Sony KDL-40W2000 3 LED Blnks Error
  • Diah
    • Feb 2013
    • 6562
    Re: Sony KDL-40W2000 3 LED Blnks Error
    this UNIT are dual IC made ONLY by Sony self as SPI and SMPS. it had script run on and off too
      "when 3.3V went grounded via IC6100 there other line continue feed the set to register error." How does IC6100 ground out the 3.3V? I do not see how IC6100 will ground out the 3.3V, I do not see 3.3v supply line connected to IC6100.
      • Diah
        • Feb 2013
        • 6562
        do you want to learn or to make point... i am here also to learn from points i didn't face before... did you know about what i wrote (script) how it work on SMPS or SPI... what does it mean at TV platform since 80th .. sorry to say if some one don't know any about this stop make conflict between stand alone hardware and dual one.
        i leave it to OP come to result.
          I am trying to understand how the 3.3V is grounded by the IC6100 and caused 3-blink as you indicated and not going by the service manual, is it that hard to explain? IC6001 has no connection to the 3.3V power supply line so how does it ground that out?
          • Diah
            • Feb 2013
            • 6562
            budm ... this cant be explained if you don't know the basic of Linux script code.
            you can start to explain how does error code generated and redisplayed on front indicator.. which part over all TV are Premiere one PSU or MB??
              What DOES the LINUX has to do with the device grounding out the 3.3V that you indicted when the device has no connection to the 3.3V?
              • Diah
                • Feb 2013
                • 6562
                LOL TV are built on Linux 100%
                  So? Which pin of the IC6100 grounded out the 3.3V power supply, simple?
                  • Diah
                    • Feb 2013
                    • 6562
                    for record this is not first time i discusses this over here... before i did on Toshiba with some one from UK. and i leaved the answer to the owner of the thread .. and here i will do it again you can write me i will do my best to answer what i know.
                      Thanks, just post in here in the forum, that is what this open forum is all about, learning and understanding.
                        • 12330
                        • U.S.
                        #31
                        The one I read said if you do have the standby then it's the mainboard at fault.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          #32
                          Hi all many thanks for the input my findings are as follows:
                          I get all CN6200 voltages when TV relay clicks to try and turn on after that the relay clicks and goes off I'm sure as all voltages start dropping significantly apart from 3v3 standby.
                          If I disconnect all connectors from PSU no relay click at all, something is causing the fault other than the psu I think.
                          I can't get a reading from the IC as it cuts to the error mode too quick.
                          Hope that makes sense, I think it's related to the main board as I get the same values with Tcon disconnected, something is triggering the 3 blink error.
                          Thanks guys.
                          S.
                            In your post #8 "Gettting ~240v on both sides of the fuse - What i don't get is I get nothing on the standby 3v3 pin and i have a Red standby LED then goes to green when powered then, when failure occurs and 3 blinks code appears. I monitored pin 5 STBY+3.3V (CN6200) when on standby, green light and when 3 blink error is repeating, still nothing. DMM set too Auto range on VDC = 0.00v "
                            So the question is, is the 3.3VSTBY always stay at 3.3V or it drops to 0V with or without having main board connected?
                            So keep meter probes on chassis and 3.3V STBY pin and tell us if it is going up and down or not.
                            • R_J
                              • 9624
                              I think he is refering to the fact that there are two operational sections on some of these models, One is for the digital part and one is for the analogue. and they have seperate service menu's. I have seen a kdl46S2000 that will cycle on and off if set to the only hdmi input. It also will not program or receive any digital tuner channels, other than that the analogue part the tv works perfect.
                              That said, none of the tv will operate if there is no standby voltage.
                              When the tv quit, what input was it on? You can try disconnecting the flat white cable between the main board and the FEE board (with the card slot) and see if the tv stays on.
                                That is what I am trying to find out if the 3.3V STBY is dropping in and out or what, OP said he gets 0V on 3.3V STBY then the main board will not have any power to run it to produce error code if 3.3VSTBY is not present. Trying to get the answer from OP.
                                • Diah
                                  • Feb 2013
                                  • 6562
                                  this is the answer
                                    • 12330
                                    • U.S.
                                    #37
                                    Check those solder joints on powerboard with a big ass magnifying glass.
                                      Post #32:
                                      "I can’t get a reading from the IC as it cuts to the error mode too quick."
                                      Which IC, which pin?
                                      • Diah
                                        • Feb 2013
                                        • 6562
                                        Post #32:
                                        "I can't get a reading from the IC as it cuts to the error mode too quick."
                                        i gave answer as i thought his write belong on my question on this post
                                          0V on all the pins?
                                          VSEN cannot be 0V since it is connected to the main filter cap via resistors that has 330VDC in standby.
                                          VC1 will be 0V if PS-ON is not present, VC1 is generated by the 3.3V STBY AUX winding of the 3.3VSTBY SMPS transformer.
                                          Did you us chassis GND of HOT SIDE circuit ground which will be the negative leg of the main filter cap in the hot side.
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • jchon
                                            Sony A1e 5-blinks help
                                            by jchon
                                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                            I found the service manual, which was critical to know where to probe.
                                            https://www.manualslib.com/manual/20...1e-Series.html
                                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                            Unfortunately the 5-blinks...
                                            06-28-2023, 11:52 AM
