Vizio E60u-D3. Will not come on. No Stand-By light
  • nomoresonys
    • 12332
    • U.S.
    #41
    Re: Vizio E60u-D3. Will not come on. No Stand-By light
    Can you use the attachment and upload the pics here?
    • nomoresonys
      • 12332
      • U.S.
      #42
      Looks like your new mainboard is not compatible, can you post a good picture here of the white sticker/s on it or type out the number letter strings? Sometimes you can change the panel settings in service menu which this doesn't seem to have a typical service menu like in tvs with a tuner but I think you have a mismatch mainboard there, thinking that even if you got to panel settings in a service menu that it would not work. I could be wrong, my best guess tho.
      • nomoresonys
        • 12332
        • U.S.
        #43
        You are sure it's a E60 and not a E65?
        • nomoresonys
          • 12332
          • U.S.
          #44
          What is the complete model number and service code on the back cover?
          • karthur
            • Nov 2015
            • 150
            It is actually a e65u. Sorry for the confusion there. Here is the main board i purchased.
            https://www.ebay.com/itm/Vizio-E65U-...EAAOSwgrBdp7l1
            There is no service code on the back. Just model and serial number. I tried to post the pics but they were too large and I had to zip them. Can you see the zip file?
            Thanks.
            • nomoresonys
              • 12332
              • U.S.
              #46
              Ok, that board looks like the right one, I don't know what it could be then, unless they sent you a bad one. My bad on calling it the wrong board, I thought I read that the new board was from a e70, must have got my threads mixed up.
              • nomoresonys
                • 12332
                • U.S.
                #47
                DISREGARD this, my bad.
                • budwich
                  • Jul 2015
                  • 3097
                  you weren't dreaming. The post at the bottom of the first page, the op indicated that the "new card" shows a 70in set. This is indeed the problem. The question is... can this actual card (serial number / model) be used in multiple set sizes or is indeed, the card for the wrong set. A quick look thru shopjimmy shows some "differences" across cards in the "family" (similar serial numbers) with some additional "checks" for the set type serial number... there are some different possibilities.
                  • karthur
                    • Nov 2015
                    • 150
                    Are you talking about post #17?
                    The "new" card is the same part number, rev # and date as the original board. I am beginning to think the board is bad.
                    • budwich
                      • Jul 2015
                      • 3097
                      Thanks.
                      you need to look closer at the board they sent you. There is a small label near the heat sink. The picture in the listing doesn't give a clear picture... instead they posted a good picture of the "generic" label for the card. The sticker needs to be 138C.
                      • nomoresonys
                        • 12332
                        • U.S.
                        #51
                        It's very strange that it reports as 70, there's the match from shop jimmy, is yours exactly like it, do the numbers on white sticker match? Is it possible they sent you a 70 by mistake?: https://www.shopjimmy.com/vizio-y838...has-serial.htm
                        • budwich
                          • Jul 2015
                          • 3097
                          all the cards in the "series" look the "same"... the only difference is the 136c,138, and 140c which are 70 65 60 according to shopjimmy. The key is the small label.
                          • karthur
                            • Nov 2015
                            • 150
                            See attached. Better pics of the tags on each board. The original board has 138A on the tag. The board i purchased was advertised to be for a 65... But it has 136B on the label and seems to be for a 70. Hopefully the ebay seller will do the right thing and take a return since this is not the correct board.
                            Thanks guys for all the help.
                            • nomoresonys
                              • 12332
                              • U.S.
                              #54
                              Ahh bingo, yep definitely a seller screw up, that has to be the only way you would get that 70 from post 17. Ok then re-regard post 42 and 47.
                              • karthur
                                • Nov 2015
                                • 150
                                Just letting everyone know the issue was the incorrect board. I searched again and found the correct board... installed it and it worked perfectly. Either the seller either shipped me the wrong board, or just had it listed wrong.
                                Many thanks to NoMoreSonys and budwich for all the help. Would never figured this out without their help.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  glad you got it straighten around. The cards look the same but vizio must have some way of writing the model number. In some "older sets" with multiple panel types / sizes, one could get into the service menu and change the panel number to get a card to function. Sony has some form of tcon to main exchange which updates / co-ordinates capabilities across panels. Anyway, enjoy your screen.
                                  • nomoresonys
                                    • 12332
                                    • U.S.
                                    #57
                                    Glad to hear it, thanks for the feedback.
                                    • x_orange90_x
                                      Vizio E550i-A0 no power, no standby light
                                      by x_orange90_x
                                      I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                      11-20-2023, 09:49 AM
                                    • p-top
                                      Vizio, E60u-D3, no standby light, no ps_on
                                      by p-top
                                      Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                      main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                      PS voltages
                                      1 VSNS -2mV
                                      2-5 LED-OUT -2mV
                                      6-10 GND -2mV
                                      11 +16VS 16.29V
                                      12 AC-DET 3.929V
                                      13PS-ON -3mV
                                      14 +16VS 16.29V
                                      15 +16VS 16.29V...
                                      11-27-2023, 10:44 AM
                                    • ChristianBr01
                                      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                      by ChristianBr01
                                      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                      04-23-2025, 01:48 AM
                                    • bunting78
                                      Vizio D650i-B2 wont trun on and no standby light
                                      by bunting78
                                      First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                                      09-23-2021, 08:53 AM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
