Need help with resistor value please
    Re: Need help with resistor value please
    That is what I thought, nothing to backup. It's funny that you do not even know what FB is. I wonder if you ever fix power supply board, able to read schematic and fix it down to component level.
    • Diah
      • Feb 2013
      • 6435
      Thanks for the judgments, but please leave writing.. Do you...Do you.. its kinda of personalty attack would not help you and other whom read when the talk about BAD DESIGN, NOT WRONG DESIGN at time you are not who designed this boards .. and here are the differences.
      Any respectful Brand when they found ..there are fault / matter the same happened always at end customers they will look at it and issue different Rev. unit/ boards. or write procedure change/ replace/add/ remove certain parts to the service center, and this what we did over and over.. because the practice at end users are the best judgments on parts Type/ Value and design. that's why i will never defend any brand because its normal matter happened over all manufacture.
      ob because its Vizio your blood boiling over here... cool down ..i think its not yours matter if i can or cant repair or read schematic.
      • JunkmanJimbo
        • Mar 2017
        • 194
        Originally posted by budm
        2) What is the actual printing on the diode D9103? I rechecked the original diode after removing it and found it is not defective so I can reinstall it.
        "Original 621-PR1007G-T" 621-xxxxx is Mouser P/N, it is Fast recovery diode.
        "Replaced with 1N4007FFG" that is standard recovery diode not Fast recovery diode used in switching power supply. 1N4007FFG is the number Digi-Key crossed for me.
        3) So what is printed on the R9114, what is the resistance value?
        From that link, the blown up in the picture one looks like 1R0 (1 Ohm). Can't make out what's printed on the resistor R9114.
        When TV is turned on, more current will flow through that resistor due to current drawn from PFC and SMPS circuit.
        You need to check the resistance between GND and the VCC pin pf the PFC IC9801 and the 12V/24V SMPS IC9201 to see if they show low Ohms value or not.
        I hate to ask this of you budm, but I'm not good at testing components on boards unless it's something simple like a capacitor. Can you please give me more detailed instructions on what I need to do? Thank you for your help. It is very much appreciated.
          LOL! Can't repair, can't read schematic but able to tell the manufacturers what parts to removed or changed to, LOL! Have you ever done real failure analysis? And yet you said using such low Ohm resistor in power supply circuit does not make any sense. Did you tell them (Samsung and LG) to remove and change all those low Ohms resistors since it is BAD DESIGN since they sure use a lot of those low Ohms resistors?
          Good luck in your work.
            1) Again, I still like to know what the P/N as printed on the body of that diode.
            2) Remove that diode and test it in both directions in using Ohm mode.
            3) Look at the P/N as printed on the PFC IC9801 and the 12V/24V SMPS IC9201 so I can look up the spec sheets.
              BTW, provide the zoomed in picture of the R9114 that you replaced.
              • Diah
                • Feb 2013
                • 6435
                FB = Ferrite bead INDUCTOR used for blocking high frequency, not for over current protection, it can be as simple as piece of wire through Ferrite bead.
                LOL.. thx google let you know whats FB and why it used.. this why you linked photo on old type of FB which no more used for many reason... let me boil yours blood...
                1- you have time till end of this year to show me TV HD or above Res. PWB with Rsense used yours lovely 0.12Ohms
                2- compare this threat model PWB at same section within any Vizio newer model to see where and how they add FB to the same section we talking about.
                3- and the last we don't have yours Vizio over here and i am not aware of Korean brands shit too..
                  [I]1- you have time till end of this year to show me TV HD or above Res. PWB with Rsense used yours lovely 0.12Ohms[/I]
                  Oh man, stop making fools of yourself! I am laughing so hard right now my blood is boiling.
                  "old type of FB which no more used for many reason" LOL!
                  See spec sheet of the FB.
                  SAMSUNG BN44-00859, BN44-00980E. Samsung uses BBxxxx designator for Ferrtie bead inductor, LG and VIZIO (board not made by VIZIO) use FBxxx as designator.
                  So Samsung and LG are KOREAN BRANDS SHITS?
                  Now show me SCHEMATIC and the good clear pictures of YOUR power board that you have.
