Vizio SV420M Yellow Logo and That's All She Wrote!
  • KookieProfessor
    • May 2020
    • 13
    • United States of America
    Sorry, meant to say Orange Logo, Not Yellow!
    I'm trying to diagnose the subject unit and have read all the available posts on this same unit with similar issues. I think it may be the EEPROM on the main logic board, but I'd like to be a bit more sure that I'm barking up the right tree.
    I have 5.21 VSB at the power supply board
    0V on PS_ON
    PS_On wire disconnected at logic board and then when forcing the Pwr Supply on w/5VSB jumped to PS_ON through a 1Kohm resistor, I get 2.96V @ PS_ON, and 12 volts at the 12 V pins, but nothing else on any of the other power supply pins, nor any change using either the ON/Off button or the remote. (Just a constant standby as long as it's plugged into mains power.)
    Fuse on Pwr Supply board is good of course, and both smd fuses on main board are good.
    Checked the following as well on main board:
    U2
    In: 5.16V
    Out: 3.34
    Adj: 2.09
    U3
    Gnd: 2.03
    V Out: 3.27
    V In: 5.12
    U4
    V In: 3.27
    V Out: 1.25
    Adj: 0.00
    U5
    V In: 5.12
    V Out: 3.30
    Gnd: 2.06
    U6
    V In: 12.26
    V Out: 8.17
    Adj: 6.92
    U7
    V In: 5.12
    V Out: 3.34
    Adj: 2.09
    U8
    V In: 12.26
    Gnd: 0.00
    V Out: 5.05
    Power Button :0.0V
    Any further guidance/suggestions on further testing procedures would be greatly appreciated.
    Thanks!
    Re: Vizio SV420M Yellow Logo and That's All She Wrote!
    Can we see the pictures of the whole backside of the TV showing all the boards?
    Also the pictures of the button board and also clarify the "Power Button :0.0V"
    Notes from Shopjimmy regarding to the EEPROM:
    IMPORTANT:
    These main boards can have multiple failures, in addition to the EEPROM.
    If EEPROM replacement does not repair your board, there are likely additional problems.
    Symptoms EEPROM replacement CAN fix:
    - Display is frozen on VIZIO logo screen*
    - TV won't power on with remote/buttons when plugged-in (VIZIO is lit in orange, but won't turn to white)
    - TV turns on when first plugged-in, but it won't turn back on after 30 minutes of being off
    - TV shuts off and goes back to standby mode (orange VIZIO lit) after you turn it on
    Symptoms EEPROM replacement CAN NOT Fix:
    - TV turns on but has NO backlight
    - TV turns on AND backlights are on, but has no video display at all
    - HDMI issues
    - Audio issues
      • 12322
      • U.S.
      Try cooling or heating that eeprom with a hairdryer, see if tv starts up if only for a while.
      • KookieProfessor
        • May 2020
        • 13
        Thanks Guys!
        Couple of things:
        1) This is the exact fault, per the Shopjimmy notes:
        "TV won't power on with remote/buttons when plugged-in (VIZIO is lit in orange, but won't turn to white)"
        2) I rechecked the On/Off switch (the top button of the row of buttons on the right side of the main logic board as viewed from the back of the TV), and got 2.39V at the top hot pin, and 2.31V at the bottom pin when pressing the button, 0.0V off the button. This was while having the jumper in place from 5VSB to the PS_ON pin with the black wire from PS_ON pulled from the Logic board connector.
        I've also attached some pics, and will try heating/cooling the EEPROM, hopefully later today.
        As far as I understand, the voltage checks I did on all the components previously mentioned prove all those things out, correct?
        • R_J
          • 9627
          When you freeze the eeprom the tv must be unplugged from ac.
          Unplug the tv, freeze the eeprom ic, then wait a few seconds for the ic to freeze, Then plug the tv in and try turning on. You may need to try this more than once.
            • 12322
            • U.S.
            OR pop the board in the freezer for 30 minutes.
            • KookieProfessor
              • May 2020
              • 13
              I will try the freezer trick a bit later today, thanks!
              In the meantime, I did some more homework, so to speak.
              I initially missed it, but U9 measures:
              In: 3.3v
              Out: 1.8v
              Gnd: 0.55
              so that looks good, correct?
              Also, I've attached a pic of all the readings from the Pwr Supply connectors.
              I'm not sure I understand the CN202 connections, which thus far all stay at 0v. I'm thinking that based upon CN201 supplying PS_ON to the main board, it should then return an Inverter_On signal to CN202, correct?
              Not sure about these pins on CN202:
              ACD?
