no picture but have half picture when i disconnect 1 side of panel
    This could be a shorted smd capacitor on the lcd panel pcb
    • sigmeyer
      • Feb 2020
      • 158
      • Serbia
      Ye i was thinking more in the realm of a shorted IC , but ye exactly my thinking. Ill have to strip down the plastic tomorrow so i can access it , ill post some pictures , maybe i can repair it
      • sigmeyer
        • Feb 2020
        • 158
        • Serbia
        https://monitor.net.ru/forum/attachments/63292/ I was too curious so i checked it right now , no shorts on the panel board, then i started looking on he motherboard , because there might be an issue. My attention was drawn to the chip next to the capacitor where i got the 32v that dissapears . The chip is SW52212 , and online i found a russian forum where they talked about what it seemed like exact same problem. They gave up and said it was probably a short on the glass , which i cant really believe that. Here is a picture that they posted , i recon this chip is at fault ... no way to test really without schematic and the thing shutting itself down anyway.
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
        • groomit
          Philips 50PUS7363/12 Backlight but no picture
          by groomit
          I'm having trouble with above mentioned TV. Bought it defect.
          Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
          Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
          I can see backlight, but screen stays black.
          What I've tried:
          - Disconnect right side cable from T-Con -> same (backlight but no pic)
          - Disconnect left side...
          11-22-2024, 02:43 PM
        • Rubenlily
          Quick question about the ribbon
          by Rubenlily
          Hey,
          So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
          When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
          08-17-2023, 11:09 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
