samsung ue55nu7021k backlights working but blank screen
  • Yoda79
    • Dec 2021
    • 56
    • United Kingdom
    #101
    Re: samsung ue55nu7021k backlights working but blank screen
    Originally posted by lotas
    Great thank you, ordered! Due on the 6th Jan, will be back on here then, wish me luck!
    • vinceroger69
      • Mar 2012
      • 6714
      #102
      might come sooner as royal mail first class singed for, fingers crossed tv works fine after fittment
      • Yoda79
        • Dec 2021
        • 56
        • United Kingdom
        #103
        Lets hope so!
        Anyway, any videos or advise on how to change board? There doesn't appear to be any boards and don't want to try and force it off.
        • lotas
          • Jan 2016
          • 4578
          • Russia
          #104
          Lets hope so!
          Like that
          https://www.youtube.com/watch?v=Zl5eOQ-ASxY
          https://www.youtube.com/watch?v=uOr8rLj_rTk
          https://www.youtube.com/watch?v=w8lu5XAVHAI
          • Yoda79
            • Dec 2021
            • 56
            • United Kingdom
            #105
            Legend Lotas, cheers
            • Yoda79
              • Dec 2021
              • 56
              • United Kingdom
              #106
              So the board arrived this morning! I replaced the old one and the TV is back up and working!
              Thank you both for your help on this, I had assumed my TV couldn't be repaired! Its fairly simple as well, as long as you get the right parts.
              Can I ask if it's possible to determine whats wrong with the old one, can you test the various components in some way?
              • vinceroger69
                • Mar 2012
                • 6714
                #107
                Thats great news the replacement board ixed the issue.
                Reagding ficing the other board my guess as it would not take the fimware/software update one of the ics is faulty so may not be cost effective for you trying to repair it if you have not got the replacement ics/hot air station, solder/flux etc etc .
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #108
                  Did you try hot air on the main processor ?
                  • Yoda79
                    • Dec 2021
                    • 56
                    • United Kingdom
                    #109
                    Fair point, probably trying to get too adventurous. You're right I don't have any of those items apart from the solder and flux.
                    • Yoda79
                      • Dec 2021
                      • 56
                      • United Kingdom
                      #110
                      Do you mean just getting a hair dryer and using that to apply hot air?
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #111
                        Yes, we're not trying to melt the solder, just get some thermal expansion of the BGA.
                        • Yoda79
                          • Dec 2021
                          • 56
                          • United Kingdom
                          #112
                          Cheers thanks, tried this but no luck. So probably not worth the hassle. Got my TV back on anyway so a win win!!
                          Thank you to all.
                          • Yoda79
                            • Dec 2021
                            • 56
                            • United Kingdom
                            #113
                            Good morning, sorry me again. Same tv, similar issue.
                            Probably about a few weeks ago the TV seems to be locked up in a boot cycle. It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the. back and can see the backlights turning on. Its funny though as when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
                            Any thoughts, any help would be greatly appreciated.
                            • dicky96
                              HP Elitebook Screen blank - backlights but no image
                              by dicky96
                              Hi guys
                              I'm trying to fix this laptop screen
                              Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                              OK so I have the original screen which works but has lines across the bottom quarter of the screen
                              I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                              04-28-2021, 07:30 AM
                            • mrtek
                              Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                              by mrtek
                              Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                              11-26-2024, 09:58 AM
                            • Bloopeta
                              Samsung UE55JU6800K No Picture
                              by Bloopeta
                              Samsung UE55JU6800K with no image on screen.
                              I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                              Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                              I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                              Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                              05-03-2024, 10:42 AM
                            • bohaboha
                              Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                              by bohaboha
                              Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                              anyhow i couldn't t read anything else
                              the backlight is on strong and the screen does not get dark or very dark but no pictures
                              the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                              01-02-2025, 08:04 PM
                            • madverkus
                              Samsung UE50KU6072U - Backlights working, black screen
                              by madverkus
                              Hey guys
                              I got this TV from my friend and he said that one day he was trying to power it on it was just dead.
                              I did open the back of the TV and check the boards and cable connections and everything seems ok (no popped caps or anything visible).
                              I tried to turn it on few times and when I plug it in it flashes "Smart TV" logo and goes dark for about 20 seconds (no backlight yet) and after that the backlights are lit but no picture and didn't give any startup sound, sometimes it didn't start up but did show the standby led only and every time I pushed power...
                              12-23-2021, 09:49 PM
