Vizio E480i-B2 Won't Turn On DPS-167DP IC901
    Re: Vizio E480i-B2 Won't Turn On DPS-167DP IC901
    How about the report in your post #1?
    "D950b read 00.5 Ohms & .000".
    Did you lift one leg and re-test it?
    • Digital_Dad
      DIY'er
      • Apr 2017
      • 36
      • U.S.A.
      Originally posted by budm
      Recheck R907A, R907B since ZD909 is no longer connected in parallel with the resistors any more, just to be sure.
      Looks like 2.1 Ohms across both R907A&B
      • R_J
        • 9627
        That would be correct, 4.7Ω in parallel with 3.9Ω would be 2.13Ω
        • Digital_Dad
          DIY'er
          • Apr 2017
          • 36
          • U.S.A.
          After post #5 I wasn't going to but since I am in the middle of all my gear, any tips on desoldering that type of riser style mount?
          Edit: It was not easy but I was able to free the leg of the diode on the riser.
          D950B = .000
          Where is a good place to source parts?
          • R_J
            • 9627
            So D950b is shorted also. You can get most parts from Digikey, but for the ic you might need to get it from eeeebay/China
            • Digital_Dad
              DIY'er
              • Apr 2017
              • 36
              • U.S.A.
              #26
              Any chance of getting it from Digikey or another place. I'm not a big fan of ebay. By chance does anyone have another part # for LD7913JGM6?
              Also there are some variations of the diodes I really don't understand, like SB2100 vs SB3100, SR3100, SB3H100 E3 for that 3A 100V SCHOTTKY DIODE?
              And I don't know the wattage of the zener diode, I know it's 4.7v and I believe it is made by Vishay?
                4.7v 1W Zener will be fine.
                What is the P/N printed on the D950B?
                "Also there are some variations of the diodes I really don't understand, like SB2100 vs SB3100, SR3100, SB3H100 E3 for that 3A 100V SCHOTTKY DIODE?"
                Easy enough just look up spec sheets: Examples
                SB2100:100V 2A
                https://cdn.badcaps-static.com/pdfs/...2bae9b1e16.pdf
                SB3100: 100V 3A
                https://cdn.badcaps-static.com/pdfs/...b8d7a6ef86.pdf
                • Digital_Dad
                  DIY'er
                  • Apr 2017
                  • 36
                  • U.S.A.
                  #28
                  What is the p/n printed on the d950b?
                  The D950B has:
                  lt3134
                  sb2100
                  • R_J
                    • 9627
                    Digikey has the SB2100 (2amp) or you could use a SB3100 (3amp)
                    For the 4.7v zener NZ4V7D you can use a 1N4732A (4.7v 1watt)
                    I don't know of a direct sub for the LD7913
                    • Digital_Dad
                      DIY'er
                      • Apr 2017
                      • 36
                      • U.S.A.
                      #30
                      The parts are ordered and will be here Jan 6th & 7th. I will post an update when they are here and start work on it. I did have to source the IC chip from ebay and I bought 5 of them so if anyone reading this ends up needing one just message me.
                      • Digital_Dad
                        DIY'er
                        • Apr 2017
                        • 36
                        • U.S.A.
                        #31
                        I seem to have a problem...
                        The SB3100 3A 100v is too large?
                        • jetadm123
                          • 2169
                          #32
                          It's okay that it's physically larger. You would expect that, since it can handle more current. Is the problem the leads of the SB3100 are too thick and will not fit through the holes of the board?
                          • R_J
                            • 9627
                            The diode should be ok, install the sb3100 diode without the standoffs in the D950A position and leave the D950b standoffs in the board. Just install the sb3100 with the same amount of clearence above the board. Just use enough solder to hold it in place
                            • Digital_Dad
                              DIY'er
                              • Apr 2017
                              • 36
                              • U.S.A.
                              #34
                              Yes it is too thick to fit through the stand off holes.
                              • Digital_Dad
                                DIY'er
                                • Apr 2017
                                • 36
                                • U.S.A.
                                #35
                                I just now read this, I have already ordered the new part/s(I always order two just in case). I ordered two SB2100E-G's 2A 100v.
