Tv Grundig Vision 2 22-2920 turn off after 2 secs
  • stomanata
    • Apr 2016
    • 82
    • Bulgaria
    #61
    Re: Tv Grundig Vision 2 22-2920 turn off after 2 secs
    No luck...
    I connect VCC and GND over FAN7314.
    Also ENABLE of driver over pin #3 of FAN.
    ADJ of driver first i try over pin #8, but it start too bright
    and led strip start to blink.
    Then i try over pin #7 of FAN, but it is the same.
    Now i wonder if i connect resistor in series of ADJ.
    It must be PWM there...
    Other solutions?
      https://www.badcaps.net/forum/attach...9&d=1587475013
      Can I see good clear focused pictures of the whole top and bottom side of the board?
      What you need to do is to disconnect the power (12V) feeding the inverter section so the inverter section will not be running so no need to deal with any protection section for the CCFL, the lines feeding the ON/OFF and Dim control signals.
      BTW, what is the spec of the LED driver ADJ signal requirement? AnaloG? PWM?
      • stomanata
        • Apr 2016
        • 82
        • Bulgaria
        #63
        This must be better. On my pc i can zoom enought to see all details.
        For inverter i remove both mosfets that drive HV transformer and use
        560 ohm resistor to ignore OLP.
        Inverter is based on DF6113. In datasheet is labeled to use series resistor for DIM...
        • stomanata
          • Apr 2016
          • 82
          • Bulgaria
          #64
          Even with 100k pot in series is the same.
          BTW it start may be normal and after 4-5-6 secs it
          start to blink.
          What about if i remove FAN7314 chip?
          • nezocas
            • Oct 2015
            • 27
            • Alcanena
            #65
            I know this is an old thread.... but I have the same set, with same PSU.
            Initially I had no backligth....just sound and image (visible with a powerfull torch).
            I went strait to the transformer, one of the secondary winding was 1.8K the other was correct 1.3K.
            Changed it with same part number, and still no backligth.
            To avoid dissassembly the LCD to check the lamps, I plugged 4 laptop screens (old ones with lamp) to the tv. Only 2 will ligth up for 2 seconds.
            Placed the 560homs resistor and backligth will stay ON on the same 2 lcds. The other ones dont even blink (S2009 and S2008).
            Allready changed the FAN7314 but NO changes.
            I have also checked the four 3Kv caps but all OK.
            Were should I check futher?
            Best regards
            Nezocas
            • nezocas
              • Oct 2015
              • 27
              • Alcanena
              #66
              Best regards
              Nezocas
              SOLVED,
              Received bad transformer, and it had good readings in the primary and secondary sides.
              Replaced transformer from a scrap board. It was also a blue transformer from 17IPS15-4 power supply with diferent part number TMS93700CT.
              Regards
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • pajdek
                Lenovo Y700-17ISK turn on and off
                by pajdek
                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                09-20-2023, 02:49 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
              • robante15
                Acer Aspire 4520 won't turn on after reboot
                by robante15
                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                If I remove the...
                04-06-2024, 06:50 PM
              • masoksian
                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                by masoksian
                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                The system does not turn on, there is no post.
                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                The problem continues in the same way.
                I tried to turn on the Fn key, nothing came to the screen....
                02-15-2025, 12:08 PM
