Seiki SE39UY04 Main board AND Tcon board bad?
  • R_J
    • Jun 2012
    • 9588
    Re: Seiki SE39UY04 Main board AND Tcon board bad?
    Using the SJ photo, It looks like the t-com VCC is switched by Q30 on the rear of the main board, so check the voltage on pin 1, pin 8 and pin 5(gate)
    • jayjr1105
      • 281
      Pin 1 - 12.7v
      Pin 5 and 8 were 0.3v
      Keep in mind, I have the original mainboard which can be harvested for parts.
      Ryzen 3600x
      16GB Patriot 3600MHz
      MSI B450 Gaming Plus
      MSI Air Boost Vega 56
      Acer 32" 1440P Freesync
      Rosewill Capstone 750W
      Hakko FX-888D Station
      FX-8802 Iron
      MG Chem .8mm 63/37 RA 2.2%
      • R_J
        • Jun 2012
        • 9588
        Pins 1,2,3 - 12v is good
        Pins 6,7,8 - 0v means the fet (switch) is not turned on
        Pin 5 is the gate, 0.3v is likely not enough voltage to turn on the fet
        Something is not telling the fet to turn on and supply the t-con voltage.
        • jayjr1105
          • 281
          That's all I need to hear really. I'll go back to the ebay seller of the board and ask for another one. I just wanted confirmation really. Thanks for the troubleshooting steps.
          Ryzen 3600x
          FX-8802 Iron
            Does pin 5 change state when toggling TV on and off?
            Most of the time they will use P-CH for this 12V switching for T-CON VCC, so the Gate Voltage has to about 4V < the Source pin Voltage for it to be ON.
            • jayjr1105
              • 281
              Another main board came in today. Same exact issue. Ugh!
              I just ordered a T-Con board for $9. Is there a possibility the LCD is bad? FWIW the new main boards at least turn the TV on. The original main board wouldn't let the set be turned on.
              Ryzen 3600x
              FX-8802 Iron
              • Diah
                • Feb 2013
                • 6440
                • jayjr1105
                  • 281
                  So pin 5 and 8 on Q30 should give me ~2v with the tcon board disconnected?
                  Ryzen 3600x
                  FX-8802 Iron
                    Again, does pin 5 of the MOSFET change state when TV is turned ON and OFF?
                    • jayjr1105
                      • 281
                      When shut off, Pin 5 goes down to nothing. Takes a while, I assume it's capacitors draining.
                      Well guys my amateur a$$ is throwing in the towel. New main board, new TCON, power supply voltages are all fine. Set powers on, standby light goes from red to blue, backlight comes on but no picture. I have no idea if it's something really simple or if the display itself is bad.
                      Ryzen 3600x
                      FX-8802 Iron
                      • nomoresonys
                        • 12276
                        • U.S.
                        #31
                        Take a good look at the driver/tab bond board/s, check the cof (chip on film) on the flex cable for discoloration or being very hot, maybe test the caps on driver board for shorts.
                        • jayjr1105
                          • 281
                          Backlight is good. I assume that's what you mean by driver board.
                          I suppose it could be a bad ribbon cable. Where is the COF?
                          Just another interesting thing... When I power it on and leave it on, 20 minutes later it's turned off again. I assume it turns off after not receiving input? That tells me the "brains" are working. I don't have the remote sadly.
                          Edit: Also, when plugged in it pulls about 8 watts from the wall, when turned on it jumps to around 65 then settles around 43. Measuring with a kill a watt meter
                          Ryzen 3600x
                          FX-8802 Iron
                          • nomoresonys
                            • 12276
                            • U.S.
                            #33
                            This here, not English but has subtitles, requires some disassembly, MUST BE VERY CAREFUL when near the panel, they are very very easy to break, if panel breaks/cracks then it's game over: https://www.youtube.com/watch?v=P0nsEaR9YgA
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • ygorsan
                              by ygorsan
                              🧩 Problem Summary:
                              • I
                              07-28-2025, 08:34 AM
                            • JDC
                              by JDC
                              ONN 100012588
                              Long answer:
                              07-15-2022, 07:39 AM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
