LN46A530 Backlights Flash
  • neilc6
    • Nov 2015
    • 1550
    TV turns on and off but backlights flash on for a few seconds before going out.
    I suspect bad CCFL bulbs and would like to force the backlights on so I can confirm the main board and tcon are good before I salvage the boards and sell them. I did this previously on a LN40B500 following this thread https://www.badcaps.net/forum/showthread.php?t=29580
    Don't see an OVP pin from the inverter. Controller IC is different LX1692BIDW PS is BN44-00202A
    The 8 pin connector from the inverter board measures.
    VCC 12V
    FB 0V
    FB 0v
    GND
    LD 12V
    LD 12V
    so the 12V regulator is good from this thread https://www.badcaps.net/forum/showthread.php?t=55179
    Caps on the PS are original and not bulged.
    Re: LN46A530 Backlights Flash
    LD will go below 10V when backlights error occur.
    LD (Lamp Detect) 12V is normal so monitor this pin when TV is turned on and see if it drops down or not.
    FB is lamp current feedback, it is high frequency AC (your AC Volt meter does not have the bandwidth to read it) and it will be in mACV range.
    Pictures of the whole backside of the TV needed. It looks like your TV uses Balancer board.
    BN44-00202A: https://www.shopjimmy.com/samsung-bn...wer-supply.htm
    https://www.youtube.com/watch?v=oE6K4xBVweA
    https://www.youtube.com/watch?v=Dh01ZepjDp0
      • 12206
      • U.S.
      That might help: https://www.youtube.com/watch?v=Dh01ZepjDp0
      • neilc6
        • Nov 2015
        • 1550
        Monitoring both LD signals, they do not drop when the backlights are on. Also checked INV ON/OFF from the main board. It goes high and stays high (5V).
        Other signals on the connector from the main board are PWM DIM and DET_5V.
        • CapLeaker
          Leaking Member
          • 8208
          measure the resistance on the secondary side on each transformer on the inverter board and compare them to each other.
          • neilc6
            • Nov 2015
            • 1550
            Secondary transformer readings: 386, 389, 393, 391, 395, 389, 393, 390, 389, 378, 384, 388, 393, 380, 387, 406, 390, 391, 384, 392, 390, 388, 393, 385
            One a little high (406) and one a little low (378)
              The invererter transformers (2) are on the power supply/inverter boards, then you have TWO Balancer boards that distribute the high Voltage to each lamps via the small transformers on each Balancer board..
              Also, the lamps are driven in push-pill mode,
              SONY Training manual, SONY/SAMSUNG use the same topology since they were working together in the past. Page 49 is to topology used in your TV.
              Did you watch the videos? Also read the trouble shooting section.
              The LD dropping Voltage may be too fast and too short for your meter to detect.
              • CapLeaker
                Leaking Member
                • 8208
                Eek. Thats one of them with a master / slave boards driven by 2 transformers on the PSU. Well, more complicated... however same thing applies to the 2 transformers that supply the juice to the 2 balancer boards. Measure the secondary on those and look for evidence that one transformer runs hotter than the other(s). Check all transformers and the little blue capacitor for cracked solder joints.
                  BTW, verify that the PFC boosted Voltage did not drop out.
                  • neilc6
                    • Nov 2015
                    • 1550
                    I probed the Enable pin on the controller IC. It is high and stays high when the backlights go out. PFC voltage is 390VDC and stable with the backlights off. Transformer solder joints look good. Secondary winding resistance on the two transformers are 20 ohms each. I disconnected a random tube and it has the same flash with one tube disconnected.
                      It will only take one bad lamp (or disconnected lamp or lamp that will not go into conduction after firing Voltage is applied) to cause the backlights to go into shutdown, you need to test the test point on the Balance board as shown in the video to see if any one of the lamp causes the error output signal as shown in norcal video.
                      • neilc6
                        • Nov 2015
                        • 1550
                        I removed the panel and all the bulbs are good though as bulbs age, they can draw more current causing an overcurrent situation. I don't see test points on the balancer board in the video.
                        • CapLeaker
                          Leaking Member
                          • 8208
                          do theses ccfls have a pinkish tint?
                          • neilc6
                            • Nov 2015
                            • 1550
                            No pinkish tint. I'm going to go through the power supply schematic and controller datasheet.
                            • CapLeaker
                              Leaking Member
                              • 8208
                              i am still thinking it's one of them transformers. There is always a transformer pair per ccfl. Usually they can't be far apart. the pair reading 387 on one and 406 for the other would be my suspect.
                              • x_orange90_x
                                by x_orange90_x
                                01-29-2025, 09:24 PM
                              • ekozeko333
                                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                by ekozeko333
                                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                🔥 The Problem Started After Suspected ESD/PD Fault
                                I experienced a power issue or ESD event through a USB-C charger
                                After that, the NX20P5090 power switch was visibly burned and was replaced
                                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                🧠 What I’ve Done So Far
                                Flashed...
                                06-21-2025, 02:48 AM
                              • corrize
                                Nikon D800 camera - flash don’t work and capacitor don’t charge
                                by corrize
                                Hello, I'm stuck in troubleshooting…
                                The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                10-01-2022, 10:02 AM
                              • lostone
                                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                by lostone
                                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                05-19-2024, 11:40 AM
                              • JunkmanJimbo
                                RCA led50b45rq tv backlights flash then shuts down
                                by JunkmanJimbo
                                First of all I looked at the other posts on this model but didn't really see a solution. This is where I am so far. I have replaced the power supply and the mainboard (both used). I'm still having the same problem. The tv standby light comes on, I push the power button, the backlights flash and the tv shuts down. The tv can't be turned off unless I unplug and reconnect the power cord. I have tested the backlight strips with an LED tester and all of them are working fine. I can unplug the led connector from the power supply and the tv turns off and on like it should. Also with it unplugged, and...
                                05-23-2022, 04:07 PM
