celcus dled40125fhd
  • finntricky
    • Jan 2014
    • 449
    celcus dled40125fhd
    flashes both eeproms u114 and u115, tv now boots and works great on all inputs, but can not tune in any tv channels ? ideas ?
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: celcus dled40125fhd
    is dtv selected ?
    go into the "hotel mode" service with Menu + 7935 and see if the "digital tuner" is activated or not.
    • finntricky
      • Jan 2014
      • 449
      just tryed it, it is turned on and hotel of, will not tune, just moves though the channels when trying to tune, as if no signal.
      • mmartell
        • Oct 2013
        • 3189
        Where did you get the eeprom bins from ? Are you certain they are correct ones ?
        • finntricky
          • Jan 2014
          • 449
          it was listed as the correct files even with the correct screen, but that don't mean its 100% working or right, but the tv is now working apart form the tv channels,
          here are the files in case anyone else wants to try it.
          • yokoono
            • Apr 2010
            • 515
            U115 deals with channel management. Copy that into memory. I compared what you have and they are different.
              • 12332
              • U.S.
              Maybe try that if you did not already: Switch on your digital box and/or TV.
              Press Menu on the remote control.
              Select the Setup or Installation option.
              Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
              Press OK if your equipment asks if you want to delete all your channels.
              • finntricky
                • Jan 2014
                • 449
                thank you, i will try it, but broken my programmer, so just waiting for another to be delivered
                • yokoono
                  • Apr 2010
                  • 515
                  A repair kit. It's for the stick. Unzipped, put on stick fat32, press and hold the OK key on the remote control. Insert TV into the socket. Release the OK key when the stb LED flashes fast.
                  • finntricky
                    • Jan 2014
                    • 449
                    well tried your file and still the same, search completes with no channels found
                    • finntricky
                      • Jan 2014
                      • 449
                      ill try this USB on next, thanks
                      • finntricky
                        • Jan 2014
                        • 449
                        USB did'nt work
                        • yokoono
                          • Apr 2010
                          • 515
                          Rewrite the memories with the software above.
                          • VaNDAL_UK
                            Altec PC410 Auto PID Tune
                            by VaNDAL_UK
                            Anyone know how to get the Altech PC410 to initiate a P.I.D Tune?
                            I can see the option, turn it on and it just flashed "tune" but nothing happens. Even tried running a profile after selecting tune.
                            I remember doing it years ago on another machine but for the life of me I can't work it out this time.
                            TIA.
                            11-13-2024, 02:58 PM
                          • shadow666
                            Lenovo Y520 NM-B191 U115 Backup
                            by shadow666
                            i have a Lenovo Legion Y520
                            I programmed the 8MB Bios & 1MB ME on the laptop by mistake
                            i have 8MB Bios Backup but i don,t have 1MB ME Backup
                            after programed Bios with 4 or 5 Different ME Laptop Turn on but after 10 Second is boot
                            I cleaned the ME bios part of 8MB by using MEinject software, but it didn't make any difference and the system will boot again after 10 seconds.
                            i know this for 1MB ME
                            my Bios Version is 4KCN45WW
                            Someone has a backup of this version of ME to upload here ?
                            i Need A Backup of 25q80dv U115 backup from 4KCN45WW...
                            09-13-2022, 07:59 AM
                          • dicky96
                            Hitachi V19B01922 Channel Tune problem
                            by dicky96
                            Hi Guys
                            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                            He also has an LG TV, so three screens in the bar
                            I installed three Satlink ST-6503 DVB-T Modulators
                            This model https://www.aliexpress.com/item/32916553905.html
                            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                            02-09-2023, 09:20 AM
                          • dailewis
                            Celcus 48UHDSB-0/1 - intermittent shut down
                            by dailewis
                            I've got. Celcus TV in that shuts down usually after about 45 minutes. It can then be turned back on but then shuts down in between 2-5 minutes each time.
                            The backlights look like they're all lighting up however the screen when a picture is on it is very dim. I haven't stripped tv yet to check backlights with my tester.
                            I have pulled all caps from the board and tested them with my ESR meter and they all appear good on the cold side.
                            one thing to note is that when the tv powers up there is a high pitched whine and a faint crackling noise coming...
                            03-04-2020, 11:20 AM
                          • spleenharvester
                            Cannot tune channels on LG 42LN540V
                            by spleenharvester
                            After a house move, our 42LN540V cannot autotune antenna channels. 0 programmes are found.
                            The control board had very visible damage to the antenna port, so I swapped it out with a new (used) board. Unfortunately, the issue persists. I've checked the cables with a multimeter and they seem to be OK with no shorts present.
                            I've tried two different antenna sockets in the new place and neither work. Short of the roof antenna being knackered, I'm not sure what to do here - is there any way to check the antenna socket with a multimeter?
                            01-06-2020, 09:16 AM
