RCA led50b45rq tv backlights flash then shuts down
  • JunkmanJimbo
    • Mar 2017
    • 192
    First of all I looked at the other posts on this model but didn't really see a solution. This is where I am so far. I have replaced the power supply and the mainboard (both used). I'm still having the same problem. The tv standby light comes on, I push the power button, the backlights flash and the tv shuts down. The tv can't be turned off unless I unplug and reconnect the power cord. I have tested the backlight strips with an LED tester and all of them are working fine. I can unplug the led connector from the power supply and the tv turns off and on like it should. Also with it unplugged, and doing the flashlight test, I can see an image in the screen. I suspect one the replacement boards is defective but I don't know which one, the power supply or the mainboard. I apologize for the long post. I look forward to any help you can offer. Thanks!
  • neilc6
    • Nov 2015
    • 1550
    Re: RCA led50b45rq tv backlights flash then shuts down
    Flash of backlights is a symptom of bad backlights. Your LED tester only puts out 10-20 mA and the TV can run at several hundred mA. I find it not worth it to repair RCA models since you can't find new strips for them, they have low resale value and you can't lower the backlight level in the menu (possibly in the service menu but not always). Failing LEDs may have fluctuating forward voltages (tripping the protection shutdown) and may also be slow to turn on.
    • JunkmanJimbo
      • Mar 2017
      • 192
      Thanks neilc6. I was afraid of that. So, even though the backlights work perfectly fine on high and low with a led tester they can still be bad?
      • JunkmanJimbo
        • Mar 2017
        • 192
        I forgot to mention. When I first got the tv, and turned it on, it played for quite awhile until I turned it off and unplugged it. Then it started doing this crazy stuff.
        • nomoresonys
          • 12181
          • U.S.
          probably backlight issue, try with tv unplugged from power, unhook cable from powerboard to mainboard, leave it unhooked, plug power cable into powerboard, plug cord into outlet, see if backlighs come on or if there's any difference, it's a simple test, may or may not work. And YES I already know it depends on if the board has pull-up resistors or not.
          • neilc6
            • Nov 2015
            • 1550
            I've done full LED replacements on TVs with bad backlight symptoms and tested the strips afterwards and they all lit up fine. You can video the backlight flash and go frame by frame to isolate the bad LED but I suspect one or two have fluctuating voltages. I rarely do individual replacements any more since all the LEDs have wear and are likely to fail in the future. If you can get the TV to come on, you can try to lower the backlight in the service menu menu-1-1-4-7 or source-2-5-8-0.
            • JunkmanJimbo
              • Mar 2017
              • 192
              Thanks nomoresonys. I'll try that tomorrow and let you know.
              • JunkmanJimbo
                • Mar 2017
                • 192
                Thanks neilc6. Sounds like another tv going to the land field. Thanks for your help. I really appreciate it.
                • neilc6
                  • Nov 2015
                  • 1550
                  Bigdog8882 has a youtube video on that model - https://www.youtube.com/watch?v=DtK1JhIqChw TLDW - he replaces all the backlights with another set
                  • JunkmanJimbo
                    • Mar 2017
                    • 192
                    nomoresonys, I tried your suggestion but nothing happened. No backlights came on.
                    • nomoresonys
                      • 12181
                      • U.S.
                      Probably time to carefully strip it down to inspect backlights. You can if you like, replace individual backlights, possibly with some from a previous salvage if they match, more are likely to fail as stated but it's a method that will only likely cost you time and not money. I would just give away or keep a tv that I repaired in this manner, because of that fact.
                      • JunkmanJimbo
                        • Mar 2017
                        • 192
                        Thank you, nomoresonys, and the rest of you guys that helped me.
                        I did find and replaced the bad led this morning. I turned on tv and the backlights stayed on. But, unfortunately while working on the tv yesterday, I cracked the screen and didn't realize it. So, this one is going to the land field. Thanks again for all your help.
                        • nomoresonys
                          • 12181
                          • U.S.
                          oh crap, hate when that happens, they are way too flimsy, seems like they could make them more durable but they probably don't want to spend a few more pennies during manufacture.
                          • ekozeko333
                            by ekozeko333
                            🧠 What I’ve Done So Far
                            Flashed...
                            06-21-2025, 02:48 AM
                          • corrize
                            Nikon D800 camera - flash don’t work and capacitor don’t charge
                            by corrize
                            Hello, I'm stuck in troubleshooting…
                            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                            10-01-2022, 10:02 AM
                          • abajor
                            Canon VIXIA HF S10 A read data from inernal flash memory.
                            by abajor
                            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                            I think my best shot is to figure out a way to read the internal flash memory outside...
                            07-20-2024, 12:04 AM
                          • Ihandyrepair
                            4 red flash led 65X950G boot Sony and android logo but then black
                            by Ihandyrepair
                            HI guys
                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                            here is the issue
                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                            but then I get black screen and 4 red flash light at the front LED
                            but I get 3 led flash on the LED driver board.
                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                            so I tried...
                            07-11-2024, 01:45 AM
                          • abhorsen
                            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                            by abhorsen
                            Hey guys,
                            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                            07-06-2023, 10:22 AM
