LG 50UH5530 intermittent unstable 13V on 3 separate power supplies, band stumped
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone!
    Here's the run-down on this TV. Pictures posted below.
    * LG TV model# 50UH5530
    * Symptoms: Turned off by itself and appeared to be unresponsive.
    * After power reset TV tries to turn on with backlight flash
    * Occasionally will turn on, boot and show picture/sound.
    * TV only turns on when 13V pin reads 10.2V stable in stand-by, with main board connector attached or detached
    * When power button is pressed and stable 10.2V is present 13V pin comes up to 13.2V stable
    * When it shuts off by itself 13V pin shows unstable voltage from 8-12V
    * The problem occurs on 3 separate power supplies and 2 separate main boards
    * Backlights are less than a year old, ShopJimmy.com replacements
    * Backlight settings have been at 66 (on a scale of 100) since new backlights installed.
    Ordinarily I see a backlight flash on these and expect the backlights to be bad....but they're not even a year old. The TV actually worked for a day-and-a-half for me, came on, picture, sound, but eventually faulted and went back to the symptoms above.
    So the band is stumped here.....does anyone have any suggestions or ideas?
    They call me......."threadkiller"
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: LG 50UH5530 intermittent unstable 13V on 3 separate power supplies, band stumped
    Further observation:
    With the original Power Supply installed voltage at the 13v pin in stand-by is a stable 10.2v. When the TV is powered on voltage raises to a stable 13.2v until after the backlight flash, then voltage at 13V pin drops to 7v stable briefly then becomes unstable from 8-12v.
    I have to be missing something here. I'm now wondering if what I'm seeing is this TV's way of going in to failsafe mode with a backlight fault?
    I'll be surprised, real surprised if those SJ backlights failed. If they have it's a first for me with SJ LED strips!
    • CapLeaker
      Leaking Member
      • 8186
      Turn the backlights all the way down and retest.
        • 12206
        • U.S.
        3 power and 2 main, thinking it must be in the backlight circuit, maybe a connection, could be an led too??
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Hi CapLeaker, thanks for the reply. I tried that but couldn't see the menu enough to make it happen.
          Hey nomoresonys, how's it going? Yes I'm sure as well it's in the backlight circuit. After my friend dropped it off it worked for about a day and a half then faulted again. Just like so many of these I've worked on it has one weak LED. Connections look good.
          What threw me was the unstable voltage on the Power Supply. I've heard of problems on the 13v rail on these, but for low voltage not unstable. Bottom line I got this one wrong.
          I'd still love to know why the 13v goes unstable after the fault?
          • CapLeaker
            Leaking Member
            • 8186
            Try something different like forcing the psu to turn on without anything connected to it, besides power mains.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              I did that as part of my diagnostic. With AC power applied there was 10.2v on the 13v line (expected) and was initially stable. Then I hooked the main board/backlights up and monitored the 13v pin while turning the TV on. The voltage came up to 13.2v as expected until the backlight flash, right after it dropped to 7v and shortly after became unstable. I then unhooked the main and backlight connectors, retested the 13v pin and it was still unstable.
              I performed a "power reset" on the PS (unplug for an hour) and re-tested with the same findings/results.
              I'm wondering/thinking when the LED Driver IC gets the wrong return current and shuts off the backlights if there is some feedback from somewhere causing the unstable voltage. I traced the 13v pin to the hot side of the PS and found unstable voltage all over the place, reference main cap ground.
              This is the mystery to me. Why the unstable voltage with a backlight fault? Inquiring minds want to know! lol
              • R_J
                • 9551
                You might have a bad, C5 or C14, these caps filter the vcc supply to the primary ic's, if they are weak, the VCC voltage can drop and the ic goes into standby/burst mode. This vcc voltage is also supplied to the optocoupler (photo cell side) so it can make the power supply think it was turned off
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  Thank you R_J! If this is the case and those caps are weak would there be a measurable change on one side of the opto, say maybe a voltage change/fluctuation I might be able to see with a meter?
