Vintage AT Power Supplies - Selecting Capacitors
  • iMic
    • Oct 2013
    • 40
    Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
    The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon YXB series, although due to the placement of some others it's difficult to tell if all of them are.
    Code:
    10v 1000uF x3
    16v 47uF x2
    16v 470uF x2
    25v 100uF x1
    50v 22uF x1
    Mains: "Omats K112" 400v 100uF x1
    The 486 uses an ASTEC power supply, with caps that aren't visibly leaking, but while I have an order open and the power supply disassembled for cleaning, it's a good time to get some to have on hand. This unit uses a mix of Chemi-con capacitors -
    Code:
    Chemicon LXF
    6.3v 1500uF x1
    6.3v 2200uF x1
    10v 270uF x1
    16v 2200uF x2
    Chemicon SME
    25v 47uF x2
    Mains: Nichicon CE 200v 470uF x2
    For the 386's I'm leaning toward the Panasonic FC series. That's based on another post I read around here a while back that suggested they would be a fitting replacement for the YXB series, they're reasonably cost-effective, and they seem to be more readily available - more so than the other brands - from the various online electronic suppliers that operate in Australia. Other brands are available of course, but either not a complete range (so some mixing and matching is required) or in lower quantities / back-ordered to a future date.
    As for the Chemicon LXF and SME series, I'm not sure what their ideal equivalents are.
    These are relatively light-duty supplies, running infrequently and in not particularly hot environments (except maybe an Australian summer sometimes). I'd still opt for 105C rated components as that seems to be what was specified from factory, but other than that, I don't suspect they need anything too fancy or exotic.
    And if anyone wants to know why I don't just replace them with a more modern power supply - they're AT by spec, but far from the standard AT form factor.
    Cheers,
    Mic.
    master hoarder
    • May 2008
    • 12176
    Re: Vintage AT Power Supplies - Selecting Capacitors
    Just curious, are the Rubycon YXB caps leaking electrolyte from the bottom of their bungs?
    I know Nichicon PR and PL in old PSUs do have this problem from time to time (especially the PR series.) United Chemicon LXF might also be affected, but not as badly. Basically, all of the manufacturers that used Quaternary ammonium salts in their electrolyte are susceptible to leakage from their bungs... though some more than others, it seems.
    UCC SME is an old discontinued series, I believe. Modern equivalent is SMG seires. You can also use Nichicon VR or Rubycon PX. Panasonic FC is entry-level low ESR. However, those will work fine for the SME's too.
    Like you said, these PSU don't need anything too fancy. So anything like Panasonic FC will work fine.
    As for the input high-voltage caps, just check them and feel free to leave them as-is, since they rarely fail, even if very old. But if you do replace them, you can go with either 105C or 85C general purpose series. Save the old ones too, just in case you need them for a future project / repair. They should still be good for re-use.
    • iMic
      • Oct 2013
      • 40
      They are - I haven't inspected mine yet, but these machines came in a lot of 7, five of which went off to different owners. Of the other 5, all of them had considerable leakage from the bottom of the caps, so I fully expect to see the same on these two.
      I'll have a look at the Nichicon and Rubycon equivalents too. I don't mind spending a bit extra to get a better cap, as long as I can actually source them and they're correct for this application. Would also like to stick to one or two manufacturer series per supply so I don't end up with Rubycon, one Nichicon because it wasn't available in the Ruby, one Panasonic, etc throughout the unit.
      The mains capacitors I figured would be fine. All except one unit currently powers up (although I don't run them for long, a half minute at most) so the AC side is working. Given that replacing those caps would add a substantial overhead to the cost of each repair, I'll leave those alone unless I have a solid reason to replace them.
        master hoarder
        • May 2008
        • 12176
        Ah OK, thank you for confirming.
        I do have one old-ish (mid 90's) AT PSU with those and Lelon caps. So will keep in mind to check them out before assembling back that machine when I get to it.
