Hitachi 50HYT62U no picture
  • nomoresonys
    • 12323
    • U.S.
    Re: Hitachi 50HYT62U no picture
    Put ur meter in ohm mode check and see if any read very low ohms, one probe on each side of cap, doesn't matter which way around.
    • Bloopeta
      • Jun 2018
      • 526
      Put ur meter in ohm mode check and see if any read very low ohms.
      Ill get onto it now any report back, what would be concidered normal readings and what would be concidered very low on these particular boards?
        All you have to do is to test the resistance of the caps, it can also be applied to any kind of boards when troubleshooting the problem.
        • Bloopeta
          • Jun 2018
          • 526
          And sorry if this is a silly question, but do I test with power on or off? Or is that irrelevant?
          • Bloopeta
            • Jun 2018
            • 526
            Originally posted by budm
            All you have to do is to test the resistance of the caps.
            Ah I see, thankyou, I will do it now and report back
            • nomoresonys
              • 12323
              • U.S.
              #26
              If you see any that are noticeably lower than the others you will know, last ones I measured were pretty much over 100 on 200 setting.
                Always do resistance check when power is not applied, i.e. unplug the TV or what ever you are working on from any power source.
                BTW. you do know how to replace SMD parts, correct?
                • nomoresonys
                  • 12323
                  • U.S.
                  #28
                  Power off.
                  • Bloopeta
                    • Jun 2018
                    • 526
                    #29
                    So Ive tested all caps on those boards, they were all between 50 and 120
                    • Bloopeta
                      • Jun 2018
                      • 526
                      #30
                      Only SMD parts I have changed so far are backlight LEDs
                        50 Ohms? 50 KOhms, 50 MOhms?
                        What is the Ohm scale set to and what is shown on the display of the meter?
                        • Bloopeta
                          • Jun 2018
                          • 526
                          #32
                          Sorry, I set the meter to 200, and the readings are for example 95.6
                            I do not expect any of those ceramics cap to show <100 Ohms.
                            • Bloopeta
                              • Jun 2018
                              • 526
                              #34
                              There are quite alot less than 100 Ohms, so what would that indicate?
                                Need to locate Voltage test points on those board and start checking Voltages. Start by looking for 12V input and the fuse.
                                • Bloopeta
                                  • Jun 2018
                                  • 526
                                  #36
                                  I camt seem to locate any test points on the driver boards themselves, nor a fuse??
                                  Thats not to say they arent any, its just everything is that small, and my eyes arent the greatest lol
                                  • mecha1166
                                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                    by mecha1166
                                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                    11-25-2024, 05:22 PM
                                  • KYBOSH
                                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                    by KYBOSH
                                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                    No picture but you hear the TV static (white noise) playing loud and clear.
                                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                    But it seems they didn't get too far and just left it.
                                    When I first took a look I was amazed at how pristine the inside looked.
                                    Its as if the TV had been in a time capsule.
                                    Caps looked like they were just pulled off the self.
                                    Copper coils had no sign of corrosion on...
                                    02-01-2023, 11:10 PM
                                  • DXseekerMO
                                    TCL 55US57 backlights, no picture.
                                    by DXseekerMO
                                    So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                    The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                    Power Supply, main and T-CON board are working.
                                    Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                    Unhook FFC from left side...
                                    09-18-2021, 03:56 PM
                                  • sordids999
                                    SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                    by sordids999
                                    Hi
                                    Really stuck on this TV
                                    I'm thinking it's a bad screen ?
                                    Voltages all seems good
                                    Tcon 12v ok
                                    Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                    even tried the tape trick still no luck
                                    Thanks...
                                    05-12-2025, 10:36 AM
                                  • stinger
                                    Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                    by stinger
                                    When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                    04-17-2024, 03:06 PM