                  • R_J
                    • 9551
                    There likely is a change in the vcc voltage, check it across C5, it is the easiest to get at from the top. I was looking at a simlar schematic [168P-L5L01F-00] plus the trace side of this board, the vcc voltage may not connect directly to the optocoupler, It is hard to trace past R65 on the board.
                    • CapLeaker
                      Leaking Member
                      • 8186
                      He already used another PSU. Don't think 2 different PSU's should have the same problem.
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        Should I check C5 using the DC scale?
                        I thought the same....but one never knows. I actually tried 3 of them. If it is a PS problem it would be nice to trace it down.
                        • budwich
                          • Jul 2015
                          • 3097
                          does an LG have some "force on" sequence equivalent to sharp / vizio panels?
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            If it does I don't know the procedure, but would try it if explained to me.
                            • R_J
                              • 9551
                              If you tried 3 different power supplies with the same result, then it is very likely that an led on the strips is bad. and just because the came from shopjimmy does'nt mean they can't fail. Bet SJ gets them from ..... China
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                Yes I bet they do! Besides this model TV seems to be hard on LEDs anyhow.
                                It's going to be "backlight mania" around here next week. I'm ordering a total of 5 sets for different TVs.
                                I'll update when LEDs installed!
                                Thanks everyone for your input!
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  Ok so here's how it turned out:
                                  The backlights arrived today....exactly 48 hours after ordering. ShopJimmy is awesome!!!
                                  I stripped this TV down to its skivvies and powered the TV on with the LCD/diffusers removed....the TV turned on....and remained on for 3 hours until it faulted. I tried to fire it back up and the bottom 2 rows of backlights did not flash. I confirmed it 5 times.
                                  After that I detached the electrical connectors from the bottom 2 rows of LEDs, tested them with the backlight tester on low and high current....and they all lit up. It's like deja vu.....I had a different TV of this model that did the exact same thing. I had to ask myself...."what am I, a sucker?" lol
                                  Since the bottom 2 rows failed to light I replaced them first with the new strips. The TV fired right up 5 times in a row. I installed the remaining new strips and it's now in testing.
                                  So I guess the 13v rail falls all to hell when the backlights fail. Lesson learned!
                                    • 12206
                                    • U.S.
                                    Nice, good to know about that 13v rail, I'll be watching out for that failure symptom.
                                    • iMic
                                      Vintage AT Power Supplies - Selecting Capacitors
                                      by iMic
                                      Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                                      The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                                      02-19-2023, 06:45 PM
                                    • SolomonMan
                                      HP Docking Stations Power Supplies...?
                                      by SolomonMan
                                      All,
                                      I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
                                      Anyways these docks are HP Model 5TW10UT#ABA.
                                      Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
                                      I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
                                      h...
                                      05-09-2023, 08:04 AM
                                    • soler88
                                      Samsung UN46H5203 backlight issue - stumped
                                      by soler88
                                      I am trying to fix this tv that has image and sound but no backlight. Replaced all led strips and each strip turns on using a led tester but do not get any backlight when the tv turns on.
                                      I disconnected the main board from the PS but still no backlight.
                                      Looking at previous threads, nothing is jumping out at me and I'm stumped.
                                      Here are the voltage measurements:
                                      ON STATE
                                      CNM803 on PSU from Main
                                      Pin 1 A13v - 13.09v
                                      Pin 2 OD_UD - 3.3v
                                      Pin 3 A13v - 13.09v
                                      Pin 4 BLU_PWM - 1.6v
                                      Pin 5 A13v...
                                      10-09-2024, 07:28 AM
                                    • dr.thodt
                                      Lenovo laptops unstable with sodimm ram
                                      by dr.thodt
                                      For the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
                                      Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
                                      Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
                                      What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....
                                      06-07-2024, 09:16 AM
                                      Meanwell Switching power supplies intermittent every capacitor under 100uf
                                      by sam_sam_sam
                                      Here is the eBay website link where I bought them from
                                      https://www.ebay.com/itm/276135936202
                                      I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
                                      11-25-2023, 06:05 PM
