Un50mu6070 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 624
    I'm having trouble with this TV.
    I have confirmed backlights work and power supply is good. There is no tcon on this model.
    Issue is the main board. When plugged into the power board the voltage drops from 13v to 9v. all pins that are supposed to be 13v are 9v. . But I cannot find a replacement board anywhere so I'm trying to repair the bad components.
    Also to note I tried unplugging the 2 lvds cables to rule out panel issues and same problem persist.
    Just need a little help tracking down the bad components.
    Any help would be greatly appreciated.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4348
    • Italy - Milan
    Re: Un50mu6070 Mainboard issue
    It is a software fault, try to locate an 8 pin chip with marking 25xYYY where xy varies, then freeze it with butane gas or compressed air can, wait 5 sec. then turn on tv..
    • Storyteller12
      • Jun 2020
      • 624
      Ok, thanks for the tip. Will try this later. However I should have mentioned that the model # is un50mu6070 version de09. When i look at shopjimmy they sell the eeprom but not for this version. So im guessing this might be a different problem. If not where can I get the eeprom for this version de09?
      Appreciate the help and I will report back about the eeprom.
      • Storyteller12
        • Jun 2020
        • 624
        Ok. I did freeze the eeprom and no dice. Nothing changes. I don’t have standby light and voltage still reads 9v. Tried removing the eeprom and plugging in just to see and still the same 9v.
        So I believe its something else drawing the power down from 13v to 9.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4348
          • Italy - Milan
          I don't think do, if the power board reports one only tension but two states 9-13 from stby to on then it is a software issue or bad processor.
          • lotas
            • Jan 2016
            • 4625
            • Russia
            Storyteller12 you can read dump with spi flash W25Q40CL programmer and put it here.
            • Storyteller12
              • Jun 2020
              • 624
              Lotus,
              Sorry don’t have a programmer to read the eeprom.
              • Storyteller12
                • Jun 2020
                • 624
                Quick update: I got the tv working.
                Davi.p thanks for your help. It was the eeprom. I switched it with 55” mu series mainboard I had from a cracked screen.
                • Storyteller12
                  • Jun 2020
                  • 624
                  Lotas,
                  What programmer should I get or do you recommend. I’ll upload the dump for you. I’m new to software related issues. This was my first.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4348
                    • Italy - Milan
                    if think to repair many in future i suggest at least a RT809F or a TL866Ii plus, them costs about 30 euro, if you need for only some small eprom CH341A will do the job.
                    • ducky29
                      • Dec 2015
                      • 370
                      • Europe
                      Originally posted by Storyteller12
                      Lotas,
                      What programmer should I get or do you recommend. I'll upload the dump for you. I'm new to software related issues. This was my first.
                      Ch341 $3
                      TL866, TL866A, TL866II PLUS ~$40
                      RT809F ~$50
                      RT809H ~$130
                      Listed them from cheapest, everyone of them gets the job done in your case.
                      Watch some reviews on youtube if you wanna learn more about each programmer and what they do.
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Lotas:
                        I receive my programmer and have dumped the file. Not sure how to upload it for you to fix.
                        I can send you a link from my onedrive where its stored if that works.
                        Thanks again for the help.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Put it in a zip file and then use the paperclip icon after clicking Go Advanced below.
                          • Storyteller12
                            • Jun 2020
                            • 624
                            See attached file.
                            Thanks for the info
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4348
                              • Italy - Milan
                              the first block is empty, maybe lotas will fill that
                              • lotas
                                • Jan 2016
                                • 4625
                                • Russia
                                Try it, but when writing this 25Q40 you need to correctly set on the programmer "STATUS REGISTERS"
                                0x88, 0x42.
                                • lotas
                                  • Jan 2016
                                  • 4625
                                  • Russia
                                  "STATUS REGISTERS"
                                  0x88, 0x42.
                                  • Storyteller12
                                    • Jun 2020
                                    • 624
                                    Thanks for the fast reply Lotas. I’ll let you know tomorrow how it works out
                                    • Storyteller12
                                      • Jun 2020
                                      • 624
                                      I programmed the old chip and it still won’t work when I installed it. I made sure the status registers were set to 0x88 and 0x42.
                                      Not sure if I’m doing no something wrong since it’s my first time feeling with eeprom.
                                      I do get a message saying chip may be protected. To hit unprotect and check data sheet. Not sure what that means.
                                      I push Unprotect. It seems to have something to do with the status register.
                                      Any ideas?
                                      Thanks again
                                      • lotas
                                        • Jan 2016
                                        • 4625
                                        • Russia
                                        Hi, what is your programmer?
                                        Read the contents (dump) again and upload them here.
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • notallbad
                                          TCL 55RP620K power board issue
                                          by notallbad
                                          Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                          0% p_dim at 1.65v and a_dim at 1v
                                          50% p_dim at 3.3v and a_dim at 1.65v
                                          100% p_dim at 3.3v and a_dim at 2.88v
                                          Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                          Leds are 2 rows of 15 6v leds.
                                          On inspection of the power board found diode MBR3200 shorted so replaced with...
                                          07-12-2025, 05:45 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • eclectric
                                          Sony Bravia KDL-70W850B T-CON board / software update issue
                                          by eclectric
                                          Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                          In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                          Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                          I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                          05-23-2022, 01:25 AM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
