Samsung UN46H5203 backlight issue - stumped
This topic has been answered.
  • soler88
    • Sep 2022
    • 9
    I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
    I disconnected the main board from the PS but still no backlight.
    Looking at previous threads, nothing is jumping out at me and I'm stumped.
    Here are the voltage measurements:
    ON STATE
    CNM803 on PSU from Main
    Pin 1 A13v - 13.09v
    Pin 2 OD_UD - 3.3v
    Pin 3 A13v - 13.09v
    Pin 4 BLU_PWM - 1.6v
    Pin 5 A13v - 13.09v
    Pin 6 PWR_On/Off - 3.3v
    Pin 7 A13v - 13.09v
    Pin 8 GND - 0v
    Pin 9 GND - 0v
    Pin 10 GND - 0v
    STANDBY STATE
    Pin 1 A13v - 13.09v
    Pin 2 OD_UD - 0v
    Pin 3 A13v - 12v
    Pin 4 BLU_PWM - 0v
    Pin 5 A13v - 12v
    Pin 6 PWR_On/Off - 0.13v
    Pin 7 A13v - 12v
    Pin 8 GND - 0v
    Pin 9 GND - 0v
    Pin 10 GND - 0v
    CNL802 CONNECTOR ON PSU TO LED's
    ON STATE
    Pin 1 D1+ - 256.9v
    Pin 2 D1+ - 256.9v
    Pin 3 S1- - 202.9v
    Pin 4 S2+ - 202.8v
    Pin 5 NC - 0v
    Pin 6 S2- - 176.1v
    Pin 7 S3+ - 176.1v
    Pin 8 D1- - 256.4v
    Pin 9 D1- - 256.4v
    STANDBY STATE
    Pin 1 D1+ - 207.5v
    Pin 2 D1+ - 207.5v
    Pin 3 S1- - 153.9v
    Pin 4 S2+ - 153.9v
    Pin 5 NC - 0v
    Pin 6 S2- - 127.5v
    Pin 7 S3+ - 127.6v
    Pin 8 D1- - 207.8v
    Pin 9 D1- - 207.8v​
    I get the following voltages with the led tester on the connector:
    D+
    S1- = 59.8v
    S2+
    S2- = 29.8v
    S3+
    D- = 29.8 v
    Any help would be greatly appreciated. Thanks for reading!
  • Answer selected by soler88 at 10-17-2024, 02:44 PM.
    soler88
    • Sep 2022
    • 9
    Fixed!
    The diode (SF28) near the the backlight connector was bad. When I measured in diode mode, it was correct 0.49v one way but not OL when reversing the probes.
    Upon closer inspection, the pcb around it was darker due to heat I presume.
    Hopefully this helps someone fix theirs.
    • EazyBone
      • Jun 2023
      • 1348
      • United states
      Either the LEDs or PSU or connection to PSU likely. Take a good photo of power boards and then 2 additional zoomed in closer to the board.
      Also disconnect the main board from PSU connector and plug in the power board. See if LEDs come on
      • soler88
        • Sep 2022
        • 9
        EazyBone Thanks for the reply. Yes I tried disconnecting the main board from the PSU and the LEDs do not come on.
        Here are some pics. Let me know if you need more zoomed in ones.
        • soler88
          • Sep 2022
          • 9
          • Diah
            • Feb 2013
            • 6399
            yours measurement on BL socket make no sense...
            you need direct on D1- & D1+ same to S2 channel don't use the chassis as references
            • lotas
              • Jan 2016
              • 4661
              • Russia
              How do you measure the voltage at the output of the leds, relative to ground or something?
              It is necessary to measure between D+ and D-.
              • soler88
                • Sep 2022
                • 9
                Yes, I measured relative to chassis ground.
                On those points like you indicated, I am getting 0.54v.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4367
                  • Italy - Milan
                  I think you must re check values, A13v in standby might be 8v, it confirmed , psb bad.. besides this if before power all things up the first time, you have tested B.L. with the tester the way you told my guess you have damaged the bars, D1+/- are the only pins to the leds, instead S1/3 are a series of sensors, if them are now damaged by the bad input , the driver is hang
                  • soler88
                    • Sep 2022
                    • 9
                    Fixed!
                    • EazyBone
                      • Jun 2023
                      • 1348
                      • United states
                      Good find! I got a board in stumped on also and I can't find the culprit.. I'll recheck these myself
                        MSI Stealth 17 STUDIO A13V-022 Notebook Specification for Upgrade or Repair
                        This specification for the MSI Stealth 17 STUDIO A13V-022 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17 STUDIO A13V-022 boardview and 17 STUDIO A13V-022 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 06:31 AM
                        MSI Creator Z17HXStudio A13V Notebook Z17 HX Studio Specification for Upgrade or Repair
                        This specification for the MSI Creator Z17HXStudio A13V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z17HXStudio A13V boardview and Z17HXStudio A13V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-07-2024, 06:38 AM
                      • Harryrepair
                        MSI CYBORG 15 A13V no Display after powering on
                        by Harryrepair
                        Hello community,
                        i bought myself this nice laptop for repair training.
                        MSI Cyborg 15 A13V (Boardnumber MS-15K11)
                        It can be charged and powered on. It stays for 20 seconds without showing any picture, even no BIOS.
                        All MAIN Power rails are present, CPU with 0.8V. USB Ports with 5V.
                        Shuts down after 20 seconds.
                        RTL8111H seems warm with about 34degrees celsius.
                        Someone mentioned to check PLTRST# , but there is no schematics available.
                        Could you assist me with any hint?...
                        07-16-2025, 10:53 AM
                      • EazyBone
                        Hisense H6750G stumped on this
                        by EazyBone
                        Picked up another free one. The original owner replaced power board to try and fix them gave up gave to me
                        Problem: Red led standby light blinks once every 5 seconds repeatedly for ever.power button does nothing. Nothing turns on.
                        PSU, 12v are all 12v to main, 18v are all 16.6 stby is 2.6
                        Disconnect main and 12v is 10.5 and 18v become 14.4.
                        This is the same for BOTH psus.
                        Backlight tester turns on backlights at 105v each strand and work properly.
                        I cannot get ANY voltage to backlights on either power supply. They remain...
                        08-30-2023, 01:25 PM
                      • Harryrepair
                        MSI CYBORG A13V BN: MS-15K11 Ver.1.0 Please check my BIOS attached
                        by Harryrepair
                        Hello community,
                        I have this laptop coming up for 20 seconds without picture and switching off again.
                        Could this be a BIOS issue?
                        Sending you the original dump in attachment.
                        Thanks for any help...
                        07-18-2025, 05:27 AM
