Removing large LCD panels
+ More Options
Posts
  • earz
    • Feb 2012
    • 30
    I'm curious what techniques everyone uses to remove/move/lift large LCD TV panels when doing backlight repairs. I typically use two large suction cups, but lifting a 65" panel off a LG a month ago and I got a little too close to the wall and accidentally crammed the corner of the panel into the wall (gouged the drywall even) which resulted in a single crack all the way across the panel. Thankfully I just do this as a hobby on TV's that I scrounge up to repair and sell, so I didn't have to make a dreaded phone call to a customer.
    That incident got me thinking about making some kind of hoist/sling mechanism to support under the panel and lift the panel straight up, instead of carrying the panel over to some other surface. I did stumble across this video on Youtube that shows a homemade lift with an electric winch on the ceiling (maybe a bit overkill?) but it got me wondering if anyone else has any nifty gadgets or creative techniques to safely remove large LCD panels?
  • neilc6
    • Nov 2015
    • 1550
    Re: Removing large LCD panels
    Following some advice posted here, I do backlight replacements on a carpeted area behind a couch. When I am ready to remove the panel, I lift the TV and let the panel slide out so it rests vertically against the back of the couch. I then rest the diffuser sheets against it maintaining the order and orientation and to protect the panel. Reverse the process to reinstall though I may need suction cups for final alignment. Can post some pics in a day or two. Waiting for strips for a Hisense 55H5C with blue backlights.
    • alfatv
      • Sep 2020
      • 353
      It looks like working space is a big factor for many of us.
      I did try sliding larger diffuser sheet under, but it needs lots of patience and I managed once to sctatch top diffuser sheet in TV, basically it's not worth it.
      What I use is a large grab bar with 2 suction caps for bathroom, it's a medical item for special needs people. I can lift 65" easily with it. Big benefit is that panel edges and corners are not stressed at all.
      If storage space is a problem, I suggest to reassemble everything back while waiting for backlights.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        For larger sets, I've used the suction cup tools that glass installers use, the cups are silicone and wont scratch and grip nicely. Smaller sets, I usually just carefully lift the panel out. I'm usually more worried about tearing/damaging tab bonds than I am actually breaking the panels....for some reason when they're flopping around loose, it makes me nervous.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • earz
          • Feb 2012
          • 30
          I’d be interested in seeing that process. Standing the thin panels on edge would make me nervous though, especially for those that have tabs on the bottom (or top) edge. I guess you’d just flip the TV so the non-tabbed side was resting on the floor.
          • diamon
            • 106
            • Netherlands
            It's the same way as mine. I have done +/- 8 tv's (between 40" and 55") and never had any issues.
            Didn't want to use suction cups, I'm afraid for breaking the glass with creating a to strong vacuum with those suction cups and lifting the glass horizontal.
            • neilc6
              • Nov 2015
              • 1550
              Here are pics as promised for a blue backlight Hisense 55H5C. Yes the panel boards go on top. I remove the back screws with the TV vertical. I barely touch the panel and let it drop out (two small pieces of tape holding it down on this model). Used suction cups to adjust the panel down a couple of mm after dropping it back in. Better to have the strips in hand than to have the TV apart for extended periods. Always test the backlights with them exposed and with the diffuser sheets installed to check for dirt, dust, and evenness. Also be careful lifting up the chassis. I did a LG 50LN once and cracked the panel by lifting the chassis from the side and it twisted cracking the panel.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                I like your method!
                LCD TV servicing=Multiple mea maxima culpas!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • SLK001
                  • May 2014
                  • 264
                  Here's a discussion that we had a couple of years ago on this very issue.
                  My go-to tool for removing large panes is my pair of double suction cup grippers.
                  • SLK001
                    • May 2014
                    • 264
                    One thing to add - resist the temptation of setting a panel directly on any form of carpet. It will attract stray fibers and lint like a magnet. Set the panel on a clean cotton towel and set the diffusers also on the towel in front of the panel (they are "attractive", too). Also, do not touch the panel or the diffusers with an unprotected hand. The oils in you hand will leave a mark that will have to be cleaned off. Wear a pair of cotton gloves, or even put a pair of cotton socks over your hand when you handle the panel.
