Can you dignose from the photo ? . Toshiba 65S2650EV
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    #321
    Re: Can you dignose from the photo ? . Toshiba 65S2650EV
    So
    I measured the combined resistance, and every half turn = 10 ohm, powered up, and every 100ohm I powered off/on .
    No Luck
    I want to inspect the lousy board... tracks get raised off very easily.
    I'm going to buy a new board, unless you have some other idea.
    • Storyteller12
      • Jun 2020
      • 624
      I would buy a new board at this point. 17 pages on here of troubleshooting and still no fix. I would waste this much time on a cheap toshiba TV personally
        • 12206
        • U.S.
        #323
        Originally posted by storyteller12
        i would buy a new board at this point. 17 pages on here of troubleshooting and still no fix. I would waste this much time on a cheap toshiba tv personally
        +1000
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4387
          • Italy - Milan
          #324
          +1000
          ..and so talked the man of the street with nothing to do...
          Ancient: we have focused onto pfc, now try to focuse on main switching, have you tested big mosfets QP2, QP3, capacitor C31 the grey square one?
          Have you got a frequency meter? If yes with turn on command try to measure an oscillation on the gates of QP2,QP3 if them ok, black probe on primary gnd..
            • 12206
            • U.S.
            #325
            AND the reply was BLAH BLAH BLAHBY BLAH AND BLAHBY BLAH. How ya doin ONE of the few? did you catch covid yet?
            • Ancient1
              • Dec 2019
              • 275
              • Israel
              #326
              Davi.P
              You're The Man
              C31 marking : 223J1000V . I measure ~27.5 nF In-Circuit. It looks 25% off since 223J means 22,000.
              I checked QP2 QP3 once for shorts - none.
              I don't have Oscilloscope but my Meter has Hz mode - is that OK ?
              I'll get their PDF
              • Ancient1
                • Dec 2019
                • 275
                • Israel
                #327
                Guys, I am learning quite a bit from all of this. I think Davi.P is an amazing guy !
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4387
                  • Italy - Milan
                  #328
                  ehm... wait.. 223 on a mylar cap means 22000 picoF then 22nF. Yes Hz mode means a frequency meter built in the multimeter (DMM), now i'm suspecting ic3, then everything on the standby aux line, that are ic2, ic3, D10 near ic3
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4387
                    • Italy - Milan
                    #329
                    if you can, test in diode mode between the pins: 10-11, 11-12, 14-15, 15-16, for shorts..
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      #330
                      "now i'm suspecting ic3, then everything on the standby aux line, that are ic2, ic3, D10 near ic3" - what do you mean ?
                      "if you can, test in diode mode between the pins: 10-11, 11-12, 14-15, 15-16, for shorts.." - IC3 ?
                      I'll get C31 out to measure
                      What about QP2,QP3 and my DMM Hz Mode
                      thx
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4387
                        • Italy - Milan
                        #331
                        1. i am suspecting those components
                        2. ic3
                        3. no leave c31 there, it is already measured
                        4. already said, put black on primary gnd and probe the oscillation in those mostets gate, there must be an around 100khz signal..
                        • Ancient1
                          • Dec 2019
                          • 275
                          • Israel
                          #332
                          IC3 pins :
                          Continuity : all pairs NC
                          Diode Mode : 0.L one way , other way 0.58, but 12-13 , 13-14 0.L
                          QP2 QP3 : I measured using IC3 #10 GND ( Black on GND ). I think I don't know how to measure ? ( like probes off and I see Hz ? ) , anyway , I measured all pins, no consistant result, But I saw 1K , 3K, 4K but no 100KHz
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4387
                            • Italy - Milan
                            #333
                            please read previous posts, i have explained the oscillation test, for the gnd is more safe on - of biggest electrolitics, only 2 steps, short on ps-on input, gate probing, don't probe drain or source, it can ruin your tester.
                            • Ancient1
                              • Dec 2019
                              • 275
                              • Israel
                              #334
                              I don't get anywhere near 100k
                              I will test a good TV PSU as a way of testing my DMM.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4387
                                • Italy - Milan
                                #335
                                so only on the gates you probed 1k and so on? The datasheet says operation at 50-500khz, so ic3 feels bad to me.. you ment 1khz not 1kohm right?
                                • Ancient1
                                  • Dec 2019
                                  • 275
                                  • Israel
                                  #336
                                  I do measure Hz . For sure.
                                  on another, GOOD TV board , I got 360K on 1st Mosfet and 0 on the 2nd.
                                  So I assume my DMM is OK
                                  I did the Gate , Hz Mode, measurement again :
                                  QP3 Gate = 1.3K
                                  QP2 Gate = 1.69K
                                  This time the measurements were stable, for few sec, than 0.000.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4387
                                    • Italy - Milan
                                    #337
                                    now i think ic3 is good but it goes into protection, this is possible in many situations, two of them are a not working PFC (possible), a not working U2 optocoupler, if you want to try replace it.. but if bad U2, possible bad TL431 connected to it..
                                    if you want to follow the bad PFC circuit you can probe the gate of the mosfet QF1/QF2 if i see well, with the frequency meter
                                    • Ancient1
                                      • Dec 2019
                                      • 275
                                      • Israel
                                      #338
                                      Hi. Better late than never. sorry
                                      I don\t quite understand :
                                      * "not working PFC (possible)" - I put new NCP1653A ( Vcc was ~16V with IC off)
                                      * As I recall , I think we replaced UF1 ... with Q10( A684) connected .
                                      But "if bad U2, possible bad TL431 connected to it" . AZ431 is in Cold Side . What am I supposed to do ?
                                      * "probe the gate of the mosfet QF1/QF2 if i see well" - But I just did that in previous post , no ?
                                      I upload a photo of some tests I PREVIOUSLY made of the Optos
                                      • lotas
                                        • Jan 2016
                                        • 4676
                                        • Russia
                                        #339
                                        TL431 and AZ431 have different pinouts.
                                        https://www.badcaps.net/forum/showpo...52&postcount=8
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4387
                                          • Italy - Milan
                                          #340
                                          1. There is always a doubt when buying chips from China, especially of non Chinese brands, how do you have received it, in sealed blister or free in an anonymous bag?
                                          2. Sorry i say TL431 just to intend, the type is the same as AZ431, U2 i point at, not U1.. the test does not reveal a sure good part.
                                          3. I see QF1/2 , it's not clear, you tested QP1/2..
                                            09-06-2024, 05:33 AM
                                            Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:30 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          • nikokin
                                            NEED help with clear ME image for toshiba A40-G fuz2sy1 a4607a
                                            by nikokin
                                            So i have 2 laptops, both had no image, all voltages are present except for igpu that comes after intel xe drivers installation i flash bios, one of 2 worked but had slow boot, that probably has something to do with management engine, also boot guard is active level 4
                                            on all bios i tried, i attach both original bios, and also the one i flash and worked with slow boot
                                            can someone clean any of them so i can try them
                                            thank you
                                            i tried to do it myself but none of them works
                                            if anyone knows, when i clean the image do i leave bootgaurd on level 4 or put it on level 0...
                                            01-30-2025, 03:02 AM
