Seiki SE39UY04 Main board AND Tcon board bad?
  • jayjr1105
    • 281
    Just replaced the main board on this set I picked up for free. The original main board made a weird hissing noise and the standby light just stayed red. New board came in, installed and the noise is gone and the set turns on now (standby light goes from red to blue) also the backlight comes on but now I have no on screen display. No splash screen, volume indicator, etc.
    I made absolute sure the main board matched up with my set because there were 3-4 revisions.
    Power supply seems rock solid. All voltages are reading as they should.
    Tcon is cheap like $12. Should I go there next or did I maybe get a bad replacement main board as well?
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • nomoresonys
    • 12276
    • U.S.
    Re: Seiki SE39UY04 Main board AND Tcon board bad?
    Try holding in power button on tv for 30 seconds or until it restarts if it does restart.
    • jayjr1105
      • 281
      Did that, and it reset once. Now I hold it for a few minutes and nothing.
      Still no OSD
      Ryzen 3600x
      FX-8802 Iron
        Did you verify that the LVDS cable from main board to T-CON board is properly seated? Did you check and find out if you do have `2VDC at both ends of the fuse on the T-CON with ref to GND?
        • jayjr1105
          • 281
          All cables are nice and snug. Not sure where to measure the fuses on the tcon board. I don't see any fuses. Maybe a surface mount 0 ohm resistor or two.
          http://prntscr.com/os6pgl
          Ryzen 3600x
          FX-8802 Iron
          • R_J
            • Jun 2012
            • 9588
            The fuse is FP1.
            • nomoresonys
              • 12276
              • U.S.
              Maybe try a firmware update.
              Unplug the power cord from electrical outlet.
              Need the firmware on fat32 formatted thumb drive. Plug USB thumb drive into USB input.
              Plug power cord back into electrical outlet.
              Power on indicator light in the front of the TV will flash red, blue rapidly.
              Once indicator light stops flashing and stays red, give it a couple more minutes just for good measure, unplug the power cord.
              Remove the thumb drive.
              Plug power cord back into electrical outlet and turn on TV.
              Do not remove the USB flash disk or power-supply during updating, otherwise the operation will fail.
              • jayjr1105
                • 281
                Once indicator light stops flashing and stays red, unplug the power cord.
                Where might I find that firmware file? Just a fat32 formatted flash drive?
                Ryzen 3600x
                FX-8802 Iron
                • nomoresonys
                  • 12276
                  • U.S.
                  No, you need the firmware, isn't there a seiki website?
                  • jayjr1105
                    • 281
                    Found the firmware. Someone had it dropboxed from a website. Looks like the procedure is to press the menu button, hit 0 four times then hit sw update. Unfortunately I don't have the remote to do this.
                    Ryzen 3600x
                    FX-8802 Iron
                    • nomoresonys
                      • 12276
                      • U.S.
                      See some here too, some say the 50 inch firmware works better on the 39 some say it don't, I would try the method I posted, might work, won't hurt nothing if it don't, seems to be some modified firmware floating around too, that's if the links work, I didn't click any: https://www.dropbox.com/sh/vjoupvucu...ZvoCukqGa?dl=0
                      • jayjr1105
                        • 281
                        That's the link I used. I tried your method, no dice. I think I'm going to bring the board into work tomorrow. A guy has a chip flasher he uses for motherboards. Maybe he can flash my ROM that way.
                        Ryzen 3600x
                        FX-8802 Iron
                        • nomoresonys
                          • 12276
                          • U.S.
                          Well anyway there's 4 pages here, looks like the modded firmware is working best: https://www.overclock.net/forum/44-m...sappeared.html
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Did you take the tcon cover off before looking ?, measure both sides of the fuse.
                            The .img file is really a .tar file. several tools, firmware update and video animation so it's not possible to flash with an external programmer.
                            It's not ROM (read only memory), it uses NAND flash.
                              Check the Voltage on the SMD fuse on the TC-ON first.
                              • jayjr1105
                                • 281
                                With the set powered on, I get .3v on either side of the fuse on the Tcon board. It is labeled FP1 like someone mentioned. White surface mount fuse.
                                Ryzen 3600x
                                FX-8802 Iron
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  .3 is too low, how are you measuring? black probe on chassis ground red probe either side of fuse, meter set dcv 20.
                                  • jayjr1105
                                    • 281
                                    Yes, DC voltage mode. Good meter, probemaster probes with sharp gold tips. 0.3v on either side of the Tcon fuse. Does that indicate a Tcon or Mainboard issue?
                                    Ryzen 3600x
                                    FX-8802 Iron
                                      Please upload good clear hi-res pictures of the board, especially the main board which the switch 12V to the T-CON is generated from.
                                      • jayjr1105
                                        • 281
                                        https://imgur.com/a/XU8KTWd
                                        Ryzen 3600x
                                        FX-8802 Iron
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • JDC
                                          by JDC
                                          ONN 100012588
                                          Long answer:
                                          07-15-2022, 07:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
