Hello everyone!
Here's the run-down on this TV. Pictures posted below.
* LG TV model# 50UH5530
* Symptoms: Turned off by itself and appeared to be unresponsive.
* After power reset TV tries to turn on with backlight flash
* Occasionally will turn on, boot and show picture/sound.
* TV only turns on when 13V pin reads 10.2V stable in stand-by, with main board connector attached or detached
* When power button is pressed and stable 10.2V is present 13V pin comes up to 13.2V stable
* When it shuts off by itself 13V pin shows unstable voltage from 8-12V
* The problem occurs on 3 separate power supplies and 2 separate main boards
* Backlights are less than a year old, ShopJimmy.com replacements
* Backlight settings have been at 66 (on a scale of 100) since new backlights installed.
Ordinarily I see a backlight flash on these and expect the backlights to be bad....but they're not even a year old. The TV actually worked for a day-and-a-half for me, came on, picture, sound, but eventually faulted and went back to the symptoms above.
So the band is stumped here.....does anyone have any suggestions or ideas?
