samsung ue55nu7021k backlights working but blank screen
  • Yoda79
    • Dec 2021
    • 56
    • United Kingdom
    #41
    Re: samsung ue55nu7021k backlights working but blank screen
    Originally posted by lotas
    You have correctly formatted (FAT32) and unpacked the files for updating, try other USB flash drives and insert them into other slots.
    So I only have one USB on the TV that I can use, just checked the usb and its formatted to FAT32. Can I just double check that when I download the update, do I select the windows version or All OS. I selected All OS as I'm downloading the software on my iMac? I'm pretty sure it should be All OS but just want to check and will then use other USB's.
    • Yoda79
      • Dec 2021
      • 56
      • United Kingdom
      #42
      Ignore that I think I have answered my own question, the windows file won't extract on the mac so it has to be All OS.
      • Yoda79
        • Dec 2021
        • 56
        • United Kingdom
        #43
        So tried several times with different usb's and nothing, just hangs and then reverts back to the No Signal screen.
        Any other thoughts, do you think it's a software issue?
        • vinceroger69
          • Mar 2012
          • 6714
          #44
          I wonder if the ic can be removed from the mainboard and re programmed that way, downside is if you have not got a programmer already you would have too buy one so a replacement mainboard may work out cheaper.
          • lotas
            • Jan 2016
            • 4869
            • Russia
            #45
            Originally posted by Chrissygizmo
            I have a Samsung ue55nu7021k that has working backlights but has a dark blank screen..
            I've tried a couple of different boards from a friend without success, however, one of the boards produced the Samsung Smart logo on the screen so I'm guessing it's the main board that's at fault, is there anything I could try to repair the board or is it a case of buying a new one ?
            Thanks in advance
            What do you have with other boards (what are the faults) and how many do you have? I understand that you only have three boards.
            • vinceroger69
              • Mar 2012
              • 6714
              #46
              This thread is slightly confusing as this is a diffrent member now not the person who started the thread i have only just noticed this myself, from post 4 onwards is the member we are offering help with.
              • lotas
                • Jan 2016
                • 4869
                • Russia
                #47
                Yes, I didn’t pay attention.
                • Yoda79
                  • Dec 2021
                  • 56
                  • United Kingdom
                  #48
                  Apologies, I should have started my own thread I guess. But yes as stated I raised my query from post 4 onwards. I haven't opened up the TV but is this worth doing and taking a photo of whats inside?
                  • Yoda79
                    • Dec 2021
                    • 56
                    • United Kingdom
                    #49
                    Sorry this is beyond my technical knowledge. Are you suggesting taking something out and reprogramming it. Yeah I have no equipment to do any reprogramming! Would a replacement board fix this, I guess its hard to say without knowing what the actual fault is?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #50
                      A replacement main board would probably solve this fault and is quite easy too change but you would have to take a good clear picture of the mainboard so we can read the details on it and also one of the lcd panel stcker
                      • Yoda79
                        • Dec 2021
                        • 56
                        • United Kingdom
                        #51
                        Sorry taken so long but just about to open the TV up but just noticed its a screwless rear. Just looked at a video and the guy sues a tool to open which I don't have. Can I just use a flat screwdriver or do you think this will damage the TV? There appears to be some gaps at the bottom of the tv to pry a screwdriver in
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #52
                          It's a tool with a plastic wedge at the end. http://www.ohmsupplies.co.uk/epages/.../OHMYS01-A2.06
                          https://www.ebay.co.uk/itm/113347471576
                          • Yoda79
                            • Dec 2021
                            • 56
                            • United Kingdom
                            #53
                            Originally posted by diif
                            Great thanks. Do you think you can use a flat screwdriver for this?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #54
                              https://www.youtube.com/watch?v=oNqJppoV5S0
                              • Yoda79
                                • Dec 2021
                                • 56
                                • United Kingdom
                                #55
                                Great thank you, sorry been super hectic at work so trying to find time has been tough. Video is good thanks, just need to find something like the Smudger he uses.I'm guessing something semi hard but of rubber would be ideal.
                                • Yoda79
                                  • Dec 2021
                                  • 56
                                  • United Kingdom
                                  #56
                                  so that went better than I expected! I have got the back off and photos attached of whats there. Any thoughts? Can get better photos if you need.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #57
                                    on your first picture lower edge can you take a picture of the white sticker that says samsung on it so we can see what lcd panel number it uses thanks (on ebay the mainboards are averaging £35.00 so up too you if you want too take a risk replacing it)
                                    https://www.ebay.co.uk/sch/i.html?_f...662A&_osacat=0
                                    • Yoda79
                                      • Dec 2021
                                      • 56
                                      • United Kingdom
                                      #58
                                      Ok I think I've attached the photo of what you mean. It says BN95-05414Q?
                                      Do you think the board will be faulty, would the picture come on then? The picture test does work but inputs don't work nor is there any sound?
                                      Also what board at the back do you think needs replacing?
                                      • lotas
                                        • Jan 2016
                                        • 4869
                                        • Russia
                                        #59
                                        Mainboard
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #60
                                          Mainboard
                                          yoda79
                                          can you take a clear picture of this white sticker too many thanks
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • Bloopeta
                                            Samsung UE55JU6800K No Picture
                                            by Bloopeta
                                            Samsung UE55JU6800K with no image on screen.
                                            I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                                            Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                                            I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                                            Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                                            05-03-2024, 10:42 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
                                          • 4thommo
                                            JVC-32C675 Backlights on but blank screen
                                            by 4thommo
                                            Hi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
                                            PSU 17IPS62
                                            MB 17MB110P
                                            Panel VES315WNDS-2D-N14
                                            08-04-2025, 07:42 AM