                  • Diah
                    • Feb 2013
                    • 6435
                    you are the fool now when you forget for reason of your high blood pressure to bold my point 3. here for you again and yours Korean shit..when the date of manufacture older than second vizio shit.
                    if you would like to have lesson for electronic mathematics to analysis and print good design... ask with respectful i will show you and teach you... other wise keep swim with yours fool of unknown how we calculated the Freq before the print.
                      I show you the proof, where is your proof?
                      Show me the schematic and the pictures of the board?
                      So you cannot provide your proof? you fools!
                      Do mean to teach us like this thread here? Telling OP to take screen apart without performing testing, telling us we cannot use force on to test the backlights?
                      People should read this thread below to see the history.
                      " Originally Posted by Diah View Post
                      man if you with this waiting time took the screen apart then you are now watching TV with it. LOL"
                      https://www.badcaps.net/forum/showthread.php?t=78439
                      • Diah
                        • Feb 2013
                        • 6435
                        you fools when you cant understand my easy english... yours SAMSUNG all same shit of the second VIZIO same old date manufacture ....--- read my point 3....
                        not good for you and your age when no more tooth at your mouth & keep playing over here like Turkey.. calm down and act back to yours real size Mr 100s PCB designer.
                        sleep time.. night.
                          sleep time.. night.
                          So you are not going to show us the schematic and the board? That is what I thought, just more BS from you.
                          Here is 2019 SAMSUNG 75Q90.
                          BN44-00980E/F
                          • JunkmanJimbo
                            • Mar 2017
                            • 194
                            1) Again, I still like to know what the P/N as printed on the body of that diode. Diode numbers....LT5302 and PR1007
                            2) Remove that diode and test it in both directions in using Ohm mode. .518 in one direction and no reading in the other direction. I guess this means the diode is good, correct?
                            Please see attached pictures of IC9801 and IC9201.
                              OK, let me look up the spec sheet of the IC's so we can check the VCC pins first.
                              "2) Remove that diode and test it in both directions in using Ohm mode. .518 in one direction and no reading in the other direction. I guess this means the diode is good, correct?" Did you check using Ohm mode?
                              It cannot be 0.518 Ohms if you did use Ohm mode, it looks like you use Diode mode not Ohm mode as I request.
                              • JunkmanJimbo
                                • Mar 2017
                                • 194
                                Sorry, I did use Diode mode. Which ohm setting do you want me to use?
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  BN44-00980E/F
                                  however i dont look on what you posted of links... but i am sure will found kind of such fool of one blind. ...also this is not only B`S of you but also the fool of you when you refer to Korean shit model name at 2019 but the the PWB was part of first Rev in year 2014 and the late shit of them new Rev in year 2016.
                                  don't expect to show you any of new clever design over here ..learn and design your self..... END
                                    So you are not going to provide YOUR SCHEMATIC and Pictures of the boards? Too much of a COWARD, Right? That is what I thought, a fool that does not understand circuit, do not know what Ferrite bead inductos are used for, don't know how to read schematic.
                                    You should leave this thread alone so I can HELP the OP, you are not providing anything to this thread. Telling OP to check FB, LOL!
                                    BTW, the bn44-00980e is REV 1.1 2018, you SHOULD learn how to read the prints on the board.
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      answer yours OP to test with Ohm or Diode...lol EINSTEIN 2020
                                        You have no idea why I ask OP to check in Ohm mode do you?
                                        • Diah
                                          • Feb 2013
                                          • 6435
                                          listen budm..
                                          OP: sorry to flood your threat problem with other issue.. but it happened.
                                          i am here not to fight with any.. and the record tell many was enemy then friends.. but fool people like you need to tracking deep their Physiology acting.
                                          to all member of this platform or who read as guest.. follow all post over this threat or any at this web. easy you can remark how many time and how long it take him to edit his post.
                                          you think edit option added to correct or add other info.. but in this Physiology show how much this person are not stable. again learn and design MR EINSTEIN
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • MidnightRoller
                                            Can a resistor lose resistance after hot air?
                                            by MidnightRoller
                                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                            02-02-2022, 11:46 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
                                          • chth96
                                            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                            by chth96
                                            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                            Since then, This AC/DC adaptor have been out of order.
                                            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                            And Is there any possibility that it will suddenly explode as well as to be out...
                                            12-03-2023, 04:40 AM
