LG 55UH615A Half Screen Dark, Replaced LED's & Power Board, Completely Stumped
  • TvtechNue-b
    • Aug 2020
    • 4
    I have this LG 55UH615A with half screen is Dark. This is an edge lit TV with 2 small LED strips that run along the bottom of the TV. When I got it, only one half of it was lit. Also, there was a buzzing noise coming from the power board. I ordered new LED strips and also a replacement power board. Installed both and I'm still getting the same problem. When I test the wires going to both LED strips, Im getting solid, non fluctuating voltages from the power board and also at the connectors plugged into the LED strips. I tried to rule out if possibly the new LED strip on the dark side was bad. I took the old strip that was still good and plugged it into the side that lights up, and it lit up the strip, but when I plugged it into the other side... nothing.
    Any one with suggestions or ideas of what else I can try, I would really appreciate the help. I'm completely stumped on this.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4562
    • Italy - Milan
    Re: LG 55UH615A Half Screen Dark, Replaced LED's & Power Board, Completely Stumped
    This is a fact of connectors, this is for exclusion, obviosly there aren't any other things. How does it come to your mind to get led trip together with powerboard? The first culprit cndidate was the strip...
    • TvtechNue-b
      • Aug 2020
      • 4
      The power board was buzzing before I replace it, so I thought the old LED's were causing the buzzing on the board. So I replace the LED's first, but board was still buzzing after and the LED's were dimly lit. Still only on 1 side though. So then I thought to replace the power board. Once the new board arrived, there was no more buzzing and the LED strip was at full brightness, but still only just one side. When I test the side that doesn't light up, I get steady 261.6v out of the red wire and a steady 201.1v from the black wire, but the LED strip still doesn't turn on.
        Show us good clear pictures of the whole backside of the TV showing all the boards, then good clear straight shots of the whole power supply board so we can see what we are dealing with.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4562
          • Italy - Milan
          i don't understand, you have only two cables output but referring to the ground you have 260v on red and 200v on black? i think between red black must be higher until 260 when full brightness.. anyway check those cabling..
          • TvtechNue-b
            • Aug 2020
            • 4
            I have attached photos of my multimeter readings of all the wires coming out from the power board and also going into the LED Strips. I also have a photo where I plugged in the old strip on the side that works showing that it lights up, but when I plug the same strip into the bad side, it doesn't light up. I just don't know what else could be the fault causing this problem. If anyone knows, please advise.
            • Diah
              • Feb 2013
              • 6647
              from the photo of the strip socket i can tell yours replacement strips are for right side not the left... you need to flip wires of - + to let it work... but then how you will fit it ?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4562
                • Italy - Milan
                Hi! Ok now is very clear, forget my diagnisis of cabling, by your photo you have 2 led driver output channels, one working at 75v , and one not working at 60v. Time to search for a schematic of power board. If you can't find it at least post two extraclear pictures of top and bottom.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Can you post photo's as Budm suggested, It could help.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Have you checked Q801, Q802 and what is the part number of IC801
                    • yoxardas
                      YoXarDaS
                      • Jul 2015
                      • 4
                      sorry to bump an old thread, I have the exact same problem, did someone fixed this?
                      The left side is darker than the right side, new led strips installed but the problem is the same, the supply outputs 154v on left and 162v on right, I have reversed left with right wires and the problem moved to right side so clearly the power board has something to do with it.
                        • 12335
                        • U.S.
                        Maybe try testing or replacing c205 and c206.
                        • yoxardas
                          YoXarDaS
                          • Jul 2015
                          • 4
                          thanks I will check c205 and c206, they are in parallel on both LED+ however c801 and c802 are on the LED- left and right that I suspected bad, I have replaced them but problem is still there.
                            • 12335
                            • U.S.
                            From what I've noticed if it is a cap causing it, it's usually one of those right by the connector there.
                              • 12335
                              • U.S.
                              Probably not your issue but I have replaced caps in the past and didn't check them after. one time I chased everything then thought maybe I better check if they were ok. Maybe check them in ohm mode, should be similar to each other on ohm reading, probably in m or k region.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Hi Yoxardas
                                Having read through some old threads I would suggest reading through this one.
                                https://www.badcaps.net/forum/troubl...81#post1766681
                                • yoxardas
                                  YoXarDaS
                                  • Jul 2015
                                  • 4
                                  thank you all, I figured it out finally, the IC801 aka MAP3516 was the bad guy, I checked all components near it and everything was fine, the fact that the dimmer side responded laggy when adjusting the brightness from settings made me suspicious about this ic so I have changed it and now it works flawless.
                                  • Pipolups
                                    Corsair K70 LUX RGB dying LEDs
                                    by Pipolups
                                    Hi there !
                                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                    10-08-2024, 11:58 AM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • Raulnn
                                    TD Systems K50DLG12US half black and half white screen
                                    by Raulnn
                                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                    01-20-2024, 04:49 PM
                                  • pni
                                    Backlight panel diffuser melt by backlight leds broken
                                    by pni
                                    Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                    10-12-2025, 12:08 AM
                                  • scubacamper
                                    Sharp Aquos LC-70C6400U Half Screen Dark
                                    by scubacamper
                                    I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                    Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                    when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                    05-03-2025, 12:19 PM