                                So should I use this and try to cancel the order tomorrow or wait until Wednesday for the new part to arrive?
                                EDIT: I just called to try and cancell the order but they said it shipped 3 minutes ealrier so they are unable to cancel the order. It's just one of those days.
                                • Digital_Dad
                                  DIY'er
                                  • Apr 2017
                                  • 36
                                  • U.S.A.
                                  #36
                                  Just got off the phone with the parts house, they couldn't find the part numbers on the original D950B schottky diode - lt3134 sb2100.
                                  And the data sheets for the 3A 100v SB3100 Diodes were all the thicker wire leads?
                                  So I found a SB2100E 2A 100v that matches a lot closer to the size specs of what I currently have to replace. I was so concerned with getting the right amperage and voltage the actual size I thought would all be the same.
                                  Nope, the new Zener is perfect though it tests .678 on the meter set to diode test. And so are the IC chips. Remember anyone who needs one message me.
                                  So for anyone else out there ordering a D950B for this board check the specs, you may have to get a SB2100 too.
                                  • R_J
                                    • 9627
                                    Zener diodes will usually check around .6xx, BUT remember, they zener (or clamp) at different voltages
                                    As for the sb2100 rectifier diode, there is no problem increasing the current and voltage, but as you found out the size can also increase. I would have just used the other holes without the standoffs.
                                    • Digital_Dad
                                      DIY'er
                                      • Apr 2017
                                      • 36
                                      • U.S.A.
                                      #38
                                      I was going to use the other holes and cancel my order but apparently I was 3 minutes too slow. The representative said there was nothing they could do once the order had shipped. I had only placed the order only 45 mins before that. It cost me another $8.79.
                                      So is the correct Schottky diode for this board really a 2A? and not a 3A. Because the size difference sure seems to point in that direction.
                                      I did go ahead and solder the Zener, the IC and the loose plug since I had pulled my gear out before realizing the diode was different.
                                      I will update Wednesday when the other diodes get here.
                                      • Digital_Dad
                                        DIY'er
                                        • Apr 2017
                                        • 36
                                        • U.S.A.
                                        #39
                                        The package was delayed a day and arrived about an hour ago. I went ahead and soldered the new SB2100 schottky diode D950b into place. I then cleaned it up with alcohol.
                                        It came on! It appears to be working again!
                                        So to recap I had to replace the IC chip at IC901, a Zener diode ZD901 and a Schottky diode at D950b. I also had to resolve the CN202 plug the hard plugs into the smaller green driver board. The part numbers and other things to test are all in this thread. I hope that this can help someone fix their TV.
                                        Thank you jetadm123, R_J & budm! I literally couldn't have done it with out you!
                                        EDIT: I now have a single horizontal line near the top of the tv, about 4" from the top, from side to side all the way across.
                                        • pop70458
                                          • Jan 2012
                                          • 103
                                          What would be a good replacement for the r915 resistor?
                                          The markings on the resistor are F1/2J 4.7OHMS FU412 and its made by futaba.
                                          Will this work?
                                          https://www.mouser.com/ProductDetail...RuuLgihA%3D%3D
                                          • TJM2005
                                            DSP-167DP LOW VCC at IC901
                                            by TJM2005
                                            I am trying to repair a power supply for a Vizio M492i-B2.
                                            Before I started:
                                            Fusible Resistor R915 was open.
                                            ZD909 was shorted.
                                            D950B was shorted.
                                            I have replaced the above parts along with a new IC901 / LD7913J
                                            I now have:
                                            165V on the main cap
                                            IC901 Drain pins: 165V
                                            IC901 VCC: 1.1V
                                            IC901 COMP: 1.1V
                                            IC901 BNO: 0.3V
                                            I pulled the Q800 Mosfet and it checked good.
                                            I also tested the two smaller caps C907 and C904B, they both tested close to the rated value.
                                            Does anyone know of anything...
                                            10-12-2025, 12:04 PM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • narf
                                            Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                            by narf
                                            hi all,
                                            first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                            i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                            what i've found so far:
                                            - the PSU does its job and supplies 12V to the mainboard via the connector.
                                            - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                            - not far away, there's the first cap with a resistance of 0.7 ohms....
                                            07-02-2024, 03:53 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
