Sony OLED XBR65A8G no video, PSU problem?
  • lotas
    • Jan 2016
    • 4661
    • Russia
    #121
    Originally posted by cheebster
    Here is the method posted by diah here;
    If you got at first test EVDD Lower than 24V then drop down... and the VIN remain at 12V or also drops down ... then do the next
    Second Test: ( running the power boards and the panel as stand alone )
    1- disconnect the Main boards totally from Power boards and from the T-CON ( mean disconnect the socket coming from the power boards & disconnect the 2 LVDS between Main boards and T-CON .. unplug them from T-CON Side )
    2- Disconnect the T-CON from Power boards ( unplug 2 sockets VIN & EVDD )
    3. RUN POWER BOARDS as Stand alone ....
    make bridge with R value 100 to 1K Ohm ( if the STBY 3.3V you can do it direct with out R but need to be sure 100% of the pins label )
    A- STBY & Power_ON ( this will turn on REG12V ON )
    B- STBY & TCON_12_ON ( this will turn on TCON_12V ON )
    C- STBY & EVDD_ON ( this will turn on EVDD V On Max 24V )
    if you confirmed all 3 Voltage in A,B,C you have ... then complete
    4- RUN The panel Module as Stand alone
    A- Feed the T-CON with VIN & EVDD V which you got at above points B & C
    Are you saying this wont work with these models ? All i get is a black screen with either original or replacement t-con, even with that panel test mode.
    I'm wondering if i should get a replacement set of cables. I attached 2 pictures, one is where i found a shorted cap, and second is the condition of the cable (can't even align it right it's so messed up, pins might not even be touching the socket pins properly.
    Also wondering, is the missing CAP (the one that was shorted) an issue ? They were all connected together, figured out missing one wasn't a big deal, maybe guess wrong.
    Rabbit hole!
    And how will it (T-CON) turn on using this method? In order to start T-CON, he still needs to issue the “Enable” command, which is supplied from the motherboard...
    • Diah
      • Feb 2013
      • 6399
      if some one never had OLED under his ass at least one time... keep silent--
      OP the test written in this threat related to Model XBR65A8G not yours.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        #123
        How can you know which TV needs Enable and which no, excuse me?
        • lotas
          • Jan 2016
          • 4661
          • Russia
          #124
          Where these 4K T-CONs from LG (Sony, LG, Philips, ...) are installed.
          • Diah
            • Feb 2013
            • 6399
            again... there are no such words t-con “Enable” signal... there data feed p+ p-, stand alone test can be done on all T-CON and its own Slave Panels.. over all brands with out F"""K “Enable” from mainboards
            so stop nonsense discussions.
            if you want to learn how open threat and ask, don't hijack other threats
            • cheebster
              • May 2008
              • 374
              #126
              hahah, i fixed the damn tv ! Woop! A hard reset fixed it. So at the end, it was just a bad cap. Pretty happy camper
              • cheebster
                • May 2008
                • 374
                #127
                Question; i've got some grey banding on the screen in the menus, this is an android tv which i don't know much. Is this normal ? I'm not sure i put back the original TCON in it.
                • Diah
                  • Feb 2013
                  • 6399
                  this happen because you removed all 4 ribbon cable and when you put them back you switched it places.... by time and pixel refresh get better
                  could you show the Cap place for refrence
                  • cheebster
                    • May 2008
                    • 374
                    #129
                    Hello, didn't remove the 4 ribbons at all, yes see my previous posts i posted a picture of it
                    • Diah
                      • Feb 2013
                      • 6399
                      i wrote to you the reason caused this look ... if you didn't, then some one ells before you.
                      • lotas
                        • Jan 2016
                        • 4661
                        • Russia
                        #131
                        Carefully clean the contacts on the bottom and top of these 4 cables, also replace the lvds cable...
                        • Diah
                          • Feb 2013
                          • 6399
                          will not help if they changing places.. also new ribbon will not help. because each channel are from Factory calibrated with mAm., need WB calibration adapter., or each time pixel refresh they will get better
                          • cheebster
                            • May 2008
                            • 374
                            #133
                            The cables were not removed they were really sticked to the board there, from factory. Maybe i'm using the wrong tcon, could this cause the bandings ? Or the LVDS cable that looks like sh1t.
                            • Diah
                              • Feb 2013
                              • 6399
                              if you are so sure 100% then as yours ribbon photo there are damage with 2 wide lines from both side.. this will reduce the Ohm. so the mAm calibration will be effected-
                              • Diah
                                • Feb 2013
                                • 6399
                                Originally posted by Diah
                                put back yours original t-con if you didn't missed with it
                                after that you do hard reset by pressing the joystick down then plug in wall remove only after changing front LED from white to green
                                by the way i wrote to you before... did you put the Original T-con? if yes then change the ribbon at least the result will be more better
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4367
                                  • Italy - Milan
                                  #136
                                  You put almost certainly the spare tcon, you need the other one, but you have to reset again
                                  • cheebster
                                    • May 2008
                                    • 374
                                    #137
                                    Ok, new set of cables didn't fix it (can't hurt). Put the original TCon in, banding is gone, image is perfect (well it's pretty clean). Sucess! Thanks for the help.. 🍺🍺🍺
                                    • Spikeman
                                      Help on Video Problem on Dell Inspiron 7459
                                      by Spikeman
                                      Hi, I'll tell you the story of this PC.
                                      The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
                                      After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
                                      However, the PC later presented the problem in the video shared very frequently.
                                      The problem also occurs at startup, in the bios and when using it as a monitor thanks...
                                      02-27-2024, 10:17 AM
                                    • Gibon378
                                      Problem with stopping audio and video for no reason
                                      by Gibon378
                                      PC Specs:
                                      • CPU: Ryzen 5 1600
                                      • GPU: GTX 1080 Palit JetStream
                                      • MOBO: ASRock ab350 PRO4
                                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                      • PSU: XFX 650W (don't remember what model)
                                      • OS SSD: ADATA SP920
                                      • OS: Windows 10 21H2
                                      Problem description:
                                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                      11-19-2022, 09:41 AM
                                    • zimeyh
                                      Problem video A1502
                                      by zimeyh
                                      Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
                                      11-15-2023, 03:19 AM
                                    • Chrissygizmo
                                      Sony KD-55XG9505 lines on screen problem
                                      by Chrissygizmo
                                      Hello again everyone,
                                      This is my latest mission, to try getting this Sony tv back to normal working order…
                                      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                      02-19-2025, 11:31 AM
                                    • hugocarmo
                                      Grundig GV-250 Repair problem. (Video inside post)
                                      by hugocarmo
                                      Hi everyone.
                                      I have the following problem.
                                      I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                      In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                      01-19-2023, 06:46 AM
