TCL 55US57 Bad Tcon Or Bad Panel Boards
  • Michale32086
    • Nov 2011
    • 1453
    Got a nice TCL in.. 55US57..
    I have dealt with a few of these, but there issues were backlights..
    This one, the backlights are fine, I just get no display at power up..
    I have found that, if I take off the right connector that goes from the TCON to the Panel Boards, I get display on the Left side of the TV...
    That tells me either it's a bad TCON (hope hope) or a bad left side panel board...
    If it's the panel board, it's likely unfixable..
    Is there a way to determine conclusively whether it's the TCON or Panel Board???
    Other than replacing the TCON...
    • 12331
    • U.S.
    Re: TCL 55US57 Bad Tcon Or Bad Panel Boards
    What did you get when you did the other ribbon cable?
    • Michale32086
      • Nov 2011
      • 1453
      Backlights.. no display on panel.. Sorry.. Meant to add that detail..
        https://www.badcaps.net/forum/attach...1&d=1574193881
        Start checking the RESISTANCE of those MLCC on that tab bonding board of the bad side.
        • Michale32086
          • Nov 2011
          • 1453
          Awesome.. Thanx...
          Uh.. Forgive my ignorance. Can you circle an MLCC??
            Those brown tan caps.
            • Michale32086
              • Nov 2011
              • 1453
              Checked the first three.. Marked..
              1600 Mohms +/- 10-20ish
                You need to check all of them.
                BTW, you meter can read 1600 Mega Ohms?
                • Michale32086
                  • Nov 2011
                  • 1453
                  Will do... As soon as I get back to the shop.. Is that a normal correct reading for those?? 1600 +/-??
                  My meter says which I took to mean Mega Ohms
                  I'll get right back on it when I get to the shop..
                  Thanx for the replies..
                    • 12331
                    • U.S.
                    That might be a match, looks like it has the same part number: https://www.ebay.com/itm/4T-TCN550-C...cAAOSwzztdOxRt
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Yea, the one I have is a 1-C-7... I found one on EBAY, but want to confirm that the TCON will fix it.. On the other hand, it's only about $25..
                        • 12331
                        • U.S.
                        Looks like they both work, I thought they looked very similar: https://www.shopjimmy.com/tcl-4t-tcn...-con-board.htm
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Yea, I am guessing it's likely a firmware difference..
                          Just got to the shop, will test those MLCCs ..
                          Question, are the MLCCs ALL of the tan caps?? Or just the larger ones I marked??
                            • 12331
                            • U.S.
                            Probably all the ones that start with C.
                            • Michale32086
                              • Nov 2011
                              • 1453
                              OK, getting some different readings now..
                              With the + probe on the lower and the - probe on the upper, I get 7.5K +/-
                              With the - probe on the lower and the + probe on the upper, I get 10.05K +/-
                              • Michale32086
                                • Nov 2011
                                • 1453
                                That's a lot of probing..
                                Thanx
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Do you have an idea of what I am looking for??
                                  Like a 0.0 reading means that cap is dead or something like that??
                                    • 12331
                                    • U.S.
                                    I think 0 is dead short and too low is bad too.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      OK... A probing I will go..
                                        • 12331
                                        • U.S.
                                        Dog did it like this, he got pretty fancy and used both diode and ohm modes, the showoff, lol, I could use a pair of those Superman glasses he's got there: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • rimwall
                                          Sony KD-65x7500D - double image - Tcon or Panel?
                                          by rimwall
                                          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                          11-18-2025, 02:09 AM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
