TCL 55US57 Bad Tcon Or Bad Panel Boards
  • Michale32086
    • Nov 2011
    • 1453
    Got a nice TCL in.. 55US57..
    I have dealt with a few of these, but there issues were backlights..
    This one, the backlights are fine, I just get no display at power up..
    I have found that, if I take off the right connector that goes from the TCON to the Panel Boards, I get display on the Left side of the TV...
    That tells me either it's a bad TCON (hope hope) or a bad left side panel board...
    If it's the panel board, it's likely unfixable..
    Is there a way to determine conclusively whether it's the TCON or Panel Board???
    Other than replacing the TCON...
    • 12208
    • U.S.
    Re: TCL 55US57 Bad Tcon Or Bad Panel Boards
    What did you get when you did the other ribbon cable?
    • Michale32086
      • Nov 2011
      • 1453
      Backlights.. no display on panel.. Sorry.. Meant to add that detail..
        https://www.badcaps.net/forum/attach...1&d=1574193881
        Start checking the RESISTANCE of those MLCC on that tab bonding board of the bad side.
        • Michale32086
          • Nov 2011
          • 1453
          Awesome.. Thanx...
          Uh.. Forgive my ignorance. Can you circle an MLCC??
            Those brown tan caps.
            • Michale32086
              • Nov 2011
              • 1453
              Checked the first three.. Marked..
              1600 Mohms +/- 10-20ish
                You need to check all of them.
                BTW, you meter can read 1600 Mega Ohms?
                • Michale32086
                  • Nov 2011
                  • 1453
                  Will do... As soon as I get back to the shop.. Is that a normal correct reading for those?? 1600 +/-??
                  My meter says which I took to mean Mega Ohms
                  I'll get right back on it when I get to the shop..
                  Thanx for the replies..
                    • 12208
                    • U.S.
                    That might be a match, looks like it has the same part number: https://www.ebay.com/itm/4T-TCN550-C...cAAOSwzztdOxRt
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Yea, the one I have is a 1-C-7... I found one on EBAY, but want to confirm that the TCON will fix it.. On the other hand, it's only about $25..
                        • 12208
                        • U.S.
                        Looks like they both work, I thought they looked very similar: https://www.shopjimmy.com/tcl-4t-tcn...-con-board.htm
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Yea, I am guessing it's likely a firmware difference..
                          Just got to the shop, will test those MLCCs ..
                          Question, are the MLCCs ALL of the tan caps?? Or just the larger ones I marked??
                            • 12208
                            • U.S.
                            Probably all the ones that start with C.
                            • Michale32086
                              • Nov 2011
                              • 1453
                              OK, getting some different readings now..
                              With the + probe on the lower and the - probe on the upper, I get 7.5K +/-
                              With the - probe on the lower and the + probe on the upper, I get 10.05K +/-
                              • Michale32086
                                • Nov 2011
                                • 1453
                                That's a lot of probing..
                                Thanx
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Do you have an idea of what I am looking for??
                                  Like a 0.0 reading means that cap is dead or something like that??
                                    • 12208
                                    • U.S.
                                    I think 0 is dead short and too low is bad too.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      OK... A probing I will go..
                                        • 12208
                                        • U.S.
                                        Dog did it like this, he got pretty fancy and used both diode and ohm modes, the showoff, lol, I could use a pair of those Superman glasses he's got there: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Lee M.
                                          Amazon Fire TV Omni K24NE5 tcon or panel bad?
                                          by Lee M.
                                          TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
                                          05-12-2023, 05:47 PM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
