Harmon Kardon AVR340 no sound on 4 channels
  • r2digital
    • Sep 2011
    • 39
    Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors on each channel and all seem ok. With that being said there's obviously a dead short some where in that section of the amp for the first 4 channels and im having some trouble trying to figure out how to locate it. This is where im asking for help from the gurus on this forum. Since this amp is so old i attached the avr340 service manual for quick access for whoever is willing to help me https://file.io/KkQoP1ZB3PpP
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8309
    disconnect CN19 on the board where these fuses are and check for a short on either side. There is a bridge rectifier that could be shorted on that power board, or something else is shorted on the main board. Your priority right now is to figure out on which board that short is.
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • LEECH666
      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
      by LEECH666
      Good day ladies and gentleman!
      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
      01-19-2024, 05:46 PM
    • japlytic
      Not all TVs can handle surround sound on a HDMI input
      by japlytic
      With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
      So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
      08-31-2022, 10:09 PM
    • Christos Tsiligiannis
      Marian Trace Alpha sound card repair help
      by Christos Tsiligiannis
      Hello to the forum.
      My name is Christos, I am new to the forum here and i am posting from Greece.
      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
      So i tried asking for a schematic from the company and they would not give me one. Instead they...
      11-18-2024, 05:26 AM
      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
      09-12-2024, 02:30 PM
