samsung ue55nu7021k backlights working but blank screen
  • vinceroger69
    • Mar 2012
    • 6714
    #61
    Re: samsung ue55nu7021k backlights working but blank screen
    Lotas when ordering a replacement main board which numbers do we use? im still learning myself i usually use the bn number (code bn41-02262) plus the cy-nn055hgev8h lcd panel number is this correct?
    • vinceroger69
      • Mar 2012
      • 6714
      #62
      Originally posted by Yoda79
      Ok I think I've attached the photo of what you mean. It says BN95-05414Q?
      Do you think the board will be faulty, would the picture come on then? The picture test does work but inputs don't work nor is there any sound?
      Also what board at the back do you think needs replacing?
      inputs and sound all go through the mainbord as you cant update it either the next step is too try a replacement in my opinion unless more experienced members can advise us better.
      • lotas
        • Jan 2016
        • 4880
        • Russia
        #63
        Lotas when ordering a replacement main board which numbers do we use? im still learning myself i usually use the bn number (model bn41-02262) plus the cy-nn055hgev8h lcd panel number is this correct?
        If you order the mainboard for a specific Samsung model, then you need to use the number
        "BN94-XXXXXX"
        For example:
        • vinceroger69
          • Mar 2012
          • 6714
          #64
          The only place i can find with that exact board is out of stock so maybe a common issue https://www.tvparts.co.uk/lcd-tv-spa...7021kxxu-ver02
          • diif
            • Feb 2014
            • 6978
            • England
            #65
            Does applying heat to the processor with a hairdryer/hot air make any difference ? I wonder if it's a BGA issue.
            • lotas
              • Jan 2016
              • 4880
              • Russia
              #66
              If his inputs do not work and there is no sound, then most likely the HDMI inputs are disabled (something was connected to "hot").
              • Yoda79
                • Dec 2021
                • 56
                • United Kingdom
                #67
                yoda79
                can you take a clear picture of this white sticker too many thanks
                Ok so this is on the mainboard ( the green one), does this help?
                The number is BN94-12869M
                • Yoda79
                  • Dec 2021
                  • 56
                  • United Kingdom
                  #68
                  Would this be the same one as well?
                  https://www.electromix.co.uk/main-pc...8240-wx2a.html
                  • Yoda79
                    • Dec 2021
                    • 56
                    • United Kingdom
                    #69
                    So on odd occasions I could get inputs to works, could only switch via the buttons on the tv itself but whilst i got picture, got no sound.
                    Sorry can I ask what you mean connected too HOT?
                    • Yoda79
                      • Dec 2021
                      • 56
                      • United Kingdom
                      #70
                      So just checked this once again and managed to get the fire stick on the HDMI port displaying. Although the round circle suggesting its thinking keep constantly coming as well as the message as per the photos. I've also uploaded a video (zip file) to show how its constantly cycling between the screen, then get the thinking circle and then the message after-which your back to the display from the input.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #71
                        yes if it was me i would take a chance on buying it (but only you can make the decision buying it as may not solve the fault) i have just seen your post lower down good you managed too get it showing a picture again not sure whats causing that error message.
                        lotas may know could a faulty tcon cause this as its a picture setting issue?
                        • lotas
                          • Jan 2016
                          • 4880
                          • Russia
                          #72
                          Connecting HDMI to "hot" is when the TV is connected to the AC power (inserted into the socket), the Internet network cable is inserted and you connect another device via HDMI, which is also connected to the AC, a static discharge occurs in the HDMI jack and the protective diodes, controllers, processor burn out ...
                          Always first you need to connect HDMI, first of all, then the Internet cable and lastly connect to the AC (insert into the socket)
                          And turn off HDMI last.
                          • lotas
                            • Jan 2016
                            • 4880
                            • Russia
                            #73
                            HDMI may also fail with EDID (Extended Display Identification Data) corruption.
                            • lotas
                              • Jan 2016
                              • 4880
                              • Russia
                              #74
                              Yes it is.
                              • Yoda79
                                • Dec 2021
                                • 56
                                • United Kingdom
                                #75
                                That's interesting as I had been trying to connect the TV to my modem via a hardwired connection as opposed to connect via wireless and I would have connected my firestick to the TV while it's plugged in! So maybe that's what's caused the issue.
                                • Yoda79
                                  • Dec 2021
                                  • 56
                                  • United Kingdom
                                  #76
                                  Yes it is.
                                  OK great advice here, thank you all. So if this is the right one might as well chance it and see if this solves my problem. Its £40 but prob worth the chance! This is definately the right one for my TV right?
                                  Also, is it easy to change these over?
                                  • Yoda79
                                    • Dec 2021
                                    • 56
                                    • United Kingdom
                                    #77
                                    Hi all, just looking at that board I found. It has several numbers on it. The first number matches the sticker on the one within the tv on the green board (BN94-12869M) but the others on the product description do not?
                                    It lists BN41-02662A BN40-00330B EL8240 WX2A, I can't find these on my TV. Is that a problem or is this the right one for my TV?
                                    I know its a risk but for £45, I might as well give it a go.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #78
                                      3rd picture in post 56 i can see printed code BN41-02662A so yes should work ok in my opinion
                                      • lotas
                                        • Jan 2016
                                        • 4880
                                        • Russia
                                        #79
                                        BN40-00330B -TUNER
                                        The most important thing for you is that the part number BN94-12869M would correspond.
                                        • lotas
                                          • Jan 2016
                                          • 4880
                                          • Russia
                                          #80
                                          BOARD BN41-02662A is the PCB number.
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • Bloopeta
                                            Samsung UE55JU6800K No Picture
                                            by Bloopeta
                                            Samsung UE55JU6800K with no image on screen.
                                            I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                                            Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                                            I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                                            Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                                            05-03-2024, 10:42 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
                                          • 4thommo
                                            JVC-32C675 Backlights on but blank screen
                                            by 4thommo
                                            Hi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
                                            PSU 17IPS62
                                            MB 17MB110P
                                            Panel VES315WNDS-2D-N14
                                            08-04-2025, 07:42 AM