                    • bbruzzoni
                      • Apr 2021
                      • 18
                      I recently got some suction cups that are meant for lifting TV panels and the first 2 TVs I used them on they worked perfect, although I did feel that the suction appeared to be very strong. Nonetheless, since it worked I used them on the next TV. Worked fine, but when I finished fixing the backlights and picked up the panel, there was a slight crack sound. I inspected the TV and saw nothing, so I continued assembling it. When I turned it on, sure enough one of the suction cups cracked a circle on the panel... maybe the suction is too strong, maybe I lifted it too fast, I don't know.
                      • dagav
                        • Feb 2015
                        • 14
                        • Norway
                        Despite long inactivity in the thread, and not a answer to any of the previous posts, Im posting a similar problem that I recently experienced.
                        After replacing all backlights on a Samsung 55" UE55JU6875, I got blue marks and som blue dots in dark pictures, see attached picture. This is only visibel in dark pictures. Used suctioncups to lift of the screen, so the bowmarks is caused by this, but not the dots. Anyone have explanation on what causing this?
                        • William1967
                          • Nov 2017
                          • 203
                          • Netherlands
                          This looks like the spacers inside the panel have pressed against the panel under pressure, giving you such errors.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            I haven't had that problem but watched Nick's video where he said suction marks would clear up. The spots are probably on diffusers.
                            • stav242
                              • Jan 2014
                              • 61
                              • United Kingdom
                              I've made a wooden brace which ican adjust to fit the glass panel size , them use some decent blue tape (like decorators use) to stick this to the glass. Then can lift the panel fully supported off and stand on its edge. The wood brace is holding it off the surface slightly. Works well. Can swap the panel out quite easily.
                              • dagav
                                • Feb 2015
                                • 14
                                • Norway
                                Do you have a link to the video?
                                • mainevail
                                  • Apr 2013
                                  • 6
                                  Could you supply any photos of your wooden brace? Looking for ideas. Thanks
                                  • KYBOSH
                                    • Oct 2011
                                    • 581
                                    • Unknown
                                    I have jsed stav242's wooden brace method along with suction cups on several occasions each. Both have had instances where my heart skipped a beat when something was about to go wrong. Suction cups slip and or come off mid-lift. Wooden braces brush against delicate wires or film which protrude from the glass they are trying to support.
                                    I like the looks of the back of the couch method though
                                    • Storyteller12
                                      • Jun 2020
                                      • 624
                                      I always use my hands and never broke a panel. I’ve done everything from 32” up to 86” LGs this way.
                                      I broke 2 panels with suction cups and never again.
                                      Just my 2 cents.
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        Originally posted by Storyteller12
                                        I always use my hands and never broke a panel. I've done everything from 32” up to 86” LGs this way.
                                        Just my 2 cents.
                                        When you say you use your hands do you mean you lift it and grip it vertically (like a suitcase) or horizontally (like you would carry an extra extra large pizza)?
                                        I have found that misting the screen with a little spray bottle before applying the suction cups help a lot. I also use the smaller cheaper suction cups. The quality gives the sweet spot for applying to screens. Too cheap to have a strong bond/suction that would damage the screen but just strong enough to stay attached with the aid of water and a clean surface. I got mine from Harbor Freight.
                                        • NolesFan
                                          Can LED panels be used from different TV's ( or the internals to the panel )?
                                          by NolesFan
                                          I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
                                          06-23-2025, 09:19 AM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
                                        • Helikvar
                                          Hisense 58A6KV
                                          by Helikvar
                                          No picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
                                          . Backlights also light up when tv is powered on.
                                          Removing panel ribbon cable from left side screen still dark.
                                          Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
                                          . Tcon gets 12 volt
                                          . Tried taping...
                                          02-21-2025, 03:52 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • KYBOSH
                                          Samsung UN50TU8000 - Dead Panel Forensic Questions
                                          by KYBOSH
                                          I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                                          When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                                          When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                                          Later I checked for shorts on the panel PCB boards but could not find anything.
                                          When I took a look with the FLIR i noticed the 2 resistors...
                                          08-10-2024, 08:39 AM
