samsung ue55nu7021k backlights working but blank screen
  • vinceroger69
    • Mar 2012
    • 6714
    Re: samsung ue55nu7021k backlights working but blank screen
    try whats suggested in post 19 a factory reset may solve the issues your having
    • Yoda79
      • Dec 2021
      • 56
      • United Kingdom
      Originally posted by lotas
      If you reset via the "factory reset" service menu, you will get the TV as if it were from a store.
      https://www.wikihow.com/Reset-a-Samsung-TV
      Method 5
      So managed to get to the menu with the info settings mute power buttons. I have attached a photo of the menu, it says failure, does that indicate what the fault is? The factory reset isn't in the main menu but within the first option section, as per photo. Should I proceed with the factory reset?
      • vinceroger69
        • Mar 2012
        • 6714
        i would wait and see what lotas suggests
        • Yoda79
          • Dec 2021
          • 56
          • United Kingdom
          Yeah same here, was tempted to just do it but lets see what the experts say! Eagerly awaiting!
          • vinceroger69
            • Mar 2012
            • 6714
            hopefully someone will have seen that failure screen before as i have not, i am still learning about firmware and software issues.
            • Yoda79
              • Dec 2021
              • 56
              • United Kingdom
              #26
              Sorry didn't mean to suggest you're not an expert, to me you are, just that I have no idea! It was a low end tv, but still £400 and expected to last longer than 2.5 years!
              • vinceroger69
                • Mar 2012
                • 6714
                #27
                Trust me im no expert ive learnt all i know from this site and youtube i repair things as a hobby mainly just for myself and family members. we never stop learning.
                i have recenty collected a Samsung UE48H6400AW 3d smart tv of a free site it needs new backlight strips just waiting for delivery from china which has been 3 weeks now if tv is ok after i may keep it myself,
                • lotas
                  • Jan 2016
                  • 4891
                  • Russia
                  #28
                  Yes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don’t know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    so would you still suggest to do a factory reset?
                    • lotas
                      • Jan 2016
                      • 4891
                      • Russia
                      #30
                      Well, there are no more options, at your own peril and risk, one way or another, the TV does not work properly.
                      • Yoda79
                        • Dec 2021
                        • 56
                        • United Kingdom
                        #31
                        Yes, it can be located under the menu Only in no case should you change the parameters in this service menu, if you don't know what for what, the changes can turn the TV into a brick (replacing the motherboard) if EMMc is alive, then the reset will go well if bad, then you can hang on the "SAMSUNG" screensaver, then how lucky you are.
                        So just did this, and it seemed to turn off and go into standby mode. Turned the tv on and it came up with the Samsung screen then went blank and back to the No signal screen but not coded correctly?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          seems a common issue just googled the error on no signal screen https://eu.community.samsung.com/t5/...l/td-p/2307700
                          • Yoda79
                            • Dec 2021
                            • 56
                            • United Kingdom
                            #33
                            so, just tried a few things. I can't use the source button on the remote but can change with the buttons on the screen. But like before no sound and it says its optimising the video
                            • Yoda79
                              • Dec 2021
                              • 56
                              • United Kingdom
                              #34
                              Clever, you googled the error message! That one you shared doesn't seem to have a fix ...
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                not sure if you can re programe the eemc etc on these sets if a replacent mainboard is cheap maybe its worth going down that route will need a picture of your mainboard thats used in your tv plus on the metal tv chassis should be a white sticker with the lcd panel type.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  no none seem too have a fix all the ones i have been reading says replace mainboard
                                  • Yoda79
                                    • Dec 2021
                                    • 56
                                    • United Kingdom
                                    #37
                                    Just tried a fix on the link you shared, one where you reset the apps. That too, no joy. Still getting the same thing. Interestingly I get the SID_No_Signal something and sometimes it displays properly, saying No Signal.
                                    • lotas
                                      • Jan 2016
                                      • 4891
                                      • Russia
                                      #38
                                      Try to update via USB with version 1320.4
                                      https://www.samsung.com/ie/support/m...E55NU7021KXXU/
                                      • Yoda79
                                        • Dec 2021
                                        • 56
                                        • United Kingdom
                                        #39
                                        Ok so followed all of those steps but when I click on update now, it doesn't give me the option to use USB? Anyway just thinks a bit and then goes back to the No Signal screen. I check the version and it say 1310. Any idea how else I can update via the USB?
                                        • lotas
                                          • Jan 2016
                                          • 4891
                                          • Russia
                                          #40
                                          You have correctly formatted (FAT32) and unpacked the files for updating, try other USB flash drives and insert them into other slots.
                                          • dicky96
                                            HP Elitebook Screen blank - backlights but no image
                                            by dicky96
                                            Hi guys
                                            I'm trying to fix this laptop screen
                                            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                                            OK so I have the original screen which works but has lines across the bottom quarter of the screen
                                            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                                            04-28-2021, 07:30 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • Bloopeta
                                            Samsung UE55JU6800K No Picture
                                            by Bloopeta
                                            Samsung UE55JU6800K with no image on screen.
                                            I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                                            Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                                            I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                                            Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                                            05-03-2024, 10:42 AM
                                          • bohaboha
                                            Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                            by bohaboha
                                            Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                            anyhow i couldn't t read anything else
                                            the backlight is on strong and the screen does not get dark or very dark but no pictures
                                            the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                            01-02-2025, 08:04 PM
                                          • 4thommo
                                            JVC-32C675 Backlights on but blank screen
                                            by 4thommo
                                            Hi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
                                            PSU 17IPS62
                                            MB 17MB110P
                                            Panel VES315WNDS-2D-N14
                                            08-04-2025, 07:42 AM
