Samsung LCD LN40AQ550P3FXZA Solarization Issue
  • jm442123
    • Aug 2019
    • 9
    Hi all. Any help would be greatly appreciated.
    Thiss is a Samsung LCD TV model LN40A550P3FXZA with a picture solarization issue that I am trying to trouble shoot.
    I have spent most of my time troubleshooting the T-con board. All test points on the T-con board have stable DC voltages. I have documented those voltages on all test points but can not find anywhere what these voltages should be. The GRD test point on the T-conn board reads 1.8v DC which seems like it should read 0 v DC.
    No capacitors on any of the boards appear to have issues. I would like to be sure which board needs to be replaced before I buy a replacement board. Attached are pictures of the TV picture that shows the issue if that would help isolate which board may be bad.
    Jim
  • jm442123
    • Aug 2019
    • 9
    Re: Samsung LCD LN40AQ550P3FXZA Solarization Issue
    Also attached are pictures of each of the 3 boards on this Samsung LCD LN40AQ550P3FXZA with a Solarization Issue.
      • 12184
      • U.S.
      See where it says GAMMA? those would be the points to test.
        • 12184
        • U.S.
        they should go gradually in one direction like 1.2, 2.3, 3.4 so on if next one is like 1.2 then you have a problem with the gamma ic, I do believe.
        • jm442123
          • Aug 2019
          • 9
          Yes. I have tested the GAMA test points and have the readings for each test point, but I don't know what readings would indicate proper voltages. I have also tested the 5 additional test points inside the GAMA test points and the 5 test points to the left of the yellow ribbon connector. However I have no documentation that tells me what each test point should read.
            • 12184
            • U.S.
            What are your readings? start with 1 then 2, 3, thru 17 post results here.
            • jm442123
              • Aug 2019
              • 9
              These are the reading from ground to the test point, not reading between test points. Meaning black to ground and red to test point 1, etc.
              1 15.0
              2 12.83
              3 12.04
              4 11.14
              5 10.73
              6 10.40
              7 9.98
              8 9.12
              9 8.16
              10 13.19
              11 14.08
              12 11.64
              13 6.81
              14 5.62
              15 4.88
              16 3.56
              17 2.65
              • diif
                • Feb 2014
                • 6978
                • England
                Yes, faulty gamma ic, I'd guess an AS15.
                • R_J
                  • 9535
                  Looks like AS19-H1G
                  • neilc6
                    • Nov 2015
                    • 1550
                    Your tcon part number is 35-D026047. Lots on ebay. I have gotten damaged and non-working used tcons on ebay so it's a bit of a crap shoot unless you can find a new one. I find 10 yr old obsolete LCD TVs are getting less worth it to repair. TV is only worth about $80 working.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Originally posted by R_J
                      Looks like AS19-H1G
                      You're right, I didn't zoom in on the photo.
                      • jm442123
                        • Aug 2019
                        • 9
                        Thanks for the opinion that it is a bad T-Con board because of the bad Gama IC, but what leads you to that conclusion based on the test point data? Just curious.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          A non faulty one produces a linear graph when plotted.
                            • 12184
                            • U.S.
                              • 12184
                              • U.S.
                              • jm442123
                                • Aug 2019
                                • 9
                                Yes. I ordered a "new" T-con board on ebay for $28.22. It looked like the Gama IC was about $12. At those prices I would just a well go with a whole new T-con board. I am hoping it is a good T-con board.
                                Diff .... So a good board would have a downward slope of the voltages from TP1 to TP17. Is that correct? Thanks for all of your help.
                                Jim
                                • R_J
                                  • 9535
                                  This is a rough graph of you voltages, its not that bad but your picture is not that bad. If more of the voltages were off your picture would look a lot worse.
                                    T-CON check spreadsheet by Tom66:
                                    https://www.badcaps.net/forum/showth...&highlight=VGH
                                      • 12184
                                      • U.S.
                                      Did you read post 4?? On your chart you're ok 1 thru 9 then it goes up, which is bad. Not rocket science.
                                        • 12184
                                        • U.S.
                                        lin·e·ar
                                        /ˈlinēər/
                                        Learn to pronounce
                                        adjective
                                        adjective: linear
                                        1.
                                        arranged in or extending along a straight or nearly straight line.
                                        "linear movement"
                                        consisting of or predominantly formed using lines or outlines.
                                        "simple linear designs"
                                        involving one dimension only.
                                        "linear elasticity"
                                        Mathematics
                                        able to be represented by a straight line on a graph; involving or exhibiting directly proportional change in two related quantities.
                                        "linear functions"
                                        2.
                                        progressing from one stage to another in a single series of steps; sequential.
                                        "a linear narrative"
                                        Origin
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
