Vizio M65-F0 white light flashing on screen
  • brandhr
    • Oct 2020
    • 6
    • Usa
    I have a Vizio 65” M65-F0 that was put into service during 02/2019 and is probably used less than five hours a week on average. The white light in the picture flashes on and off about once every two seconds no matter what I am using for the source. The sound and picture are fine otherwise— so very noticeable/annoying if the scene is dark, not as noticeable when the scene is bright. My questions are: 1. Will replacing the LED strips fix this problem or is it likely a board issue? 2. If it is an issue of replacing the LED strips, should I replace them all or can I just replace the one that is flashing? Thanks.
  • xfox
    • Feb 2018
    • 84
    Re: Vizio M65-F0 white light flashing on screen
    Those Vizio TVs have intelligent full array led blah-blah-blah, main board connected to led driver board with with digital protocol, so I would check driver first for that specific line
      https://cdn.badcaps-static.com/pdfs/...d842704c0c.pdf
      See page 14
      Try setting the the Pictures mode to Standard.
      Auto brightness to off
      Backlights level to 50%
      Then see what will happen, you may have to do this on all input sources settings.
      • neilc6
        • Nov 2015
        • 1550
        I would turn off all the local dimming features.
        Black Detail - Adjusts the average brightness of the picture to compensate for large areas of brightness. Select Off, Low, Medium, or High.
        • Xtreme Black Engine™ - Based on the content, dynamically adjusts and balances the brightness and the contrast ratio of the picture by locally adjusting backlight zones.
        • Clear Action - Reduces blur in scenes with fast action but limits the range for the Backlight setting.
        • brandhr
          • Oct 2020
          • 6
          • Usa
          Thanks for all the responses. I made all the suggested setting changes and no improvement. As far as checking the LED driver board as suggested by xfox, that may be beyond my capabilities. I can generally follow YouTube videos on replacing boards/components but not sure how to check a board (other than looking for the tell tale brown/burned spot). I did find a YouTube video on how to replace the LED Light strips so thought I would ask to see if that could fix the problem. Looks like the LED driver boards are relatively cheap— would it make sense to try replacing that board? If that doesn’t fix it, would it make sense to replace the light strips? Thanks again.
          • xfox
            • Feb 2018
            • 84
            If you have a multimeter just check voltage on blinking leds, if not, try new led driver board, just buy on ebay with return option...
              But did you try what we suggested you to try on post #3 & 4?
              • brandhr
                • Oct 2020
                • 6
                • Usa
                . Yes, as stated I made all the suggested settings changes and no improvement. I do appreciate the suggestions.
                • brandhr
                  • Oct 2020
                  • 6
                  • Usa
                  Thanks for the additional info on the board. I will order a new board and see if that fixes it.
                  • gavric
                    • Jun 2011
                    • 65
                    I have same tv model that had appearance of 1/4 of horizontal backlight to be out just as picture bellow. After replacement of burned out led on that strip strip works but now it is flashing half of the strip that was initially out, same as original poster. It seems to be that led driver is bad because now swapping places with original strip it makes is flash also. I ordered led driver board 0171-2471-0172 and will update result when i see how it goes.
                      • 12129
                      • U.S.
                      Hard to tell what happened, brandhr never reported back. ??
                      • brandhr
                        • Oct 2020
                        • 6
                        • Usa
                        “Hard to tell what happened, brandhr never reported back. ??“
                        Yeah, sorry guys. I got distracted/lazy and never attempted to replace the board. Was planning on moving and was going to leave this TV for whomever bought my house, but the crazy housing market put an end to that idea. I’ve also actually gotten used to the flashing light and I really don’t notice it very often. That said, I will be interested to see if gavric is able to fix the issue with a new board.
                        • Ihandyrepair
                          sony 55X850D black screen no front white or red led light.
                          by Ihandyrepair
                          Hi guys
                          strange one
                          I have a dead Sony 55X850D
                          when plug in, black screen, no front white or red LED, no back light no screen
                          Voltages I get
                          3.3v LD/power and main board
                          reg 12V
                          reg 19V
                          3.3v on power on pin
                          no Tcon on
                          no tcon 12v
                          no BL_on
                          I do get BL_ERR 2.0v
                          I tried to bypass it by ground it but still get same symptom
                          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                          or is possible the chip next to...
                          08-07-2024, 04:58 AM
                        • harp
                          White screen repairs
                          by harp
                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                          05-13-2024, 03:43 AM
                        • spice_disc
                          Vizio TV M50-C1 reboot cycle and static on screen
                          by spice_disc
                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                          09-08-2024, 02:37 PM
                        • Gigabyte_PL
                          PS4 PRO - black screen, white light
                          by Gigabyte_PL
                          I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
                          Error returned: CE-34878-0 (I changed HDD)
                          I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the...
                          01-04-2024, 05:46 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
