PS4 PRO - black screen, white light
  • Gigabyte_PL
    • Dec 2021
    • 36
    • Poland
    I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
    Error returned: CE-34878-0 (I changed HDD)
    I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the connection). Safe mode - a nice signal that it enters the mode but no change on the screen. I took out the disk, the CMOS battery, measured the diodes between the system and the HDMI socket and the drops were 0.450. There is no breakdown between the lines on these filters. The console has never been touched before (apart from replacing the paste). HDMI socket in perfect condition (pins on the board and connecting to the cable). Replaced HDMI cables and TV - 0 effect.
    I attach log from UART.
    RETIMER is dead?
    Somone help me ?​
    • 31259
    replace the clock battery and set the time/date and reset all the settings to defaults.
    then try again.
    it's lost the time/date.
    if it's like a pc then it's lost the harddrive boot settings too
    and if it's running Linux the o.s. wont boot if the files are dated newer than the machine date/time << not a lot of people know that simple fact.
    if putting a fresh battery in and doing a complete reset still gives ATA errors then check your harddrive is connected or test it in something else
      • 31259
      one other thing,
      if it's the same as PS3 then losing the battery will de-authorise the user accounts on the console.
      so after changing the battery you need to login to the playstation network so it updates the certificates.
      THAT may be why your games reset.
      • Gigabyte_PL
        • Dec 2021
        • 36
        • Poland
        then try again.
        I already replaced the battery but it didn't help. The error still appears. I can't set anything because nothing is displayed on the screen.​
          • 31259
          maybe you can power it on with some button combo to force a reset.
          maybe some usefull info here:
          https://www.psdevwiki.com/ps4/
          • Gigabyte_PL
            • Dec 2021
            • 36
            • Poland
            thanks for help. As I wrote "Safe mode - a nice signal that it enters the mode but no change on the screen. " it''s probably one way to force reset.
            I can't initialize because nothing appears on the screen...
            Other ideas?​
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Maybe try some of the fault finding tips from in this video (1) PlayStation 4 PS4 White Light Of Death Fix - WLOD Faulty HDMI Encoder Diagnosis And Repair - YouTube
              • Gigabyte_PL
                • Dec 2021
                • 36
                • Poland
                I replaced HDMI port and Panasonic MN864729, but this did not help to solve problem.
                Before replacement, the effect is the same.
                APU dead ? Can I check it ? How ?
                • Ihandyrepair
                  sony 55X850D black screen no front white or red led light.
                  by Ihandyrepair
                  Hi guys
                  strange one
                  I have a dead Sony 55X850D
                  when plug in, black screen, no front white or red LED, no back light no screen
                  Voltages I get
                  3.3v LD/power and main board
                  reg 12V
                  reg 19V
                  3.3v on power on pin
                  no Tcon on
                  no tcon 12v
                  no BL_on
                  I do get BL_ERR 2.0v
                  I tried to bypass it by ground it but still get same symptom
                  I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                  or is possible the chip next to...
                  08-07-2024, 04:58 AM
                • harp
                  White screen repairs
                  by harp
                  To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                  Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                  On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                  05-13-2024, 03:43 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • fab13
                  EVGA GTX 980 TI black screen when launching a game - Why?
                  by fab13
                  I have a problem with an EVGA GTX 980 TI,
                  I have a problem with an EVGA GTX 980 TI it displays a black screen when starting a game on the menu for example either in HDMI OR DISPLAY PORT.
                  The basic problem is that the card does not boot, the FDMF 6823A mosfet shorts internally on the 12V line and I also changed an original one and now the card boots.
                  Driver installation OK
                  Detection of the card OK
                  No black screen on the desktop
                  No short circuit on the GPU
                  All voltages stable
                  The problem is when starting a...
                  08-25-2022, 09:10 AM
                • EazyBone
                  Sharp LC-65Q620U White Screen
                  by EazyBone
                  Another TV topic!!
                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                  08-21-2024, 12:56 PM
