Cannot tune channels on LG 42LN540V
  • spleenharvester
    • Mar 2010
    • 921
    After a house move, our 42LN540V cannot autotune antenna channels. 0 programmes are found.
    The control board had very visible damage to the antenna port, so I swapped it out with a new (used) board. Unfortunately, the issue persists. I've checked the cables with a multimeter and they seem to be OK with no shorts present.
    I've tried two different antenna sockets in the new place and neither work. Short of the roof antenna being knackered, I'm not sure what to do here - is there any way to check the antenna socket with a multimeter?
    Thanks,
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • nomoresonys
    • 12330
    • U.S.
    Re: Cannot tune channels on LG 42LN540V
    Maybe try a factory reset, if no go try a firmware update, does the tv work on other sources like an hdmi or component etc?
    • spleenharvester
      • Mar 2010
      • 921
      Have tried a factory reset (will have been reset with the new control board too) and no joy. Will try an update later. I bought a cheap crappy indoor aerial and still get no channels either so I'm at a loss here. HDMI and everything else is working fine.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        as its a new house move have you tried another pre tuned tv using the roof aeriel? i know when i moved i had no signal issues and had too call my local council repairs line.
        • spleenharvester
          • Mar 2010
          • 921
          Solved, it is the roof antenna. The cheapo indoor antenna didn't work at first, but I dangled it out of the window on the other side of the house and it picked up a few channels. Thanks all.
          • Hondaman
            Single-channel antenna?
            by Hondaman
            Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
            I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
            Years ago I made a "T"...
            11-18-2024, 01:14 AM
          • Chaks
            Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
            by Chaks
            TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
            The specs says ...
            High antenna efficiency 868MHz ISM Band
            5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
            The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
            1. Should I Fix it with a glue.
            2. Should I fix it with a double side adhesive tape
            3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
            12-09-2024, 11:06 AM
          • dicky96
            Hitachi V19B01922 Channel Tune problem
            by dicky96
            Hi Guys
            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
            He also has an LG TV, so three screens in the bar
            I installed three Satlink ST-6503 DVB-T Modulators
            This model https://www.aliexpress.com/item/32916553905.html
            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
            02-09-2023, 09:20 AM
          • VaNDAL_UK
            Altec PC410 Auto PID Tune
            by VaNDAL_UK
            Anyone know how to get the Altech PC410 to initiate a P.I.D Tune?
            I can see the option, turn it on and it just flashed "tune" but nothing happens. Even tried running a profile after selecting tune.
            I remember doing it years ago on another machine but for the life of me I can't work it out this time.
            TIA.
            11-13-2024, 02:58 PM
          • r2digital
            Harmon Kardon AVR340 no sound on 4 channels
            by r2digital
            Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
            03-09-2024, 01:33 PM
