Repairing a Sony KD-49X8309 tv (android boot loop)
  • rvh
    • Feb 2020
    • 9
    • Netherlands
    I got a Sony led tv, that's stuck in a boot loop. It won't go any further the android screen and won't turn on further. The indicator light turns up white, and then it comes in a boot loop
    It seems, that all of the Sony tv of this X-range will end with these problems after 2-3 years or so.
    Television
    Sony KD-49X8309c
    Main board
    1-894-595-12
    Y210B300c
    Sony BMFW
    Panel:
    SYV4941
    The problem is the mainboard. That's confirmed by Sony.
    After some googling, i came on some repairers on ebay and it seems like that some parts needs reballing. This one is one such an advert:
    https://www.ebay.co.uk/itm/333470102931
    I also read some problems with eMMC on the web..
    So, questions are:
    -Can anyone confirm that the android boot loop is caused by bad solder connections, which can be solved by reballing the chip?
    -Can anyone tell me what parts needs to be reballed?
    -Has anyone repaired this mainboard itself?
    Problem is, i dont want to spend nearly 175 euro for repairing :/
    And, another question. I see that multiple tv's have this mainboard with this partnumber. Some even bigger screens.. If i manage to find a mainboard with the same parnumber, can i use it for my tv? That one is 49", but i see them also used on 43¨ or 55" screens.
    Thanks in advance, i'll appreciate any help
    If there are questions, please ask.
    This is how the mainboard looks like by the way:
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4425
    • Italy - Milan
    Re: Repairing a Sony KD-49X8309 tv (android boot loop)
    The problem is only software, only if you can gain access to the linux shell you can do funny things but unfortunately most of the makers protects the access with their own rules..
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8286
      +1 for software issue
      • rvh
        • Feb 2020
        • 9
        • Netherlands
        The problem is the emmc chip.. must see if i can get it repaired.
        As far as i understand, at a certain moment all the x-series mainboard will fail.
        Can this be due bad soldering only? Or is it the emmc chio thats gonw bad?
        • ducky29
          • Dec 2015
          • 369
          • Europe
          The guy that listed the repair service is a very reputable guy. I think that you should send the mainboard and the tcon to get it repaired.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4425
            • Italy - Milan
            If you connect the board to a pc via Uart you can have some answers, memory chips are not usually so power drawing so since soldering problems begins with heat problem then reballing of the flash don't seem to me a possible cause, instead all smart tvs are prone to data loss due to the management of data (the need to use flash mem to save data).
            • rvh
              • Feb 2020
              • 9
              • Netherlands
              Last question..
              The mainboard that's inside is:
              Main board
              1-894-595-12
              Y210B300c
              Sony BMFW
              I see that a mainboard with the same partnumber can be found in multiple tv's with different models or even screensizes.
              Would another mainboard with eaxcatly the same partnumber work in this tv, even when it's from another model tv? And, can i update it to the correct soft/firmware by downloading that on a USB?
              Is
              • nomoresonys
                • 12216
                • U.S.
                You need to match the alphanumeric string on the white sticker of the mainboard.
                • rvh
                  • Feb 2020
                  • 9
                  • Netherlands
                  Thanks for the response. Cant remembert havinh seen a sticker on the mainboard. Maybe that's on the other side of the mainboard then..
                  Wull take a look at it at later moment.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8286
                    if the emmc would be dead, you wound't be able to boot. same thing if there is a bga issue. period. Yes, the emmc has a limited read and write cycle.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Sounds similar to my Samsung Galaxy S5, when Android suddenly was in a corrupted state. (in my case, it didn't stay in a reboot-loop and was able to do a "factory reset")
                      It looked like Android was randomly rebooting itself like Windows 2000 and later does, when its kernel panics.
                      At least once, it randomly crashed at the Samsung logo, WTF! Probably flash data corruption.
                      As I got a random reboot when playing music on my Samsung Galaxy S5, IIRC. But ever since the "factory reset", I never saw the Galaxy S5 unstable again.
                      Looks like the Android recovery data wasn't corrupted. Whew.
                      Wouldn't be surprised if Android was silently corrupted on the flash chip. Probably have to at least reflash Android to the storage.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • m3tal82
                        • Oct 2013
                        • 8
                        • usa
                        Have you tried a factory reset on the TV?
                        Hold the volume down and power buttons down on the tv while ac power is plugged in, then unplug ac power (still holding down buttons), plug back in AC power, and hold buttons for 10-30 seconds until you see the front light on the TV turn green, then release power and volume down buttons.. And it will go through its reset process and turn back on.
                        Worth a shot...
                        • neilc6
                          • Nov 2015
                          • 1550
                          https://www.sony.co.uk/electronics/s...icles/00171297
                          • Grut
                            JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                            by Grut
                            My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                            Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                            When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                            Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                            11-15-2024, 03:12 AM
                          • NolesFan
                            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                            by NolesFan
                            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                            10-24-2024, 06:36 PM
                          • Ihandyrepair
                            4 red flash led 65X950G boot Sony and android logo but then black
                            by Ihandyrepair
                            HI guys
                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                            here is the issue
                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                            but then I get black screen and 4 red flash light at the front LED
                            but I get 3 led flash on the LED driver board.
                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                            so I tried...
                            07-11-2024, 01:45 AM
                          • Takeatry
                            Yet another Samsung QLED Boot Loop
                            by Takeatry
                            Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                            10-04-2024, 02:57 PM
                          • torchzack
                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                            by torchzack
                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                            08-28-2023, 07:42 AM
