UN55D6000SFXZC no video issue
  • basha318i
    • Jul 2020
    • 4
    I know this has been discussed several times in this forum; but usually people tend to replace the whole board; while I'm trying to figure out what's wrong with it & replace it as a last resort. As I'm trying to learn while fixing this TV.
    Here's what I have so far; please feel free to correct me if I'm wrong:
    My issue is not in the power board. Simply because when I disconnect the main board the LED’s come on; which I believe means that there’s a short somewhere in the main board.
    So here’s what I’ve found so far:
    1. LED’s come on when I disconnect the MB.
    2. tested the voltages out of the PS board & they all check.
    3. F11 (fuse) in T-con board is good (continuity) but it has zero voltage.
    4. PANEL_VCC is dead in the MB; it should read 13v (not sure)
    5. PANEL_VCC is the output of protection IC IC210.
    6. IC210 has good input to it coming from the PS board via the 20 pin connector.
    7. IC210 EN (Enable) pin is dead; as if whatever (I think should be the MCU) turning it on so it can supply voltage to the panel is not.
    8. IC210 is good; I applied 5v to the EN pin & it turned on; which delivered the 13v to the T-con board.
    9. The TV is responsive to remote; I mean when you press buttons in the remote the stand by LED blinks; not sure if this acknowledgement is coming from the MCU or a simple IR circuitry in the IR transponder board.
    I cannot find schematics for the main board so I can troubleshoot it further; any help would be appreciated.
  • neilc6
    • Nov 2015
    • 1550
    Re: UN55D6000SFXZC no video issue
    12V to the tcon is typically switched through a FET with an on signal from the processor. Hard to find schematics for main boards. Things you can check are on board regulators. The D model year main boards do have a lot of flash memory failures. You can spray with upside down can of duster to freeze it before plugging in.
      Try as neilc6 suggest, right now more likely that the main is not sending PS-ON, BL-ON, DIM, and on command for the switched 12V for running the T-CON.
      • basha318i
        • Jul 2020
        • 4
        Thanks for your reply & recommendation; I've tested every transistor according to the poor service manual & all voltages are present & correct.
        I'm not sure I do understand spraying a duster with upside down; do you mean to cool down the main board might get it to work? Sorry I'm trying to learn here.
        • basha318i
          • Jul 2020
          • 4
          Thank you for noting that; I have tested these signals in the 20-pin connector & they seem to be fine, or maybe I'm just missing something?
          • budwich
            • Jul 2015
            • 3097
            list the pins (labels) and readings that you get on each so the forum can see what you are saying is "fine".... "fine" some times is in the eyes of the beholder, learning or not.
            • neilc6
              • Nov 2015
              • 1550
              Originally posted by basha318i
              I"m not sure I do understand spraying a duster with upside down; do you mean to cool down the main board might get it to work? Sorry I'm trying to learn here.
              An inverted duster will spray out the propellant only acting like freeze spray. You want to freeze the flash module.
              Here is a video of a D series flash replacement.
              https://youtu.be/812DCrpZufk
                Are you sure they are fine? So what are the readings for the control signals that goes to the power supply board?
                It cannot be fine if you turn on the TV but the backlights do not come on when you have every things all connected back up.
                You should read Basic LCD TV troubleshooting to know what the TV needs to function.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  The UN55D6000SFXZC uses OneNAND, not the TSOP48 NAND in this video, that's on boards up to 46". It would have been obvious had the OP posted photos.
                  • Soulzink
                    Samsug washing machine. Power supply DC41-00189a board issue
                    by Soulzink
                    I am trying to fix a samsung washinmachine power supply main board.
                    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                    The power supply board reference is the following: DC41-00189a
                    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                    04-19-2025, 06:26 AM
                  • alltvrepairs
                    Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                    by alltvrepairs
                    I have confirmed that I have a mainboard problem.
                    I have tracked no hardware issued on board so might be a software dump required.
                    I have searched a bit but wasn't able to find anything for my screen:
                    Here are some more details:
                    Panel: cy-nn065hgev1h
                    Main: BN94-14180M P08F
                    Your help much appreciated!
                    05-16-2025, 03:03 AM
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
                  • notallbad
                    TCL 55RP620K power board issue
                    by notallbad
                    Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                    0% p_dim at 1.65v and a_dim at 1v
                    50% p_dim at 3.3v and a_dim at 1.65v
                    100% p_dim at 3.3v and a_dim at 2.88v
                    Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                    Leds are 2 rows of 15 6v leds.
                    On inspection of the power board found diode MBR3200 shorted so replaced with...
                    Yesterday, 05:45 AM