        The Nichicon equivalent to Panasonic FC and Rubycon YXB are the PW series. PS, PM, and PJ series should also be relatively close. And I think YXJ series from Rubycon are the nowadays modern replacements (more or less) for their YXB series. YXF also, but they are only available for select few sizes.
        With UCC, you can still get LXZ series, which will cover OK for the LXF series. KYB might be getting a little on the low side of ESR, but should also be OK.
        I tend not to "discriminate" when it comes to recapping PSUs and usually mix and match whatever are the cheapest (quality) caps at the time. So more often than not, my recapped PSUs have a mix of various Japanese brands in them.
        Indeed.
        Large caps are expensive, so I leave them alone.
        For modern PSUs with APFC circuits, though, they are always worth checking, because APFC tends to stress them extra and sometimes kill even good Japanese brands. Of course, when it comes to AT PSUs, those haven't even heard of such circuit, so nothing to worry about.
        • PeteS in CA
          • Aug 2005
          • 3586
          • USA, Unsure of Planet
          For output caps, older series that are still available pose less risk of stability issues.
          From Nichicon, the PS and PM series are RoHS-compliant versions of the 90s vintage PR and PL series, with basically identical specs. The PJ series is a little newer but probably won't cause problems, and the PW series a bit newer still. The PA series night be risky.
          From Nippon Chemicon, the LXV series is approximately equivalent to Nichicon's PJ series, and the LXZ series is approximately equivalent to the PW series. The LXY series is a somewhat limited intermediate between LXV and LXZ.
          Panasonic's FC series is approximately equivalent to the PW and LXZ series.
          PeteS in CA
          • iMic
            • Oct 2013
            • 40
            Cheers for the advice. I opened the second 386 power supply and saw it used Panasonic caps across the board, so figured based on looking at the two that Panasonic FC's were probably a safe bet.
            The ASTEC I'd planned to go a mix of UCC and Nichicon, but none of the recommended equivalents were available - different specs were either "on order" or "end of life" at Element14 and Mouser. Given the UCC LXZ series would cover for the LXF, Panasonic FC is approximately equivalent to the LXZ, and the FCs would also be a suitable substitute for the SME series - I just went with the Panasonics across the board for this supply too.
            It'll probably be a couple of weeks before the order comes in, but when they do, I'll get them fitted and see how it goes.
            • SolomonMan
              Vintage BK Precision 1403 Oscilloscope....
              by SolomonMan
              All,
              Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
              Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
              I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
              12-03-2023, 10:39 PM
            • DrDos
              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
              by DrDos
              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
              08-08-2025, 03:16 AM
            • SolomonMan
              HP Docking Stations Power Supplies...?
              by SolomonMan
              All,
              I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
              Anyways these docks are HP Model 5TW10UT#ABA.
              Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
              I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
              h...
              05-09-2023, 08:04 AM
            • edugimeno
              Diagnose real-vintage Strong-Hammer arcade machine
              by edugimeno
              Hi there!
              My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
              I am attaching several pictures of the machine.
              It basically has 2 sides, left side has
              • 2 x 220->12+24v transformers
              • 2 relays (1 moves motor UP, other moves motor DOWN)
              • IGF and breakers for safety
              Right side is shown on pictures. It has 3 boards ( top-down)
              • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
              02-29-2024, 11:05 AM
            • tony359
              Acer V58 Vintage Socket 7 Motherboard
              by tony359
              I'm trying to troubleshoot a vintage Acer V58 motherboard, ALI chipset 1541/1543. Symptoms are: it's very dead.
              The CPU in question, a plain Pentium 200, it works on a different board. I have checked the voltages, the clock and the reset lines. All checks out.
              However I have ZERO activity on the CPU data/address lines. It's like the CPU is told NOT to start but I cannot figure out how. A post-card shows "--" and there is of course no activity on the BIOS address/data lines.
              I checked the HLDA (Hold Acknowledge) line which could indicate...
              02-27-2024, 07:07 AM
