LG 60UH8507 Backlight turns off after few seconds
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Hello, this TV is a relatively new platform, certainly new to me. LED backlight connection is unclear to me, appears to be several separate circuits going to the ribbon, instead of the more common 2 wire connection and everything in series.
    Anyway the problem is that the TV turns on and works just fine, then after 10 seconds or so the backlight turns off, but you can still make out the picture so the rest is still working. There is some sort of diagnostic LED on the power supply that blinks red 4 times in a loop with pauses after the backlight failure occurs. Couldn't really find what this means. In fact I couldn't find much info about this particular TV at all.
    Any directions on where to go? There appears to be a test point on the power supply marked LED+ and GND. The voltage is 45V after plugging the PSU into the mains, then it falls to 42,5V in standby. After turning the unit on, it goes to 87V, LED backlight comes on, works for about 5-10 seconds and then the backlight turns off, but the voltage on this point still stays at 87V and begins to fall off very slowly down to 62,5V and the power supply blinks the diagnostic LED 4 times and repeats it.
    I would really like to eliminate all possible causes before disassembling this massive 60 inch panel to get to the LEDs.
    I do posses a high voltage LED backlight tester.
    Attaching pics of the inside.:
  • FrozenHaxor
    • Jun 2015
    • 260
    • Poland
    Re: LG 60UH8507 Backlight turns off after few seconds
    I have tested each VC_ to LED+ on both ribbons and I get stable 75-80V @42mA. Not sure how else I can test the backlight without disassembly.
    I'm swaying towards the power supply being faulty.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      It looks like you have a led problem. Turn the set on and reduce the backlight level to 50% or less and see if the backlights stay on longer.
      • FrozenHaxor
        • Jun 2015
        • 260
        • Poland
        Backlight stays on at maximum power saving settings where the image is barely visible.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So turning backlight to minimum they stay on but the image is barley visible. It certianly appears that you have a led problem.
          • FrozenHaxor
            • Jun 2015
            • 260
            • Poland
            Alright then. Looks like the inevitable is coming. Disassembling the panel now.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              That's a large panel to remove. There are threads on the forum offering advice on removing large panels. Good luck.
              • FrozenHaxor
                • Jun 2015
                • 260
                • Poland
                Manage to disassemble it from the back. Panel is still lying on the table, I lifted the back away with suction cups after removing all screws. Looks like it has edge LEDs on the bottom only, two strips on metal backing glued in. Needs some heat to loosen them up.
                • FrozenHaxor
                  • Jun 2015
                  • 260
                  • Poland
                  Right, one diode is faulty. Decided to order the whole heatsink with diodes already glued in. Not feeling like having to deal with this TV again if another diode fails after replacing just one. Will update on the topic when I get the part and the panel back together.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    I would suggest you change ALL the backlight strips, instead of the single bad strip. This will guarantee not having to open her up again for along time. Remember to turn down the Backlight setting on ALL the Inputs after you close her up. 65-70% is about the best setting. Good Luck.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      Good job and good decision to replace the whole strip.
                      • FrozenHaxor
                        • Jun 2015
                        • 260
                        • Poland
                        The entire backlight was replaced along with the radiator it's factory bonded to. TV works fine now. Thanks for the help to everyone involved in the topic.
                        I see now why this one was so difficult to diagnose. The power supply has the ability to address individual backlight strip sections depending on current display content. Very different to regular fixed ones.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Glad you got there in the end.
                          • vikivng
                            • Feb 2019
                            • 228
                            hI gus ,
                            I hope its ok to add to this thread.
                            I have a 55 Toshiba tv that seems to have similar symptoms to the OP,
                            If the tv is on without any peripherals attached and no menu input, it will stay on indefintely.
                            From the time the menu button is pressed, the backlights go out.
                            If anythng is connected via hdmi, the backlights go out.
                            I have changed the mainboard to no avail.
                            Does this point to the leds.?
                              • 12274
                              • U.S.
                              I usually try the simple things first, firmware update and factory reset, might not fix it but shouldn't hurt and can eliminate those from the suspects after.
                              • EuLE
                                • Aug 2020
                                Recently, my TV (LG 60UH8509) had this exact symptoms after 3 years of usage. The backlights would go off after 5 seconds and
                                LD701 on the powerboard was blinking in intervals of 4 times. The TV had sound and by shining a light onto the screen you could see the lcd had a picture.
                                First thing I did was buy a new powerboard via the LG website and exchanged it. Unfortunately this didn't fix it so I went ahead
                                and opened the panel to get to the leds. Turned out one of them was faulty so I ordered 2 new strips from AliBaba as it was the only source I could find.
                                After reassembly when I first turned on there was no picture at all, so I reopened the back panel and reconnected every flatband cable connection to the LCD.
                                Now my TV works perfectly again. The next step is to make sure the max value for the backlights is set to 70% in every picture mode.
                                I'm quite sure this should prolong the LEDs' life by a good amount of time.
                                So all in all I paid around 290€ for the parts (powerboard 180€ + led stripes 110€),
                                but I'm sitting on a spare powerboard now. I'm still undecided, but If I sold it, I could realistically get maybe 100€ or so.
                                Last point: the LG support was not helpful at all. All I got from them were pre-made e-mail texts saying "no support for self service" and such things. "Go buy a new TV" ... after 3 years ... sure, LG
                                Word of advice: Don't underestimate the space you need when disassembling a 60" panel.
                                • alpersen
                                  Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
                                  by alpersen
                                  Hello
                                  Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
                                  07-25-2024, 12:50 AM
                                • www
                                  LG L192WS-BN backlight turns off after 1 second
                                  by www
                                  I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                  I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                  03-24-2024, 05:26 PM
                                • phuzzyday
                                  My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
                                  by phuzzyday
                                  This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
                                  (All the Electrolytics are brand new.)
                                  I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
                                  I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out...
                                  05-30-2025, 05:20 PM
                                • twonk9098
                                  Lenovo Legion 5 high fan spin turns off after 34 seconds
                                  by twonk9098
                                  I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                  I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                  I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                  I have tried a few new bios but exactly...
                                  07-14-2024, 11:19 AM
                                • frannyjunk
                                  Hisense 40H4F no backlight but turns off after splash screen
                                  by frannyjunk
                                  So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                  TIA.
                                  09-24-2025, 10:59 AM
