Vizio P502ui-B1 has no video or sound
  • ksuper
    • Apr 2021
    • 9
    I have a Vizio P502ui-B1 4K Led TV.
    It was working fine until one day the picture went out. When the picture first went out, it had some sporadic sound.
    Now when you try to power it on, the power light comes on and fades away but that is it. There is no picture or sound.
    I tried the flashlight test, but didn't see anything.
    I opened up the case, but didn't find anything of interest. The boards all look to be in good condition, the fuse on the power board looks ok (when researching there were references to other fuses, but I only saw the one fuse), no bulging capacitors, etc.
    I also unplugged and replugged the connectors to the various boards, but nothing changed.
    Any ideas for a next step?
    Re: Vizio P502ui-B1 has no video or sound
    Show us good clear pictures of the whole backside of the TV so we can see how the boards are connected together, that will be a start so we can see what we are dealing with.
    What Voltage testing have you done so far?
    • R_J
      • 9588
      Search your model number, there are a few threads on this same model, like this one: https://www.badcaps.net/forum/showth...ight=P502ui-B1
      • ksuper
        • Apr 2021
        • 9
        I've got some pics up now. There is one of the full layout and a little closer pictures of the individual boards
        I just did the basic checks that I mentioned before. I haven't done any voltage testing.
        • budwich
          • Jul 2015
          • 3097
          the tcon is under the plate at the bottom. You need to try disconnecting the cables going from it to the panel (one at a time, with power off) to see if anything changes.
          • Storyteller12
            • Jun 2020
            • 625
            I’ve had a few of these TVs. Always seems to be the Main chips connected to the heat sink. . It needs to be reflowed or really reballed. You can check by heating the heat sink for 1-3 minutes.
            Tv should turn on then to confirm. Unfortunately it’s short lived without reballing it. Reflowing is just a temp solution
            • ksuper
              • Apr 2021
              • 9
              I disconnected the right cable and nothing changed.
              With the left cable disconnected, when I power on, I thought I saw the screen flash slightly. I waited a bit, but nothing happened.
              I powered off and back on again to see if it would flash again, but nothing happened on the power on. I waited a bit and then the screen came on with the "no signal" sign on the left side of the screen and all white on the right side.
              I was trying to get the cable box to power up to see what it would look like with a video input, but since there was no signal, the tv turned off and when I powered it back on, it was back to no activity at all (except for the power light). I tried powering off and on several times, but there was no activity except for that one time.
              • ksuper
                • Apr 2021
                • 9
                Besides that one blip, I guess I should just say there was no difference when trying to run the TV with each of the tcon connectors disconnected.
                Any ideas? Should I try something else? Replace the tcon?
                • budwich
                  • Jul 2015
                  • 3097
                  Your "one blip" appears to indicate a problem with / near the panel... maybe (withstanding the suggestion of reflowing the main board). The disconnected side (on most sets) will show up as white while the connected side may show a picture IF it is functional. You need to ensure that the cabling has seated properly during the tests otherwise your results maybe erratic. Having said that, if the "blip" is "valid", you might need to start checking some of the components on the bottom edge boards, especially the capacitors for being shorted. It is a common problem and lots of post on this forum with this type of problem. Some have fixed by replacing the shorted cap CAREFULLY with good soldering efforts. You could get lucky.
                  As suggested earlier, good pictures of the boards especially focus around the labelling of voltages will help as then certain voltage checks can be suggested / done.
                  With respect to the main boards, some have done some "baking" to see if it helps the situation which then would certainly point to a main board issue. Again, numerous posts about "board baking"... carefully.
                  • ksuper
                    • Apr 2021
                    • 9
                    Ok. I'll check and retest the cable cable connections to see what the results are and update.
                    I'll also take some pics of the voltage labels.
                    • ksuper
                      • Apr 2021
                      • 9
                      Here is the update from adjusting the cables, along with the pictures of the boards.
                      I disconnected and reconnected the cables from the panel. Upon trying to turn the tv on with the remote, I saw the same slight flash that I saw before and then nothing further on the screen. After powering off and then on again, just like last time, the tv turned on with some image.
                      As you will note in the picture, the right screen is still not working and is distorted. But now the left side has a vertical line going through it and where the no input sign is, it is distorted, whereas last time it was a normal display.
                      I'm guessing the distortions are a problem with the cables or the cables not getting the proper connections?
                      • ksuper
                        • Apr 2021
                        • 9
                        After adjusting all the panel cables on both ends, I tried powering up, with no success. I didn't see the flash and I tried powering off and on many times, but no video ever showed.
                        I checked and reconnected the cables a second time and tried to power up several times, but still no video or sound at all.
                        Any ideas where to look? I would like to be able to just get it down to the component (tcon, power, etc.) that is failing and replace it so I can get the tv up and running again. The user would like to use their tv again soon.
                        I put some pictures of the boards up in the previous post, but if something else or more specific is needed, let me know.
                        • Storyteller12
                          • Jun 2020
                          • 625
                          I already mentioned it’s most likely the BGA chip on the main board failing. It’s the ones attached to the heatsink.
                          You never responded if you tried to heat it up with hot air to see if it worked or not.
                          Don’t ask for help if you can’t follow directions.
                          • frannyjunk
                            • Oct 2010
                            • 82
                            Originally posted by Storyteller12
                            I already mentioned it's most likely the BGA chip on the main board failing. It's the ones attached to the heatsink.
                            Don't ask for help if you can't follow directions.
                            There are a couple of chips under the heat sink. Which one is typically the culprit?
                            • ksuper
                              • Apr 2021
                              • 9
                              The actions posted are what have been done.
                              Indeed, I can follow directions and that is what was being done. The others had listed some steps of things to try and report the results back to narrow down the problem area(s). What was offered by you was a potential cause and a suggestion on a way to alleviate it. While you may be correct in your assessment, I do not believe we had narrowed the problem area enough to implement your suggestion quite yet.
                              With that being said, there are two mentions of the main board being a potential area. But budwich mentioned something about the "bottom edge boards." Does that mean the boards connected to the tcon? (The ones at the bottom connected to the panel?) If so, I'm pretty sure there are no capacitors on those boards on this unit.
                              • ggil44
                                Vizio M65-E0 No Picture, No Sound
                                by ggil44
                                Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                09-03-2024, 08:30 PM
                              • gl4709
                                Samsung un55cu7000d with backlight and sound No Video / Picture
                                by gl4709
                                I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                                01-23-2025, 06:21 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • ajshoe
                                vizio E60-E3 backlights, sound, no video
                                by ajshoe
                                Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                                Does this mean remove right side (from front of TV) tabs ?
                                Like a second opinion before possibly destroying set....
                                04-07-2023, 01:59 PM
