Sony XBR-70850B Lightning
  • heffneil
    • Jun 2020
    • 20
    Hey guys, so I have this tv and we got a close-by lightning strike. I turned the tv on and no picture and got 3 blinking lights. Everything indicates a dead logic board. I replaced the main logic board with a new one and have a green amber light blink. Tv doesn't turn on automatically, I power it on and I get a white light on the indicator and then switches to the green and amber. The screen flashes white for a split second.
    The green amber light indicates the firmware doesn't match the screen. I downloaded the proper firmware and put it on, now, 6 different thumb drives and plugged it in all three ports. Nothing happens here. Its stuck for hours in the green amber blink. I can not get it to flash. I'm stuck and not sure what else to do.
    Any recommendations here? Sony won't help. I've made sure the USB is FAT32. I've tried the file in the root, I tried it in the directory and the file in that directory nothing catches it.
    Any ideas would be GREAT! Thanks again
    Re: Sony XBR-70850B Lightning
    Any of the devices connected to the TV get damaged?
    • heffneil
      • Jun 2020
      • 20
      no devices were ruined best I can tell. All connected was a receiver which I still get sound out of. I can't and don't see sony logo or anything.
      I lost some IP cameras, an optisolator in between my house and outbuilding, and a couple EOL resistors on my alarm system.
      • nomoresonys
        • 12269
        • U.S.
        Did the numbers on the sticker of both boards match up?
        • heffneil
          • Jun 2020
          • 20
          Yes the board(s) are both A2068024A but the numbers after are different. I don't know if the numbers after that are a serial number for the board or what...
          Thanks!
          Neil
          • nomoresonys
            • 12269
            • U.S.
            Sonys can be finicky:Turn TV on
            Wait one minute
            Insert USB drive
            Wait for LED on USB drive to stop blinking
            Wait 15 minutes
            If on-screen activity does not indicate success, turn TV off, remove USB drive and repeat steps.
            • nomoresonys
              • 12269
              • U.S.
              Maybe a variable would be have USB drive in then turn tv on.
              • heffneil
                • Jun 2020
                • 20
                I've tried this a bunch of times both ways. I didn't want to be dense but was I supposed to turn the TV on ever?
                Thanks!
                Neil
                • nomoresonys
                  • 12269
                  • U.S.
                  Yes, turn it on wait a minute, put usb drive in.
                  • heffneil
                    • Jun 2020
                    • 20
                    Someone provided me a tech manual. It said if I disconnect the Main board from the tcon it should display test patterns. It never did. I believe the Tcon is dead too?
                    • nomoresonys
                      • 12269
                      • U.S.
                      OK, curious situation, on my old sony kdl from 2009, I had the test patterns when mainboard was unhooked but it only needed the firmware update and it was good to go so I think you are on the right track.
                      • heffneil
                        • Jun 2020
                        • 20
                        Right so since I didn't get the test patterns I have to assume the tcon board is dead too?
                        I don't know if it won't take a firmware update if the tcon is bad. Im confused man. Frustrated beyond belief!
                        • nomoresonys
                          • 12269
                          • U.S.
                          The tcon can be tested, some are easier than others as some have clearly marked test points, I think I saw Budm had a chart or link about what voltages to expect, I tested my tcons before but I swear I can't remember how I did a procedure even a week ago.
                          • heffneil
                            • Jun 2020
                            • 20
                            t con board is less than $20. I am replacing it. I don't have time (Really patience) to look up testing it. Without the test pattern I have to assume its a goner.
                            • budwich
                              • Jul 2015
                              • 3097
                              Wait one minute
                              Insert USB drive
                              Wait 15 minutes
                              OP... what type of USB drives are you using? As this post suggests, when the usb device is being accessed by the set IF that drive has a LED indicator on it, it should flash... do you see any flashing? do you actually have a drive with the indicator on it?
                              • nomoresonys
                                • 12269
                                • U.S.
                                Think I would too if nothing else at least you will have a spare.
                                • heffneil
                                  • Jun 2020
                                  • 20
                                  I did have a thumb drive with a light. It was just solid on. never blinking....
                                  Sigh - tcon will be here in a few days. I don't need spare parts. I ordered another main board but then cancelled it. I think if the main board can't talk to the Tcon it can't know which TV it is to update?
                                  • nomoresonys
                                    • 12269
                                    • U.S.
                                    Well without testing you usually wind up with spare parts.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Possibly, but from my limited experience (from sharp and old sony), when the system starts up from plug in with a USB previously already inserted, the "boot operation" does a "quick check" to see if it recognize a "load file" on the drive and goes from there.... if nothing recognized, set attempts normal boot up. IF something is recognized, it attempts to load file that it identified. Not sure at this point, the tcon has any impact. Having said that, some sets (thru my readings) do communication with the tcon to determine the size / model of the panel so that can be set properly but to me, that is after a successful boot up of the main.
                                      Hope the replacement tcon solves the problem.
                                      • heffneil
                                        • Jun 2020
                                        • 20
                                        Me too! We will see. Apparently the tcon is different for each model tv so hopefully, this gets me some image. I can't find the new cable set unfortunately and I don't have the dexterity to test each pin with a meter!
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • Nopy
                                          Sony KDL-55EX500 solid green screen
                                          by Nopy
                                          I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
                                          My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green...
                                          03-08-2022, 07:48 PM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
