Samsung LN40B630N1FXZA, brief backlight, power up chime, then nothing.
  • johnboy1313
    • Nov 2012
    • 1959
    I recently picked this set up. When plugged in, the LED on the front illuminates, the startup chime is heard, the backlights come on for ~1 sec, then it all cuts off. I don't see a picture with a flashlight. I haven't connected a source to see if there is sound. One of the troubleshooting steps is to "Check the backlight on, when 30p cable unconnected". With the cable disconnected, the backlight still just briefly comes on before cutting off again. My problem is I don't know if the light is supposed to come on and stay on with the cable disconnected or just flash like it does, so I can't answer YES or NO to the attached troubleshooting chart.
    Re: Samsung LN40B630N1FXZA, brief backlight, power up chime, then nothing.
    The light should stay on.
    See my video. You may have same issue (I fixed the LE40B652), though my backlight DID stay on when the connector was unplugged, and it turned out to have a bad t-con board.
    Common fault on this TV power supply is shorted diode in PFC section causing similar symptoms (no backlight or brief backlight) due to low PFC voltage.
    https://www.youtube.com/watch?v=7Xz-iSaEAb8
    The smart features on this TV sucked.
    • johnboy1313
      • Nov 2012
      • 1959
      Thanks for the quick response Tom. The chime doesn't seem to cut short. I remembered your video and have already attempted powering up with the t-con disconnected. It still does the same thing.
      • johnboy1313
        • Nov 2012
        • 1959
        Pictures coming soon.
          Check the voltage across one of the large 400V capacitors, both in standby and while powered on (try measuring as power is turned on, see if you get a brief spike or if it stays at one voltage.)
          • johnboy1313
            • Nov 2012
            • 1959
            When plugged in, I have 166.5V at the big caps. At power on, it went up to 390V and held steady. I checked the voltages on the IP board and everything seems correct. At power on, PWR-ON/OFF rose to .9V and held steady. INV_ON/OFF rose to 4.9V and held steady. 5.3V was present as was 13V. I then decided to connect a source and to my surprise, there is sound. At this point, I suspect either the IP board or maybe a bad CCFL.
            Short of opening the panel and seeing for myself, is there a way to confirm that the inverter section of the IP board is bad?
            IP Board
            https://www.shopjimmy.com/samsung-bn...it-rebuild.htm
            • johnboy1313
              • Nov 2012
              • 1959
              IP board schematic
              http://www.tgohome.com/ServiceManual...&Search=Submit
                Schematic:
                You will need to solder wires to the point OVP. OVP is found on pin 10 of UI801 (solder side, secondary; though any component connected to pin 10 should be fine.) It should be low normally.
                OVP (over voltage) firing indicates a loose or failed bulb. I don't think it will fire if a transformer is open circuit/high resistance.
                DET on pin 5 should also be checked, but I'm not sure what that should measure. I think it's some kind of feedback for regulating the high voltage.
                Be careful when removing inverter/power board as damage to tubes is possible.
                You can place a solder bridge across CI805/CI806. This disables shutdown timer, so set should start and run continuously. You can then carefully inspect panel on test pattern for bad bulb. Don't run for too long in this condition and shut down TV if burning smell/arcing sound detected.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Originally posted by tom66
                  Schematic:
                  To be clear, I'm just soldering one wire to pin 10 and one to pin 5 so that I have something to probe when the set is powered on?
                    Yes. The other end you are measuring the voltage against is chassis ground.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Pin 5 jumps to 6.6V when the lights come on but drops out when they shut off.
                      Pin 10 jumps to 1.99V when the lights come on but drops out when they shut off.
                      I hear no buzzing or arcing when the lights are on.
                        Ok. Pin 10 appears to be a fault. Connect pin 10 to chassis ground. Does the backlight stay on?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          No, with pin 10 connected to ground, they flashed like they have been but there was a loud buzzing coming from the hot side of the IP board then everything cut off. I disconnected it from ground and it is back to the original fault with no buzzing.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Also, I could be wrong, but aren't CI805 and CI806 already connected at both ends?
                              Yeah, you only need to bridge one -- they're in parallel. Sorry if I wasn't clear.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                How do I pull up the test pattern on this set?
                                  The backlight needs to be on -- but you can do it from the service menu.
                                  From standby: Mute 1 8 2 Power on remote. I think it's under "CONTROL".
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Jumping CI806 got the backlight on. I need to get the base on and have a look at the screen. I can tell there's a picture but I can't see enough to tell if I've got a bulb out.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Looks like there's at least one bulb out, probably more.
                                        Looks like only one to me -- though could also be a transformer out.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
