Vizio E60u-D3. Will not come on. No Stand-By light
  • nomoresonys
    • 12276
    • U.S.
    Re: Vizio E60u-D3. Will not come on. No Stand-By light
    Looks like you need to use an app on a phone or tablet etc. to work the menu:
    ยท 3 years ago
    Some features are good, but it is not a TV
    This model has a clear picture and has nice features. However, it is not a television. It does not have a tuner and there is no coaxial connection. It is basically a large computer monitor. It will only work with items that can be connected by USB, HDMI, or RCA. It also comes with a remote that will not even access the menu or settings. You MUST connect it to a smart phone or tablet to even operate the menu. Also the unit will dim the display periodically, despite the fact that the auto dim feature is set to "off".
    • nomoresonys
      • 12276
      • U.S.
      Yep, it has no tuner: https://www.vizio.com/e60ud3.html
      • budwich
        • Jul 2015
        • 3097
        what remote do you have? maybe spend the $10 and get a "good" remote.
        • karthur
          • Nov 2015
          • 150
          ยท 3 years ago
          I tried it with the smartphone app to control it. could not get to the service menu with that. I wasnt so sure that it would work right if I was pressing two buttons at the same time on the phone.
          I have a Direct TV remote that I can program. Will try it tonight and see if I can get it to control the it.
          BudWich : I have the XRT-132 remote. See message #19 for a visual.
          • budwich
            • Jul 2015
            • 3097
            :-( hopefully you can get a universal to work. From a quick search, the "standard" remote for the set is about $10... might be worthwhile since you got this far.
            • karthur
              • Nov 2015
              • 150
              I have the original remote that came with it. It just does not have a menu button.
              • karthur
                • Nov 2015
                • 150
                I also borrowed my neighbors vizio remote. It has a menu button and seems to work with my tv. It turns the set on/off and the menu brings up the system menu. Tried procedures to get to the service menu and none of them work.
                • nomoresonys
                  • 12276
                  • U.S.
                  #28
                  See if the other functions of the system menu work and volume channel up down and mute etc. to verify it working, I've tried some same brand remotes but different models that only had limited function on the other tv.
                  • karthur
                    • Nov 2015
                    • 150
                    As far as I can tell everything on the borrowed remote works.
                    • budwich
                      • Jul 2015
                      • 3097
                      maybe if your neighbor is "nice"... :-) you can try some of the sequences on his set to see if you can get any to work... it could be a "finger problem".... but be careful not to do anything there after.
                      • karthur
                        • Nov 2015
                        • 150
                        He is out of town and wont be back until 2020.
                        His set is not the same E-series, but i can try.
                        Have either of you actually got to the service menu on this e-series set?
                        • nomoresonys
                          • 12276
                          • U.S.
                          #32
                          Nope, haven't had the "pleasure" of messing with one of these, starting to wonder if there is a service menu.
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            It's a little different than a regular tv, I think you have everything you need with your remote, here's the whole spew: https://cdn.badcaps-static.com/pdfs/...26246f0ca0.pdf
                            • karthur
                              • Nov 2015
                              • 150
                              I have the user manual. I have searched everywhere but cant find a service manual.
                              • nomoresonys
                                • 12276
                                • U.S.
                                #35
                                Post a good clear picture of both mainboards, need good clear straight on pics.
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  #36
                                  What's the first 8 letters of the serial number of the tv on the back cover?
                                  • karthur
                                    • Nov 2015
                                    • 150
                                    No problem. It will be this afternoon before I can get the pics and number.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      nope... never had the pleasure, just seen what has been posted here for vizio and sharps for that matter. BUT the purpose of the effort, is to see if YOU can get into a service menu at all. There have been a number of posts that user have difficulty getting into the SM on various sets. It is rather suspect and indeed, the likely suspect is usually "fingers". Hence, the "test".
                                      • karthur
                                        • Nov 2015
                                        • 150
                                        I really appreciate the help and it might be a timing thing with the key-presses. Only reason I asked was to make sure there was indeed a service menu available.
                                        • karthur
                                          • Nov 2015
                                          • 150
                                          The set serial number is LFTIUHAS......
                                          Attached below are the pics of both the original and the replacement main boards. If these are not clear enough, let me know and I will try again.
                                          • x_orange90_x
                                            Vizio E550i-A0 no power, no standby light
                                            by x_orange90_x
                                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                            11-20-2023, 09:49 AM
                                          • p-top
                                            Vizio, E60u-D3, no standby light, no ps_on
                                            by p-top
                                            Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                            main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                            PS voltages
                                            1 VSNS -2mV
                                            2-5 LED-OUT -2mV
                                            6-10 GND -2mV
                                            11 +16VS 16.29V
                                            12 AC-DET 3.929V
                                            13PS-ON -3mV
                                            14 +16VS 16.29V
                                            15 +16VS 16.29V...
                                            11-27-2023, 10:44 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • bunting78
                                            Vizio D650i-B2 wont trun on and no standby light
                                            by bunting78
                                            First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
                                            09-23-2021, 08:53 AM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
