SAMSUNG UE40JU6000K thin vertical line.
  • vikivng
    • Feb 2019
    • 216
    Hi guys,
    hope everyone is coping with this crisis.
    Has anyone ever seen this particular issue shown n the photo.?
    Very thin vertical yellow line just off centre of the screen.
    I have disconnected both lvds cables and cleaned and reseated,,no change.
    What could cause this. Could the panel be cracked internally?
    ps. is there an issue with iploading photos.? Cannot seem to.
    Re: SAMSUNG UE40JU6000K thin vertical line.
    Did you use attachment function in the Go Advanced to attach the picture?
    • vikivng
      • Feb 2019
      • 216
      Hi Bud,
      I cannot find this Go Advanced option anywhere.
      I click on manage attachments,choose the file and click upload..The page then turns white and does nothing.
      • CapLeaker
        Leaking Member
        • 8147
        Click on "Post Reply", scroll down, there is "Manage Attachments".
        • vikivng
          • Feb 2019
          • 216
          Ok
          the pic was too big.
          Although it was jpg and only 4.40mb
          Anyway I have managed to upload.
          Can someone tell me if this is actually a damaged screen or is fixable.?
          • vikivng
            • Feb 2019
            • 216
            The line stops approx 2 inches from the bottom of the screen.thnx
            • brucetv
              • May 2015
              • 281
              • united states
              Possible tab bond issue or a bad cap in the lower drive boards attached to the panel. You'll have to remove the back and the driver board covers on the bottom and inspect the ribbon cables for corrosion. You'll need a multi meter to check the caps but some will be in parallel so you'll need to remove them one by one to find a short. These are small caps so you will need a good degree of soldering experience.
                • 12181
                • U.S.
                Did you try cleaning the ribbon cables going from tcon to panel? Some use a pencil eraser, gently they can be delicate, might be a loose tab bond as mentioned.
                  • 12181
                  • U.S.
                  Some have had success with the "cutoff tape" method with vertical lines.
                    • 12181
                    • U.S.
                    Example there but on horizontal line issue: https://www.youtube.com/watch?v=7TT8QYeN1s8
                    • vikivng
                      • Feb 2019
                      • 216
                      Hi guys,,
                      many thanks for the replies and suggestions.
                      I will try them.
                      Hope everyone is ok in this crazy crisis.
                        • 12181
                        • U.S.
                        Any followup on this one??
                        • cubytus
                          Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                          by cubytus
                          Hi to all,
                          I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                          I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                          Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                          01-10-2024, 01:26 AM
                        • mrsith
                          Samsung UE58TU7100K - no picture, vertical line
                          by mrsith
                          Hi.
                          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
                          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
                          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
                          02-07-2023, 11:18 AM
                          09-07-2024, 05:50 AM
                          HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                          This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                          09-06-2024, 06:50 AM
                        • Raulnn
                          Hisense LTDN40D36EU thin black vertical line
                          by Raulnn
                          good evening!!! I have this tv with a line that occupies 1 or 2 pixels in width. it has a solution? Can you do a test to find out if it's a panel or something else? Having the tcon integrated into the panel makes everything difficult. I have pushed on the flex attached to the panel, on both sides and there are no changes. I don't know what else I can do... the integrated ones that go on the flex get hot, but without burning yourself if you put your finger on it. to see if someone can help me. I attached a detail photo of the line. Thanks in advance...
                          12-30-2022, 05:45 PM