              DCR?
              Thanks again for all the great insight! I'm learning!
              • R_J
                • 9627
                The pins on CN202 control the backlight, ON/OFF_INVERTER turns the backlight on and off. DIM controls the brightness of the backlight. LAMP_STATUS tells the main board if the backlight is on or off. The other pins like VBRA,ACD,DCR are not used on this model.
                CN201 does not SUPPLY PS_ON to the main board, it is the control line FROM the main board to turn the power supply ON
                • KookieProfessor
                  • May 2020
                  • 13
                  R_J,
                  Thanks for mentioning that. I did understand it that way, but got turned around when I wrote the question.
                  So to clarify further,
                  • the 5.1VSB from the Pwr Supply board is supplied to the Main board, and
                  • once the PS_ON signal is sent back to the Pwr Supply board from the Main Board (by activating the On/Off switch or the remote),
                  • this is the input to the Pwr Supply board to wake up and produce the 12V output, which then is also sent to the Main board, correct?
                  I suspect that the Mainboard will then signal the Pwr Supply to turn on the backlight by sending a signal to ON/OFF_Inverter, correct?
                  To prove out the backlight, can I jump 5VSB to the ON/OFF Inverter pin at CN202, through the 1K resistor like I did to get 12V out at CN201?
                    • 12322
                    • U.S.
                    Make sure the cable from powerboard to mainboard is unhooked, when you try it you will need your first jumper in place then your on/off inverter to 5vsb probably also need one from dim to 5vsb, so 3 resistors.
                    • KookieProfessor
                      • May 2020
                      • 13
                      I threw the main board in the freezer for a few hours, and no change. .......
                      • KookieProfessor
                        • May 2020
                        • 13
                        nomoresonys,
                        Unhook both cables (CN201 & CN202) from the Pwr Supply board to the mainboard?
                          • 12322
                          • U.S.
                          Originally posted by KookieProfessor
                          nomoresonys,
                          Yes unhook both, you are self testing the powerboard and backlights.
                          • KookieProfessor
                            • May 2020
                            • 13
                            nomoresonys,
                            The picture I uploaded at 11:25am shows those measurements at the power supply board connectors.
                            • KookieProfessor
                              • May 2020
                              • 13
                              Sorry, make that 1:25pm
                                • 12322
                                • U.S.
                                Right, the test in post #10 will supply the 5v to inverter on/off to see if the backlights come on and stay on, may need a resistor jumper on dim to 5vsb too.
                                • KookieProfessor
                                  • May 2020
                                  • 13
                                  nomoresonys, R_L, budm,
                                  So jumping 5VSB through a 1K resistor to the ON/OFF Inverter pin in addition to the PS_ON pin lit the backlight up just fine. I did have the harness from the Power Supply board disconnected from the Mainboard, so I assume that's why the orange Vizio Logo was not on. (Previously just plugging in the set illuminates it orange indicating 5VSB is good.)
                                  At this point, knowing that the backlights work and both the 5VSB and the 12V signals from the Pwr Supply board are there, can I assume the Pwr Supply is good? (Should I load the 12 output to make sure it doesn't crash, or does verifying the backlight prove out the 12V rail is good, in and of itself?)
                                  I'm thinking that with all the previous measurements made on the main board regulators, that I can be pretty sure now that it is the U14 EEPROM?
                                  Is this a good assumption, or is there more I can do to rule anything else out?
                                  Thanks Again!
                                    Power supply board is fine, try new EEPROM, just make sure to get the right one for your main board.
                                    • KookieProfessor
                                      • May 2020
                                      • 13
                                      Awesome! Will order one up and report back once it's installed. ........
                                      • KookieProfessor
                                        • May 2020
                                        • 13
                                        Well,
                                        I got the EEPROM from ShopJimmy, and finally installed it tonight .......... and no difference. I'm bummed. Any suggestions?
                                        Seeing as though the backlight worked when I forced it on with a resistor from 5VSB, I'm guessing it's the main processor chip on the mainboard, but that's just a guess.
                                        Not knowing enough about proper diagnostics, would that make sense with all the readings I took of the regulators on the mainboard?
                                        Anyone have a mainboard available, if that's the next logical step?
                                        • Bob1394
                                          Vizio M65-C1 | Logo appears for 10 seconds then off
                                          by Bob1394
                                          I have used the search, and am stumped.
                                          My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                          I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                          https://www.badcaps.net/forum/showthread.php?t=81088
                                          https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                          Observations
                                          1) [Interaction] Power turned on via TV button (or remote)...
                                          02-08-2023, 01:03 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
