Sharp LC-70LE600U Won't Turn On
    • 12089
    • U.S.
    Re: Sharp LC-70LE600U Won't Turn On
    Did you try a reset? might be: hit menu-scroll over to initial setup-scroll down to reset, then follow the prompts.
    • R_J
      • 9535
      Forcing the tv on with Vol(-) and input, and pluging in the tv is how service mode is entered, When you do that do you get the letter<K> on the screen? Since the tv does come on and work at some point I would think the fault is on the main board and it is either a bad eeprom ic or a bad bga connection on the large processor ic. The heat on the t-con chip is likely normal.
      I would try freezing the eeprom, this sometimes will work and the tv will read the data correctly and the tv will turn on and work normally.
      To do this: unplug the tv, freeze ic8401, wait 5~20 seconds, plug in the tv and try turning on. I see shopjimmy offers an eeprom which might fix this issue.
      I thought it might be a backlight led problem, but if it was, it should have sent the error to the main and the led would be flashing the fault code. and entering the service mode should bypass this and the tv should stay on and not instantly turn off when the buttons are released.
      • befuddled
        • Sep 2019
        • 22
        • US
        I did do a reset to factory settings. No change.
        • befuddled
          • Sep 2019
          • 22
          • US
          I'd seen videos showing this. No. I do not get a K in a box. This is an older tv so I don't know if that makes a difference. I believe it was purchased in 2013.
          I wondered if that heated chip was actually normal, it's just that nothing else on either board (main or tcon (I go touching things on the power supply!)) get remotely close in temperature.
          I don't have anything with which to freeze the eeprom.
          The tv DOES stay on in service mode. It becomes fully functional.
          • befuddled
            • Sep 2019
            • 22
            • US
            SCRATCH THAT! I just got the K for the first time. Is there anything that can be done with that?
            • R_J
              • 9535
              Don't you have the service manual? If not you can get it here https://www.badcaps.net/forum/showth...ht=LC-70LE600U
              When the <K> is on the screen,you can enter the service adjustment mode by pressing and holding VOL(-) and CH(▼)
              Check normal standby cause and error standby cause:
              You can also clear errors on page 9
              BUT DO BE CAREFULL There is no need to adjust anything and there is no need to do any of the RESET as that resets the adjustments on that page.
              • befuddled
                • Sep 2019
                • 22
                • US
                #27
                I'd seen that thread but didn't notice the service manual links! Thanks for pointing that out! I will check those out later today.
                  • 12089
                  • U.S.
                  #28
                  Check lamp error count, thinking it will be at max, reset to 0, make note of any faults and clear them, be VERY CAREFUL in that service menu.
                  • befuddled
                    • Sep 2019
                    • 22
                    • US
                    #29
                    So I just got into the service menu on the tv and I'm including a couple pics, one showing page 1 and one of page 9.
                    Can you guys take a look at the values on page 9 and tell me if they give any hints as to what may be wrong?
                    I see a "STANDBY CAUSE RESET" but that's the closest thing and it just says "OFF"
                    Oh wait... I just saw the NORMAL/ERROR STANDBY CAUSE lines on page 1. Those values seem logical to me as if there were nothing wrong?
                    L ERR RESET says 6... is that the lamp error count? Should I change that to 0? I also don't know what faults I'd be seeing to make note of and then clear.
                    Should I set the EEP CLEAR to ON?
                    Also... I included a pic of page one because it shows TEMP SENSOR 192, and on page 9 it shows TEMP CAUTION 139 and TEMP SHUTDOWN 135. Are these related? And can this be part of the issue?
                    Sorry for my ignorance, I just don't want to jump to conclusions OR do anything inside this menu without knowing that I'm doing the right thing!!!
                    • R_J
                      • 9535
                      If you highlight L ERR RESET and press enter, you should be able to set it to 0 by using the < > arrow keys
                      This is likely why the tv won't turn on, 6 is the maximum for the error count.
                      I think the temp data is wrong, why have shutdown at 135 but caution at 139? I would change them to something like 200, that 192 could be wrong data causing the tv to shut down also. Those will likely be in the range of 0~255 and not temperature.
                      • befuddled
                        • Sep 2019
                        • 22
                        • US
                        #31
                        I think the temp data is wrong, why have shutdown at 135 but caution at 139? I would change them to something like 200, that 192 could be wrong data causing the tv to shut down also. Those will likely be in the range of 0~255 and not themerature.
