Need help with resistor value please
    Re: Need help with resistor value please
    Or just read this thread.
    https://www.badcaps.net/forum/showthread.php?t=78439
    • Diah
      • Feb 2013
      • 6354
      [QUOTE=budm;980613] answer OP why you want Ohm test when Diode Test was OK to him,
      OP: could you please show us yours DM which you do test with... thanks.
        Oh look, I edit post in this thread here too! After I found more info about the unit.
        https://www.badcaps.net/forum/showpo...18&postcount=6
          [QUOTE=Diah;980619]
          To Diah if you want to know, read below:
          if you would like to have lesson for electronic mathematics to analysis and print good design... ask with respectful i will show you and teach you... other wise keep swim with yours fool of unknown how we calculated the Freq before the print...
            Originally posted by JunkmanJimbo
            Please see attached pictures of IC9801 and IC9201.
            IC9801 PFC IC UCC28063: Check resistance between VCC pin 12 and GND pin 6.
            IC9201 SMPS IC SSC9522: Check the resistance between VCC pin 2 and GND pin 4.
            • JunkmanJimbo
              • Mar 2017
              • 192
              IC9801 PFC IC UCC28063: Check resistance between VCC pin 12 and GND pin 6. With my ohm meter set to 20k I get a reading of 2.72 between pin 12 and pin 6.
              With my ohm meter set to 20k I get a reading of 2.72 between pin 2 and pin 4.
                So both IC's show exact same reading, 2.72K?
                • JunkmanJimbo
                  • Mar 2017
                  • 192
                  That is correct. Both show the same reading.
                    OK, let me look at the board layout.
                      Check the resistance between the two legs of cap C9211, C9146.
                      • JunkmanJimbo
                        • Mar 2017
                        • 192
                        They both actually show the same numbers 2.72.
                          OK.
                          Lift up one end of the jumper wire J928 or J930 of the board, this will disconnect the switched VCC from the 12V/24V SMPS IC.
                          Put in the new R9114 SMD resistor.
                          You will power up the power board by itself first to make sure the R9114 will not blow up, then you will connected a 220 ~ 470 Ohms (what ever value you have in that range) resistor between PS-ON and 5V/3.3V pin to force on the power supply and see if you do have 380 ~ 400VDC on the main 450VDC main filter cap or if R9114 will blow up again.
                          BTW, do you know what wattage of the replacement of R9114 is? Is it the same physical size as original one?
                          This power supply and mainboard also known for bad solder joints on the connector that goes to the main board.
                          • JunkmanJimbo
                            • Mar 2017
                            • 192
                            OK.
                            I can do part of this but I don't have any resistors to perform that task between PS-ON and 5V/3.3V pin. Is there any other way to do this? The SMD R9114 resistor is the resistor I got from the youtube video posted earlier. Sorry, I don't have everything I need to do this. If there is another way please let me know. I appreciate your patience, understanding and all of your help.
                              You can do the force on test without the resistor, I suggest to use resistor in case you make wrong connection that can cause damage to the circuit, so if you perform the connection correctly for sure then you can do without using resistor, so inspect real well on how you have the PS-ON and 5V/3.3 pins connected together, I would solder one wire to each pin then you can connect the end of the wires together after powering up then wait about 5 seconds before connecting the two ends of the wire together to simulate power on condition.
                              • JunkmanJimbo
                                • Mar 2017
                                • 192
                                Thank you budm. I will try to get this done tomorrow and I will definitely let you know the outcome. Thanks again for everything. It is very much appreciated.
                                  Right now we are trying to find out which circuit is drawing so much current to flow through R9114 that cause it to burn up.
                                  If it works, you should see about 380 ~ 400VDC on the main filter cap when you touch the PS-On wire and the 5V/3.3V together.
                                  There will be no 12V/24V since we lift up one end of the jumper wire that feed switched VCC to the 12V/24V SMPS IC.
                                  • JunkmanJimbo
                                    • Mar 2017
                                    • 192
                                    Please explain main filter cap and if possible the location. Thanks
                                      There are 3 of them, they are 82uF 450VDC C9804, C9805, C9823.
                                      You can check the Voltage on the two legs of any one of the 3 caps since they are connected in parallel.
                                      You must be real careful since you are working on the HOT deadly side so not touch anything with your hands or body, do not let the test probes slip either.
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16956
                                        [QUOTE=Diah;980619]
                                        You need to cool your act down a little....
                                        <--- Badcaps.net Founder
                                        Badcaps.net Services:
                                        Motherboard Repair Services
                                        http://folding.stanford.edu/
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • JunkmanJimbo
                                          • Mar 2017
                                          • 192
                                          Hey budm, sorry I didn't get a chance to do this yesterday. I just now followed your procedure and the resistor blew as soon as I plugged in the power cord. I didn't even get the chance to power on the board. The first time it didn't blow until I turned the TV on. This makes no sense. I did use a small clamp with rubber ends to clamp the board to the table to hold it in place. I clamped it over the power connector where the power cord plugs in. I don't know why that would have made a difference.
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            by mikey5791
                                            Hi to all forum members,
                                            12-26-2024, 04:55 AM
                                          • MidnightRoller
                                            Can a resistor lose resistance after hot air?
                                            by MidnightRoller
                                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                            02-02-2022, 11:46 PM
                                          • artvandalai
                                            What resistor ohm will work better to repair this waterpik?
                                            by artvandalai
                                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                            01-05-2025, 04:10 PM
                                          • chth96
                                            Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                            by chth96
                                            I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                            Since then, This AC/DC adaptor have been out of order.
                                            But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                            After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                            And Is there any possibility that it will suddenly explode as well as to be out...
                                            12-03-2023, 04:40 AM
