Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    I have confirmed that I have a mainboard problem.
    I have tracked no hardware issued on board so might be a software dump required.
    I have searched a bit but wasn't able to find anything for my screen:
    Here are some more details:
    Panel: cy-nn065hgev1h
    Main: BN94-14180M P08F
    Your help much appreciated!
  • Diah
    • Feb 2013
    • 6614
    make jumbers between this 2 points feedback FB, then disconnect one LVDS at time.... see which half of screen will show image
    • alltvrepairs
      • Jan 2014
      • 256
      • Malta
      Have checked these points before and with both LVDS disconnected there was 3.3v and 0v,
      However I have tried 2 other boards similar but different BN94 number and got a picture. 1 perfect pic (From UE55MU6400) and 1 almost B/W with lines.
      Got the Panel no from Service Mode for the good picture board and tried to update the second (B/W pic) board as its identical board but didn't find a matching model out of all those different displays in SM.
      • alltvrepairs
        • Jan 2014
        • 256
        • Malta
        Anyone has the correct spi dump for this board?
        Thanks!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4544
          • Italy - Milan
          Working software and no output video tends to be bad tcon integrated to main board.. maybe the data on the tcon spi eprom, you can import that one on the board that displays ok
          • alltvrepairs
            • Jan 2014
            • 256
            • Malta
            Hi, interesting as didn't know about this trick. Did this but with both connectors out and points shorted, the tv start rebooting sequence. Trying each lvds makes no difference.
            I have swapped ic1603 ic1604 with a working but wrong panel board but still same problem.
            The tcon is part of the cpu so no more places to look at. I have just ordered a replacement board with same specs and display.
            I have managed to get the dumps for both ICs. Will post them later in the correct section.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4544
              • Italy - Milan
              no software issue then, short circuit in tcon power supply circuits, maybe a small cap, you can test also mosfets & diodes
              • alltvrepairs
                • Jan 2014
                • 256
                • Malta
                For curiosity, do you still remove the EEprom / SPI chips from main board to read / write? With closeby SMDs sometimes becomes a bit risky job. I am aware that the programmer cannot power supply the whole board.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4544
                  • Italy - Milan
                  i .always try to read with clip, in certain situations it does not go, but it's mandatory a verify after.
                  • Asraf Atb
                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                    by Asraf Atb
                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                    01-27-2025, 05:02 PM
                  • mrautom8
                    Samsung TV UN75H6350AFXZC main board schematics?
                    by mrautom8
                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                    I love a good logic puzzle but getting lost without any schematics.
                    No shorts on ANY capacitor main board.
                    Thermal camera shows 3.3V inductor getting warm instantly but...
                    10-19-2025, 06:32 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Lee M.
                    Samsung UN75RU8000FXZA bad main board?
                    by Lee M.
                    When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                    11-08-2023, 07:46 PM
