LG 42LV355T Blue screen No picture
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 42LV355T Blue screen No picture
    It did the update smoothly but still no change.
    • nomoresonys
      • 12331
      • U.S.
      #42
      On some tvs if you st the headphone setting to audio out, you can get sound from both headphones and speakers, not sure if that tv does tho.
      • notallbad
        • Oct 2012
        • 1190
        unfortunately nothing like that in the user menu
        • diif
          • Feb 2014
          • 6978
          • England
          #44
          Replace the amplifier IC. You'll need to use hot air as the bottom is a large soldered ground pad.
          • notallbad
            • Oct 2012
            • 1190
            Is there any way of checking its def the amp ic before replacing as I wanted to avoid doing that if possible.
            I dont think its getting warm, will check with thermal gun.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #46
              i was watching this video earlier not a official fix but seems too work
              https://www.youtube.com/watch?v=wgn8nN9HlrQ
              • nomoresonys
                • 12331
                • U.S.
                #47
                Nice solution.
                • nomoresonys
                  • 12331
                  • U.S.
                  #48
                  A couple comments from the video: "Neko iz Mase
                  2 weeks ago
                  Block condensators make problems around original IC and becouse of that you dont have sound on original IC : MrReeceyburger123
                  6 months ago
                  And plus you could of just repaired the Mainboard by changing 4 ceramic caps lolllll
                  • notallbad
                    • Oct 2012
                    • 1190
                    Update: attempted replacing the ntp-7100 and still didn't work, possibly my soldering. Oh well, worth a go! Perhaps more practise needed.
                    Anyway picked up a cheap replacement board, £14. For that price I thought it easier and quicker than further troubleshooting which may have led to a bad uc ic anyway.
                    p.s. that was a damn good price for one of those boards, all others are extortionately high!
                    All tested and working.
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • jean luc ferre
                      acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                      by jean luc ferre
                      on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                      i tried the hard reset, cmos reset, changing the ram without results.
                      in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                      The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                      but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                      11-22-2025, 03:54 PM
                    • alltvrepairs
                      Lg TCon test pins for screen test
                      by alltvrepairs
                      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                      Appreciate your help....
                      06-13-2025, 06:33 AM
