LG BP620 DVD player lightning hit / not working now.
  • roadrunninmark
    • Apr 2019
    • 11
    I have a LG BP620 Blue Ray/DVD 3D player that was another victim of a lightning strike. Seems that the strike came through the cable line, taking out cable box then transferring to the HDMI cable (in which I had a HDMI hub) that made its way to the DVD player. It won't power on or do anything. Normally, when you plug it in, it would make a power up "sound", but it is not doing anything.
    I really like the unit, as I just got a used one from Ebay to replace it. If it is something I can inexpensively replace in the unit to make it work again, I would like to give it a try.
    Is there anyone here that can lead me in the right direction on which item might need to be replaced and where I could get it?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG BP620 DVD player lightning hit / not working now.
    Photographs of the inside so we can see what we're dealing with.
      Please upload good clear pictures. Do you have tools to do troubleshooting and repairing down to component level?
      • roadrunninmark
        • Apr 2019
        • 11
        I checked the fuse (with multi meter, only troubleshooting tool I have) and it is good.
        Here are some pics, let me know if you need any closer up or more detailed...
        • roadrunninmark
          • Apr 2019
          • 11
          couple more pics:
            • 12129
            • U.S.
            Check those diodes and resistors in the area where the power cord is coming in, meter in diode mode, each end of probe on each end of diode should get a reading in one direction reverse the leads should read 1 or OL. Thats for the diodes, resistors will read same both ways. Sometimes it's just about impossible to get an accurate reading of a resistor in circuit.
            • R_J
              • 9535
              Check the voltage on CN901 pin5 (5v) or check if you have any DC voltage on these diodes I marked, If they are 0 then check the large 5 watt resistor near the ac input, If it is ok, check the two green flameproof resistors (R130 & R104) near the ic101.
              • roadrunninmark
                • Apr 2019
                • 11
                R J...I checked for DC voltage at the locations you said. I am seeing voltage of 15.1 at the two smaller items on the left at about 5 or so at the big one on the right.
                • R_J
                  • 9535
                  Ok thats good, the power supply is working, I suspect the problem will be with the main board
                  • CapLeaker
                    Leaking Member
                    • 8127
                    i am almost betting that the hdmi goes straight to the main processor. Usually that means game over unless you replace the main board or that IC.
                    • roadrunninmark
                      • Apr 2019
                      • 11
                      I tried to find if the board was available, it doesn't seem to be. Is it possible to replace the main chip on the board and where could you find one?
                        More likely the IC for the HDMI is damaged. Look at the IC by the HDMI port and get the P/N so you can get the spec sheet to find out if the VCC pins may be shorted out, but since you do not have tools to do SMD level repair then it will be a waste of time to look for the IC's.
                        • roadrunninmark
                          • Apr 2019
                          • 11
                          Will having a bad chip at the HDMI cause the unit not to power on? What tool would be needed to check the IC? What does IC stand for???
                            If it shorted out then it can lock up the micro controller.
                            IC = Integrated circuit.
                            Tools? You need the IC spec sheet, DMM, Oscilloscope, etc.
                            Even if you find bad IC's, then what?
                            • CapLeaker
                              Leaking Member
                              • 8127
                              unfortunately I think this is a lost cause. I'd part it for other projects.
                              • karthur
                                Samsung UN60EH6000 wont come on after lightning strike.
                                by karthur
                                We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                Here is what I have checked.
                                On the power supply board, 14pin connector:
                                1 :12.7 Vdc
                                3 :12.7
                                5 :12.7
                                7 :12.7
                                9 :0
                                11 :5.
                                13 :5....
                                11-01-2023, 06:18 PM
                              • MrCreosote
                                Lightning Strike: 55" TV dead: is display panel OK?
                                by MrCreosote
                                THE LIGHTNING:
                                This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                Very close and probably a very strong EMP.
                                THE TV:
                                No standby LED. Some voltage from PSB (not totally dead).
                                But found a kit of ALL 4 circuit boards for $55.
                                At first thought, this will fix my TV.
                                But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                08-16-2021, 10:27 PM
                              • pbig
                                advices for repairing Sony Bravia 32EX600 after lightning strike
                                by pbig
                                hi everyone,
                                my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                - from connector CN6150 (15 poles)
                                STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                06-28-2023, 02:43 AM
                              • ktmmotocross
                                DELL 5537 LA-9982P - not work after lightning strike
                                by ktmmotocross
                                Hello.
                                Have this DELL 5537 LA-9982P that not work after lightning strike to house.
                                i replaced PQ701 but now have only 5.5V after it. ACDRV have voltage only for a moment when attach charger. BQ24717 have ACDET 2.58V, VIN 19V. Dont have this charger ic , can be replaced by other like 737?
                                How to check if PSID is ok?
                                MOD Edit: Schematic & boardview moved to new thread - https://www.badcaps.net/forum/showthread.php?t=122414
                                12-25-2022, 03:39 AM
                              • MMH3
                                Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                by MMH3
                                i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                Never ever i experienced problems with that.
                                Now i have one 5050sff machine, where this jumper isnt working at all.
                                I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                The history of the machine is that i used it in my office...
                                03-23-2025, 09:28 PM
