Vizio E480i-B2 Won't Turn On DPS-167DP IC901
  • R_J
    • Jun 2012
    • 9624
    Re: Vizio E480i-B2 Won't Turn On DPS-167DP IC901
    That will work, but It is unlikely the only problem.
    • 3GsDad
      • Oct 2020
      Originally posted by Digital_Dad
      The parts are ordered and will be here Jan 6th & 7th. I will post an update when they are here and start work on it. I did have to source the IC chip from ebay and I bought 5 of them so if anyone reading this ends up needing one just message me.
      Hey Digital Dad...I know this thread is old but if you have one of these parts still I'm in need of one. Your private messaging isn't working so I decided to just bump the thread.
      • Digital_Dad
        DIY'er
        • Apr 2017
        • 36
        • U.S.A.
        #43
        Yes, I still have a few. Try and PM me again I will keep my eye on it, if I don't reply pretty quickly just come back here and post. We will work it out.
        • stinger
          • Jan 2014
          • 57
          • usa
          #44
          Hi Digital Dad, I am in need of that IC also if you still have one you would like to sell. Thanks
          • Digital_Dad
            DIY'er
            • Apr 2017
            • 36
            • U.S.A.
            #45
            What part number do you need?
            • stinger
              • Jan 2014
              • 57
              • usa
              #46
              I need the LD7913JGM6. It seems like my pm's aren't getting through to you.
              • Digital_Dad
                DIY'er
                • Apr 2017
                • 36
                • U.S.A.
                #47
                I guess my inbox is too full with 30 messages? I didn't think they had a limit.
                I have all three of the parts you listed, shoot me an offer.
                • stinger
                  • Jan 2014
                  • 57
                  • usa
                  #48
                  $8 - $10?
                  • ping.saga
                    • Nov 2020
                    Did you ever fix this problem, I have the IC901 blown. No standby power. I got a replacement board 001(my board is 002). Unfortunately after swapping the replacement board no power either.
                    • squeaks
                      • Nov 2016
                      • 8
                      Hi Digital_Dad,
                      I am also looking for the IC LD7913JGM6. I did send a private message as well. Thanks if you can help. Mike
                      • Rodwillett
                        • May 2021
                        So, after replacing the IC and the ZDiode, did the TV work? Or did you have to replace other components?
                        • Rodwillett
                          • May 2021
                          Originally posted by squeaks
                          Hi Digital_Dad,
                          Regarding the IC901 I have three of them, let me know if you need one.
                          • jlee
                            • Jan 2022
                            • usa
                            #53
                            Anyone know what is the replacement for diode D901? 1Nxxxx?
                            • Camparts54
                              • Feb 2023
                              New here so I may need a tiny bit of help posting correctly. I too have the same problem in a Vizio tv set and will need the common repair parts. I can get back to anyone who suggests test results for components in this PS board. My Tv is also dead with a chip blown out of the same I C. It seems to be a common problem and I wonder if it is worth fixing or not. Anyone with spare parts please feel free to message me. Can't contact Digital Dad because i get a message that his message area is full and needs to be cleared out so that messages will go through.
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • TJM2005
                                DSP-167DP LOW VCC at IC901
                                by TJM2005
                                I am trying to repair a power supply for a Vizio M492i-B2.
                                Before I started:
                                Fusible Resistor R915 was open.
                                ZD909 was shorted.
                                D950B was shorted.
                                I have replaced the above parts along with a new IC901 / LD7913J
                                I now have:
                                165V on the main cap
                                IC901 Drain pins: 165V
                                IC901 VCC: 1.1V
                                IC901 COMP: 1.1V
                                IC901 BNO: 0.3V
                                I pulled the Q800 Mosfet and it checked good.
                                I also tested the two smaller caps C907 and C904B, they both tested close to the rated value.
                                Does anyone know of anything...
                                10-12-2025, 12:04 PM
                              • SS454
                                vizio e650i-a2 backlight flashes then turns off
                                by SS454
                                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                panel: au optronics T650HVN05.4
                                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                08-20-2020, 03:57 PM
                              • narf
                                Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                by narf
                                hi all,
                                first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                what i've found so far:
                                - the PSU does its job and supplies 12V to the mainboard via the connector.
                                - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                - not far away, there's the first cap with a resistance of 0.7 ohms....
                                07-02-2024, 03:53 PM
                              • howardc64
                                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                by howardc64
                                Failure Symptom
                                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                Where is the short?
                                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                05-27-2025, 02:56 PM
