The Overseas Only Kenwood Model KR 790
  • Mark R
    • Oct 2023
    • 92
    Ok, I took some shots of the Ebay switch which is the same as the one in the unit. Except the shaft is different. Butt he shafts are interchangeable. Also some shots of the Reverb Board. I'm going to swap out hose two diodes now. Just another shot in the dark. They did test good in circuit on diode check with my Fluke 8808A 6 digit DVM.
    Here's the pic's
ID:	3737603 Click image for larger version
ID:	3737604 Click image for larger version
ID:	3737605 Click image for larger version
ID:	3737606 Click image for larger version
ID:	3737611 Click image for larger version
ID:	3737608 Click image for larger version
ID:	3737609 Click image for larger version
    sigpichttps://www.badcaps.net/forum/image....ine=1697924519
    • CapLeaker
      Leaking Member
      • 8339
      On the second last picture, look at C28. Is that cap installed backwards?
      • Mark R
        • Oct 2023
        • 92
        Yep..sharp eye's Leaker. I'm aloud one backwards cap out of the 20 I replaced L.O.L. on that board. Anyway It checked good even being in backwards. But I installed a new one and checked it with the LC103. Fired up the unit and still ...Audio in the off position ...Next click Mic only... that works...but no reverb...Light comes on ( That's what Board #13 & 14 run from the switch) ...Then next click is supposed to be Audio and reverb and Mix. I get the reverb light but totally nothing else. That cap that was in backwards is in the delay line control feed.
        I'm still leaning towards that switch or a defect ( Cold Joint ...Broken trace) or something ???
        Anyway tim for Lunch. Gives you time and me also to ponder WTF!!! L.O.L.
        Regards: Mark
        • CapLeaker
          Leaking Member
          • 8339
          I am saying it’s time to bring out the oscilloscope and see where the audio disappears. Whatever the problem is affects both sides. Switch, muting, an IC etc.
          • Mark R
            • Oct 2023
            • 92
            Tried that once but that switch has to be traced out. I'll hook up the scope and start probing again. Also check voltages in and around the circuit which I have done before. I have another BBD in route. it'll be about a week. Like you say...Sometimes the new stuff you get is garbage. if it passes audio and Mic but no reverb it won't hurt to throw another one in.
            Also, I have another KR 790 that the Reverb circuit which does work ok. But that one has a dead Power L.E.D. display. That one should be an easy fix. I could put the other one up next to the bad one and compare scope traces. Maybe I'll have to go that route if I can't trace what and where on the bad one.
            What you suggest is right... Use the scope.
            Mark R
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              #26
              fix the regulated voltages and all will be well .
              • Mark R
                • Oct 2023
                • 92
                Thanks Pete,
                Got the correct voltages coming in at the board @ +24 Volts DC and - 24 Volts DC. Need to Check around to make sure they are what the schematic calls for at the IC pins and other parts of the circuit. But this all changes when you turn that multi contact switch.
                That's why this think is a PITA as there is no Theory of operation or service manual to follow signal flow at the different switch positions. As Capleaker says it's time to break out the scope for the umteeth time.
                • Mark R
                  • Oct 2023
                  • 92
                  Originally posted by Mark R
                  Thanks Pete,
                  Hey Capleaker:
                  Just dropping by to let you know ..I had a slight detour . Lost my rear brakes on my Classic Ride. Been rushing around to get parts to do the repair. Will be back on the Kenwood soon,.
                  I'll keep you posted.
                  Regards: Mark R
                  • Mark R
                    • Oct 2023
                    • 92
                    I'm Back,
                    Just had some time to Jump on the Kenwood KR 790. Here's the short Story:
                    I have another one that works except for another problem. To eliminate the Main function switch ... I took it out of the unit it was working in and stuck it in the problem one. Same Problem!!! Then I took the one that came out of the non working Reverb section and stuck it into the good unit.......It Worked!!
                    So Now I know I have an electronic problem. The BBD IC has been pushed out to Nov 2nd delivery. But I have both units on the bench and I can trace from the good one and then check the bad one's trace...and so on.
                    Won't be back on for a while.
                    Regards: Mark R
                    • DrDos
                      Unit runs but no speaker output kenwood KR-6030
                      by DrDos
                      I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                      09-14-2025, 09:57 PM
                    • u666sa
                      HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                      by u666sa
                      Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                      Platform: ipa32 la-m024p rev 1b
                      Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                      I found a short on the other side:
                      10-04-2025, 05:03 PM
                    • Loretto
                      Samsung SMPS BN44-00339A
                      by Loretto
                      this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                      I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                      I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                      I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                      03-29-2025, 08:30 AM
                    • Loretto
                      by Loretto
                      03-28-2025, 10:28 AM
                    • ngml
                      Repair of an LG split AC system indoor unit PCB
                      by ngml
                      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                      This indicates an error in the communication between the outdoor and the indoor unit.
                      The outdoor unit is fine, so the problem is the indoor PCB.
                      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                      Does anybody have the schematics of this board,...
                      02-01-2025, 12:55 PM