                        LOL. I thought the 135 and 139 figures seemed a little odd to me! Glad someone else thinks so too!
                        I'll try setting the L ERR RESET to 0 first and test it. If it doesn't work, then I'll change those temp values. I will give these things a try and get back to ya!
                        • befuddled
                          • Sep 2019
                          • 22
                          • US
                          #32
                          So setting the lamp error count back down to zero worked. I lugged the thing out of the garage, around to the back of the house down the hill and into the family room in the basement. Hooked it up to my system... very not impressed with tv's sound hookup options, mainly the lack of optical audio cable signal even though it HAS A PORT! But I digress. Anyway, within an hour or so, the faded triangle in the lower left corner doubled in size and the tv shut off. The good news is that it did start blinking a code. But since I was done for the day and trying to watch tv, I just unhooked it and set it aside and hooked up my original tv again.
                          The fact that more of the lights went out right before it turned off pretty much tells me that those burned lights are more than likely the problem (even though that faded triangle has been on the screen for one to two YEARS).
                          How expensive are these strips, and how difficult are they to change them? I'm not sure I want to even bother at this point though, given the lack of compatibility with my sound system.
                          I wonder what I could get for it if I put on craigslist or facebook marketplace (after fixing, of course!).
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            #33
                            From China, not very expensive at all. https://www.aliexpress.com/item/33047722408.html I believe they are the same as the new ones sold on ebay. https://www.ebay.com/itm/Sharp-LC-70...y/152399107128
                            You need three strips I believe.
                            Also available from Shipjimmy https://www.shopjimmy.com/sony-70inc...dl-70r550a.htm
                            Changing the strips is easy. It's taking the 70" LCD panel out of it's frame to get to them that's the tricky bit.
                            • befuddled
                              • Sep 2019
                              • 22
                              • US
                              #34
                              Thank you for that! I found a pretty decent how-to on the youtube that makes me think I can probably do the job. (https://www.youtube.com/watch?v=TJUtrExz-aI)
                              I have some rigid foam insulation that I can gently transfer the glass to rather than fully lifting it and leaning it somewhere (yikes).
                              I went ahead and ordered the strips for less than $16 (on a slow boat) from China.
                              If the repair is successful, at the very worst, I figure I could get a couple hundred bucks for it. If I destroy it, I could part it out on eBay!
                                • 12089
                                • U.S.
                                #35
                                Big big screen, VERY easy to break, I suggest using suction cups.
                                • befuddled
                                  • Sep 2019
                                  • 22
                                  • US
                                  #36
                                  I don't have suction cups. I'm quite certain I'll be able to transfer the glass to a piece of rigid foam. And like I said, even if I do break it, I can part it out on eBay now that I know the PSB, main, and tcon are all good. A used working PSB goes for $150+, main board $99+, and tcon for $40.
                                  I'll be as careful with it as I can because, quite frankly, I hate failing!
                                  • befuddled
                                    • Sep 2019
                                    • 22
                                    • US
                                    #37
                                    So.... TWO MONTHS LATER.... I finally got the replacement led strip from China yesterday!
                                    SUCCESS!!
                                    TV is as good as new!
                                      • 12089
                                      • U.S.
                                      #38
                                      Well done, glad to hear it, thanks for feedback.
                                      • JunkmanJimbo
                                        Sharp lc-55p6000u won't turn on
                                        by JunkmanJimbo
                                        Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
                                        09-28-2024, 12:56 PM
                                      • pajdek
                                        Lenovo Y700-17ISK turn on and off
                                        by pajdek
                                        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                        09-20-2023, 02:49 AM
                                      • Egidio85
                                        SHARP LC-40LE814E does not turn on 2 flashes
                                        by Egidio85
                                        hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                        the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                        reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                        now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                        to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                        07-21-2023, 11:49 AM
                                      • Superbee_dad
                                        Sharp 80” long short flash backlight error - Help
                                        by Superbee_dad
                                        Hello Sharp TV experts
                                        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                        01-24-2025, 11:51 PM
                                      • Mitike
                                        SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                        by Mitike
                                        Hello guys,
                                        I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                        According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                        And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                        If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                        02-16-2020, 08:11 PM
